SMA Right Angle Solder Type Plug for Semi-Rigid Cable
1. Identify connector parts. (2 piece parts)
2. Strip cable to dimensions shown. Do not nick center
conductor during strip operations.
3. Insert cable into body making certain that the cable jacket is
butted against internal body shoulder and cable dielectric is
started into cross hole. Solder center conductor to contact
using 60/40 tin/lead solder as shown. Use a minimum amount
of solder for a good joint.
4. Solder body to cable using 60/40 tin/lead solder as shown.
Use a minimum of heat to minimize cable dielectric growth.
Any growth of cable dielectric shall be flush with contact.
5. Press end cap into body access port using .187 (4.75) dia.
flat punch.
Cable Group
Part No.
“A”
“B”
RG-405/U (.086 Semi-Rigid)
142-0693-101/106
.145 (3.68)
.075 (1.90)
RG-402/U (.141 Semi-Rigid)
142-0694-101/106
.170 (4.32)
.105 (2.67)
233
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“142-0694-101”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+178.195101+23.12067
- 10+151.4722410+19.65340
- 25+141.9843725+18.42236
- 50+135.2098850+17.54337
- 100+128.75829100+16.70628
- 250+120.70356250+15.66119
- 500+114.94931500+14.91458
