Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
MMCX Series
Ultra-small Push-on Coaxial Connector
Jan. 2022 ①
MMCX Series/Ultra-small Push-on Coaxial Connector
Features
1. Push- on System for Easy
Attachment and Removal
2. Applicable Cable
RG Type High Frequency Coaxial Cable
・RG- 178B/ U (φ1. 8)
・RG- 316/ U (φ2. 59 Max. )
Extra- fine Fluororesin Cable
・Single Shielded Cable(φ1. 13,φ1. 37,φ1. 48)
・Double Shielded Cable(φ1. 32)
Semi- flexible Cable
・External conductor diameter equivalent to
0. 085 inches
( With jacket finishing diameter is φ2. 5)
0. 047 inches
( With jacket finishing diameter is φ1. 44)
3. Double- ended Cable
Assembly with Other Hirose
Series
Double- ended cable assembly available with H. FL,
U. FL, SMA, and SMA( R) .
4. High Frequency
Characteristics
Guaranteed frequency : DC to 8GHz
( The guaranteed frequency of some parts is DC
to 6GHz. )
5. Two Types of Plugs Available
In addition to the standard plug, a mating
compatible outer conductor contact reinforced
type is also available.
6. RoHS2 Compliant
Application Examples
Wireless LAN, GPS, POS, Measurement Instrument, Wiring Inside Transmission Equipment
2
Product Specifications
Characteristic Impedance
50 Ω
Operating Temperature
-55 to +85℃
Rated Frequency
DC to 8GHz
Operating Humidity Range
90% Max.
Item
Specification
Condition
Insulation Resistance
500 M Ω Min.
Measured with 500V DC
Withstanding Voltage
No flashover or insulation breakdown
500V AC for 1 min.
Contact Resistance
Center : 10m Ω Max.
Outer : 5m Ω Max.
Measured at a maximum of 100mA (DC or 1000Hz)
Retention Force of
Female Contact
0.2 to 2N
Measured with φ 0.37 pin gauge.
Insertion Force : 15N Max.,
Extraction Force : 6 to 15N
Standard Type
Extraction Force : 6N Min.
Outer Conductor Contact Reinforced Type [MMCX(AR)]
1.2 Max.
DC to 6GHz
1.4 Max.
6 to 8GHz
Vibration Resistance
No electrical discontinuity for 1 μ s
or more.
No damaged, cracks or loose parts.
Frequency of 10 to 500Hz, single amplitude of 0.75mm,acceleration
of 98m/s2
for 12 cycles in each of the 3 axes direction.
Thermal Shock
or more.
Acceleration of 735m/s2, for a duration of 6ms, sine half-wave
waveform, 3 cycles in each of the 3 axes
direction.
Humidity Resistance
No damaged, cracked or loose parts
Insulation Resistance : 10M Ω Min.
(High Humidity)
Insulation Resistance : 500M Ω Min.
(Dry)
96 hours at temperature of 40℃ and humidity of 95%.
Temperature Cycle
No damaged, cracked or loose parts.
Temperature : -55℃ → +20 to +35℃ → +85℃ → +20 to +35℃
Time : 30 min. → 5 min. → 30 min. → 5 min.
5 cycles
Mating Durability
Contact Resistance
Center : 20m Ω Max.
Outer : 10m Ω Max.
Mating/unmating : 500 mating cycles : Standard Type
Mating/unmating : 100 mating cycles : Outer Conductor Contact
Salt Spray
Satisfies the V.S.M.R.
5% salt water solution for 48 consecutive hours
Total Insertion /
Extraction Force (Plug)
V.S.W.R.* (Note)
Note : Refer to section on V.S.W.R. for details.
* V. S. W. R. Measurement System
The above V. S. W. R. standard values were measured using the measurement system shown below.
Network Analyzer
Test Set
Test Port
D.U.T
Termination
Test Port Cable
Note 1 : The cable connector is measured attached to a double-ended cable assembly with an applicable 15cm cable.
Note 2 : The board connector is measured while mounted to a 50 Ω board and attached to a dedicated adapter.
3
V.S.W.R.
