2986-6001
2986-6001
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMAJACKR/A50OHMPCB
2986-6001 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV A DCN 39115 DATE APPROVED 05/12 STW .240 6.10 .525 13.34 4X .040 1.02 .051 1.28 .576 14.63 5X .155 3.94 .456 11.58 1/4-36 UNS-2A MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 TERMINAL: BRASS PER ASTM B16, ALLOY UNS No. C36000 INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODY, CONTACT & TERMINAL: GOLD PER ASTM B 488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00010" MIN. NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: PERFORMANCE: N/A PROPRIETARY IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 12.4 GHz THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: RD 07/08/77 CHECKED: APPROVED: DGG 07/13/77 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMA R/A JACK FOR PRINTED CIRCUIT BOARD SIZE CAGE CODE DWG. NO. 2986-6001 B 95077 SCALE: 4:1 SHEET 1 OF 1
2986-6001 价格&库存
很抱歉,暂时无法提供与“2986-6001”相匹配的价格&库存,您可以联系我们找货
  • 1+963.955141+124.77395
