MMCX7-P-C-GF-ST-CA3
MMCX7-P-C-GF-ST-CA3
    SAMTEC(申泰)
    MMCX7-P-C-GF-ST-CA3
MMCX7-P-C-GF-ST-CA3 数据手册
RF-16 (Rev 04FEB16) MMCX7–P–C–GF–ST–CA3 MMCX7–J–C–GF–ST–CA3 MMCX7–P–C–GF–RA–CA3 MMCX7-CA SERIES 75Ω MICRO-MINI COMPONENTS SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?MMCX7-CA Shell Material: Brass (–J) BeCu (–P) Insulator Material: PTFE Outer Contact Material: BeCu Pin Material: Brass Operating Temp Range: -65 °C to +125 °C Contact Resistance: Center: Testing Now! Outer: Testing Now! Frequency Range: Testing Now! (Cable dependant) Impedance: 75 Ω RoHS Compliant: Yes MMCX7 GENDER TYPE PLATING –C –GF –ST = 10 µ" (0.25 µm) Gold center contact, 3 µ" (0.08 µm) Gold outer contact = Straight = Cable –J = Jack ORIENTATION TERMINATION –CA3 = RG 179 Cable (5.25) .207 (4.48) .176 DIA (8.80) .346 Processing: (13.60) .535 Lead-Free Solderable: Yes (2.70) .106 DIA Supplied with pins and ferrules. See website for dimensions. MMCX7 GENDER TYPE PLATING –C –GF –RA = 10 µ" (0.25 µm) Gold center contact, 3 µ" (0.08 µm) Gold outer contact = Right Angle = Cable –P = Plug ORIENTATION (14.40) .567 (4.48) .176 DIA –ST (2.70) .106 DIA (2.70) .106 DIA (7.00) .276 (9.60) .378 –ST Note: Designed to meet SMPTE 424M 3G-SDI specifications. –CA3 = RG 179 Cable = Straight (9.00) .354 (4.00) .157 –RA Supplied with pin and ferrule. See website for dimensions. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. TERMINATION (2.70) .106 DIA
MMCX7-P-C-GF-ST-CA3 价格&库存
很抱歉,暂时无法提供与“MMCX7-P-C-GF-ST-CA3”相匹配的价格&库存,您可以联系我们找货
MMCX7-P-C-GF-ST-CA3
  • 5+196.811105+25.51047
库存:5
MMCX7-P-C-GF-ST-CA3
  • 2+92.401882+11.97705
库存:360
MMCX7-P-C-GF-ST-CA3
    • 1+115.05240
    • 10+111.60720
    库存:3
    MMCX7-P-C-GF-ST-CA3
    • 2+49.978622+6.47818
    库存:261
    MMCX7-P-C-GF-ST-CA3
    • 1+102.361641+13.26802
    • 10+92.3704010+11.97297
    • 25+82.2587625+10.66230
    • 50+50.6226850+6.56167
    • 100+45.29067100+5.87054
    • 500+43.54305500+5.64401
    • 1000+39.958651000+5.17941
    • 2000+37.875852000+4.90943
    库存:360