V. S. W. R is 1. 2 Max. ( DC to 6GHz) or 1. 4 Max. ( 6 to 8GHz) excluding the products listed below.
Item
Part No.
V.S.W.R.
MMCX-R-SMT-8
1.2 Max. (DC to 8GHz)
1.2 Max. (DC to 4GHz)
MMCX-LR-SMT(40)
1.3 Max. (4 to 6GHz)
1.4 Max. (6 to 8GHz)
Receptacle
MMCX-R-PC(40)
1.2 Max. (DC to 6GHz)
1.3 Max. (DC to 3GHz)
MMCX-LR-PC-1(40)
1.5 Max. (3 to 6GHz)
MMCX(AR)-P-SF047
MMCX(AR)-P-SF085
1.4 Max. (3 to 8GHz)
MMCX(AR)-LP-SF047
Plug / Jack
MMCX-PJ-SF085
1.4 Max. (3 to 4GHz)
MMCX(AR)-LP-SF085
1.5 Max. (4 to 5GHz)
1.6 Max. (5 to 6GHz)
Materials / Finish
Component
Material
Finish
Shell
Brass
Stainless steel (Conversion Adapter)
Gold Plating
Male Center Contact
Phosphor Bronze
Gold Plating
Female Center Contact
Beryllium Copper
Gold Plating
In-line Contact (Male/Female)
Beryllium Copper (Conversion Adapter)
Gold Plating
Insulator
PTFE Resin
Securing Ring
Beryllium Copper (Plug)
Gold Plating
Crimp Sleeve
Bronze
Gold Plating
Cap
Brass (Plug)
Gold Plating
4
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
■ Standard Type
MMCX - LP - 066 (40)
❶
❷
❸
❹
❶
Series Name
MMCX
❸
Applicable Cable
/PCB Mounting
Style
178B/U
316/U
FHSB
088
066
SF085
PC
SMT
❷
Connector Type
P
: Straight Plug
LP
: Right Angle Plug
PJ, BPJ : Pannel Jack
J
: Straight Jack
LR
: Right Angle Receptacle
R
: Receptacle
❹
Specifications
RoHS2 Compliant
: RG-178B/U ( φ 1.8)
: RG-316/U ( φ 2.59 Max.)
: φ 1.48 (Single Shielded Cable)
Coaxial Fluororesin Cable
: φ 1.37 (Single Shielded Cable)
: φ 1.32 (Double Shielded Cable)
: φ 1.13 (Single Shielded Cable)
:External Conductor Diameter
Equivalent to 0.085 Inches
(With Jacket Finishing Diameter
is φ 2.5)
: PCB Through Hole Type
: PCB SMT Mounting Type
Examples of Mated Condition
Right Angle Receptacle + Straight Plug
Straight Receptacle + Straight Plug
Right Angle Receptacle + Right Angle Plug
Straight Receptacle + Right Angle Plug
5
Interface Dimensions
[Jack]
REF.PLANE
[Plug]
2.59 Min.
1.6±0.03
2.69 Min.
1.48±0.02
0.1+0.15
-0.1
0.23 Max.
0.2 Max.
φ0.7±0.02
60
φ3.02±0.02
φ2.88±0.02
1.4 Min.
15
φ0.4±0.02
2.32±0.02
70
1.05±0.15
φ1.6±0.02
φ2.38±0.02
REF.PLANE
30
[Reference] MMCX-R-SMT-8 High Frequency Characteristics
■Insertion Loss
■V.S.W.R.
Test Bord
6
Right Angle Plug
For φ1.32 Double Shielded Cable
For φ1.13 Single Shielded Cable
Connects with U. FL- LP- 066HF( 06) .
φ1.27
7.5
7
5.25
φ3
4
Part No.
MMCX-LP-066(40)
HRS No.
Purchase Unit
CL0339-0019-2-40
20pcs per bag
For φ1.37 Single Shielded Cable
Connects with U. FL- LP- 088HF( 06) .
φ1.9
φ0.96
11
7
5.25
4
Part No.
MMCX-LP-088(40)
Purchase Unit
CL0339-0020-1-40
20pcs per bag
For φ1.48 Single Shielded Cable
7
Part No.
