SF2960-6001
SF2960-6001
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMAJACKR/A50OHMSOLDER
SF2960-6001 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING A DCN 41793 DATE APPROVED 10/15 DAL .500 12.70 .180 4.57 .380 9.65 2X .340 8.64 .063 1.60 .033 0.84 X .125 DEEP .050 1.27 .600 15.24 .162 4.11 4X .460 11.68 .103±.003 2.62±0.08 .065 1.65 1/4-36 UNS-2A MATERIAL: BODIES: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CAP: STAINLESS STEEL PER ASTM A-240, ALLOY UNS S30400, TYPE 304 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 TERMINAL: BRASS PER ASTM B16, ALLOY UNS No. C36000 INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODIES & CAP: CONTACT & TERMINAL: PASSIVATED PER AMS-2700 GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: 50 OHMS DC TO 12.4 GHz N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: BNK 10/21/15 CHECKED: APPROVED: DAL 10/21/15 SW 04/07/97 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMA R/A JACK 4 HOLE FLANGE MOUNT W/SOLDER POT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 5:1 SF2960-6001 SHEET 1 OF 1
SF2960-6001 价格&库存
很抱歉,暂时无法提供与“SF2960-6001”相匹配的价格&库存,您可以联系我们找货
SF2960-6001
  • 1+208.382001+26.95740
  • 10+177.1113410+22.91206
  • 25+166.0175925+21.47691
  • 50+158.0953750+20.45205
  • 100+150.55383100+19.47644
  • 250+141.13751250+18.25829
  • 500+134.40923500+17.38789
库存:30
