133-9701-311
133-9701-311
    CINCH
    插件
    MCX
133-9701-311 数据手册
MCX Non-Magnetic RF Connectors PC Mount INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST Right Angle Jack Receptacle "A" GOLD PLATED .110 (2.79) 133-9701-311 SPECIFICATIONS ELECTRICAL RATINGS Impedance: 50 Ohms Frequency Range: 0-6 GHz VSWR: (f = GHz) Straight Cabled Right Angle Connectors Cabled Connectors RG-316 cable ............................................ 1.13 + .04f 1.07 + .04f Uncabled receptacles .................................................................................. N/A Working Voltage: (Vrms maximum) Connectors for Cable Type Sea Level 70K Feet RG-316 ............................................................ 335 85 Dielectric Withstanding Voltage: (VRMS minimum at sea level) Connectors for RG-316, uncabled receptacles ...................................... 1000 Corona Level: (Volts minimum at 70,000 feet) Connectors for RG-316, uncabled receptacles ........................................ 250 Insertion Loss: (dB maximum, tested at 1 GHz) Straight cable connectors .................................................................... 0.1 dB Right angle cable connectors .............................................................. 0.2 dB Uncabled receptacles ............................................................................... N/A Insulation Resistance: 10,000 megohms minimum After Contact Resistance: (milliohms maximum) Initial Environmental Center contact (straight cabled connectors, uncabled receptacles) ................................................. 5.0 8.0 Center contact (right angle cabled connectors) .............. 5.0 15.0 Outer contact .................................................................. 1.0 1.5 Braid to body ................................................................... 1.0 N/A RF Leakage: (dB typical tested at 2.5 GHz) Cable connectors ...................................................................................... -55 Uncabled receptacles ............................................................................... N/A RF High Potential Withstanding Voltage: (Vrms minimum, tested at 4 and 7 MHz) Cabled connectors ................................................................................... 700 Uncabled receptacles ............................................................................... 600 MECHANICAL RATINGS Engagement Design: Compatible with CECC 22220, Series MCX Engagement Force: 5.6 pounds maximum axial force Disengagement Force: 8 pounds maximum axial force, 1 pound min. Contact Retention: 2.3 pounds min. axial force (captivated contacts) 1 inch-ounce min. torque (uncabled receptacles) Cable Retention: Axial Force* Torque (pounds) (in-oz) Connectors for RG316 ......................................... 20 N/A Connectors for RG316DS .................................... 25 N/A * or cable breaking strength whichever is less. ENVIRONMENTAL RATINGS (Meets or exceed the applicable paragraph of MIL-PRF-39012) Durability: 500 cycles minimum Temperature Range: - 65°C to + 165°C Thermal Shock: MIL-STD-202, Method 107, Condition F Corrosion: MIL-STD-202, Method 101, Condition B Shock: MIL-STD-202, Method 213, Condition B Vibration: MIL-STD-202, Method 204, Condition B Moisture Resistance: MIL-STD-202, Method 106 Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com 1
133-9701-311 价格&库存
很抱歉,暂时无法提供与“133-9701-311”相匹配的价格&库存,您可以联系我们找货