MMCX-LP-FHSB(40)
11
φ0.9
4
φ1.9
HRS No.
5.25
φ3
10
HRS No.
CL0339-0007-3-40
7
Purchase Unit
100pcs per bag
For RG-178B/U Cable
7
HRS No.
Purchase Unit
CL0339-0001-7-40
20pcs per bag
For RG-316/U Cable
φ1.6
11
7
φ3
4
5.25
12
φ3.5
φ0.9
5.25
Part No.
MMCX-LP-178B/U(40)
φ2.4
11
4
Part No.
HRS No.
Remarks
MMCX-LP-316/U(40)
CL0339-0006-0-40
We accept cable assembly specifications. Please contact a Hirose sales representative.
8
Straight Plug
φ4
φ3.9
13.7
Part No.
MMCX-P-066(40)
HRS No.
Purchase Unit
CL0339-0023-0-40
100pcs per bag
14
φ4
φ0.96
φ1.9
7
Part No.
MMCX-P-088(40)
HRS No.
Purchase Unit
CL0339-0021-4-40
20pcs per bag
φ0.93
φ1.9
14
7
φ4
φ4
10
Part No.
MMCX-P-FHSB(40)
HRS No.
CL0339-0008-6-40
9
Purchase Unit
100pcs per bag
For RG-178B/U Cable
φ0.93
φ4
φ2.4
14
7
Part No.
Purchase Unit
CL0339-0010-8-40
20pcs per bag
Straight Jack
For RG-178B/U Cable
14.8
φ2.4
φ0.93
7.8
φ4
MMCX-P-178B/U(40)
HRS No.
Part No.
MMCX-J-178B/U(40)
HRS No.
CL0339-0011-0-40
10
Purchase Unit
100pcs per bag
Panel Jack
0.8
5.1
φ3.9
φ7
φ7.7
φ3.6
8.6
6.5HEX
No.10-32UNF-2A
Part No.
HRS No.
Remarks
MMCX-BPJ-066(40)
CL0339-0016-4-40
1
+0
0 .1
■ Panel Cut-Out Dimensions
φ
6.
+0.1
Recommended Panel Thickness : 1.3 to 2.5mm
For Semi-flexible Cable (Low Loss Type)
External conductor diameter equivalent to 0. 085 Inches. ( With jacket finishing diameter is φ2. 5. )
(10.7)
(7.2)
φ19.5±0.3
17±0.2
φ17.5±0.3
φ4
10
Part No.
HRS No.
Remarks
MMCX-PJ-SF085
CL0339-0045-0-00
11
Receptacle
For Straight SMT
φ3.5
3.5
1.7
φ0.75
3.5
Part No.
4.69
HRS No.
MMCX-R-SMT-8
Purchase Unit
CL0339-0046-0-00
500pcs per reel
■ Recommended PCB Layout
37±0.05
37±0.05
15±0.03
φ9±0.05
φ20.8±0.03
For Right Angle SMT
7.37
4.45
Part No.
HRS No.
MMCX-LR-SMT(40)
CL0339-0003-2-40
7±0.05
4.6±0.1
2±0.1
4×φ1±0.1
3.5±0.1
3.5±0.1
4.5±0.05
7.5±0.05
3.5 +0.1
1.1
12
φ4.47
φ0.7
1.4
3.4
3.51
1±0.03
1
Purchase Unit
50pcs per tray
For Straight Through-Hole
3.5
7.37
Part No.
4-0.5
φ3.5
φ0.7
4.45
HRS No.
Purchase Unit
CL0339-0005-8-40
100pcs per bag
■ Recommended PCB Dimensions
2.54±0.05
2.54±0.05
5-φ
0.9
+0
.1
For Right Angle Through-Hole
3.5
6.8
3.8
2.1
4.75
4-0.5
2.54
3.5
4-0.5
φ0.7
2.54
6.5
φ3.5
Part No.
MMCX-LR-PC-1(40)
HRS No.
CL0339-0013-6-40
2.54±0.05
2.54±0.05
MMCX-R-PC(40)
4-0.5
2.54
3.5
2.54
5-φ
0.9
+0
.1
Purchase Unit
10pcs per bag
Conversion Adapter
SMA Conversion Adapter (Mated Portion : SMA Plug - MMCX Jack)
8HEX
Part No.
HRMP-MMCXJ
HRS No.
Purchase Unit
CL0311-0312-1-00
20pcs per bag
Note : Can be used with standard type and outer conductor contact reinforced type (MMCX[AR]) MMCX plugs.
SMA Conversion Adapter (Mated Portion : SMA Jack - MMCX Plug)
14
4.05
6
φ6.35
φ4
1/4 -36UNS-2B
13.74
Spanner Engaged Width : 5.6
Part No.
HRMJ-MMCXP
HRS No.
CL0311-0313-4-00
1/4_36UNS_2A
Purchase Unit
20pcs per bag
14
Plug/Jack Termination Tools
Item
Part No.
MMCX-LP-066(40)
Straight Jack
Usage
CL0902-3064-6-00
Cap Press Fitting
HT103/MRF01-J-178
CL0350-0128-5-00
Outer Conductor Tightening
MMCX-LP/PR-MP
CL0902-3064-6-00
Cap Press Fitting
HT103/MRF01-J-178
CL0350-0128-5-00
MMCX-LP/PR-MP
CL0902-3064-6-00
Cap Press Fitting
HT103/MRF01-J-178
CL0350-0128-5-00
MMCX-LP/PR-MP
CL0902-3064-6-00
Cap Press Fitting
MMCX-P-066(40)
MMCX-P-066/CV-MD
CL0902-3272-0-00
Clamp Press Fitting
MMCX-P-088(40)
HT103/MRF01-J-178
CL0350-0128-5-00
MMCX-P-FHSB(40)
HT103/MRF01-J-178
CL0350-0128-5-00
MMCX-P-178B/U(40)
HT103/MRF01-J-178
CL0350-0128-5-00
MMCX-J-178B/U(40)
HT103/MRF01-J-178
CL0350-0128-5-00
MMCX-LP-FHSB(40)
MMCX-LP-178B/U(40)
Straight Plug
HRS No.
MMCX-LP/PR-MP
MMCX-LP-088(40)
Right Angle Plug
Tool
15
Ultra-small Push-on Coaxial Connector [MMCX(AR)]
Outer Conductor Contact Reinforced Plug Connector
[MMCX(AR)]
MMCX(AR)- LP - 066
❶
❷
❶
Series Name
❷
Outer Conductor
Contact
Reinforced Type
❸
Connector Type
❸
❹
❹
MMCX
Applicable Cable
or
Board Mounting
Style
(AR)
P :Straight Plug
LP :Right Angle Plug
TMP:Termination Plug
178B/U
FHSB
088
066
SF085
SF047
:RG-178B/U(φ 1.8)
:φ 1.48 (Single Shielded Cable)
:φ 1.37 (Single Shielded Cable)
:φ 1.32 (Double Shielded Cable)
:φ 1.13 (Single Shielded Cable)
: External Conductor Diameter
is φ 2.5)
Equivalent to 0.047 Inches
is φ 1.44)
[Reference] Semi-flexible Cable Configuration and Cable Loss Comparison
Insertion Loss Comparison
(Semi-flexible Cable & Flexible Cable)
Excellent Electrical Performance Due to
Tin-Coated Braided Shielding
L=1m
[Reference] Insertion Loss (Typical)
-2
-3
Insertion loss [dB]
Cable Jacket
Outer Conductor
(Shielding + Tin Coating)
-4
-5
Semi-flexible Cable (φ2.5/0.085 inch)
-6
Flexible Cable (RG-316U)
-7
Semi-flexible Cable (φ1.44/0.047 inch)
-8
Flexible Cable (φ1.37)
-9
Flexible Cable (φ1.13)
-10
Dielectric (PTFE
Center Conductor (Single Wire)
16
1
2
3
4
5
Frequency [GHz]
6
7
8
Standard Type and Outer Conductor Contact Reinforced Type [MMCX(AR)]
Standard Type
Product : MMCX-P-###
Plug ring contacts the receptacle
outer conductor.
Receptacle
Mating
Before
Mating
❶
Plug head does not contact
receptacle outer conductor (without padding)
Only a single point makes
contact with the outer conductor.
After
Mating
Cross Section
Since the contact is strengthened compared to the standard type,
mating feels tighter.
Product : MMCX(AR)-P-###
outer conductor.
Receptacle
Mating
Plug head contacts receptacle outer
conductor (with padding)
Before
Mating
❷ ❶
Contact with the receptacle outer
conductor at two points enhances
prying force and ensures high contact
reliability even in difficult wiring
conditions.
After
Mating
Cross Section
Mating and Extraction Forces Comparison (Reference Value)
(Reference Value)
Mating Force
Extraction Force
Standard Type
15N
15N
Outer Conductor Contact Reinforced Type[MMCX(AR)]
35N
25N
17
Right Angle Plug
7.5
7
5.25
φ3
φ1.27
4
Part No.
MMCX(AR)-LP-066
HRS No.
Purchase Unit
CL0339-0031-8-00
20pcs per bag
11
Part No.
MMCX(AR)-LP-FHSB
φ0.9
φ1.9
5.25
7
4
HRS No.
Purchase Unit
CL0339-0035-9-00
100pcs per bag
For RG-178B/U Cable
7
Part No.
MMCX(AR)-LP-178B/U
φ0.9
φ2.4
11
4
5.25
φ3
10
HRS No.
CL0339-0033-3-00
18
Purchase Unit
100pcs per bag
Straight Plug
φ4
φ3.9
13.7
Part No.
MMCX(AR)-P-066
HRS No.
Purchase Unit
CL0339-0030-5-00
100pcs per bag
φ0.96
φ4
φ1.9
14
7
Part No.
MMCX(AR)-P-088
HRS No.
Purchase Unit
CL0339-0037-4-00
20pcs per bag
For RG-178B/U Cable
14
φ2.4
φ0.93
7
φ4
φ4
10
Part No.
MMCX(AR)-P-178B/U
HRS No.
CL0339-0038-7-00
19
Purchase Unit
100pcs per bag
External conductor diameter equivalent to 0. 047 Inches. ( With jacket finishing diameter is φ1. 44. )
(φ6.25)
52.5
φ24
18
Part No.
HRS No.
Remarks
MMCX(AR)-P-SF047
CL0339-0032-0-00
φ6
φ5.5
Non-reflective Terminator
6
14.5
HRS No.
MMCX(AR)-TMP
CL0353-0010-0-00
Electric Power(W)
Purchase Unit
1/4
20pcs per bag
Conversion Adapter
1/4-36UNS-2B
13.74
φ4
Part No.
8HEX
Part No.
HRS No.
HRMP-MMCXJ
Purchase Unit
CL0311-0312-1-00
20pcs per bag
Plug Termination Tools
Item
Part No.
MMCX(AR)-LP-066
Right Angle Plug
HRS No.
Usage
MMCX-LP/PR-MP
CL0902-3064-6-00
Cap Press Fitting
HT103/MRF01-J-178
CL0350-0128-5-00
MMCX-LP/PR-MP
CL0902-3064-6-00
Cap Press Fitting
HT103/MRF01-J-178
CL0350-0128-5-00
MMCX-LP/PR-MP
CL0902-3064-6-00
Cap Press Fitting
MMCX(AR)-P-066
MMCX-P-066/CV-MD
CL0902-3272-0-00
Clamp Press Fitting
MMCX(AR)-P-088
HT103/MRF01-J-178
CL0350-0128-5-00
MMCX(AR)-P-178B/U
HT103/MRF01-J-178
CL0350-0128-5-00
MMCX(AR)-LP-FHSB
MMCX(AR)-LP-178B/U
Straight Plug
Tool
21
While Taking into Consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the Drawing and Product Specifications sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public
infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com
※ The contents of this catalog are current as of date of 1/ 2022. Contents are subject to change without notice for the purpose of improvements.
22
23
