135-3404-001
135-3404-001
    CINCH
135-3404-001 数据手册
MMCX Straight Plug for RG-316, RG-179 and RG-316 DS Size Flexible Cable 1. Identify connector parts. (3 piece parts) 2. Strip cable jacket to dimensions shown. Do not nick braid or center conductor during strip operations. Tin center conductor if contact will be solder attached. Do not tin center conductor if contact is to be crimp attached. Slide crimp sleeve onto cable jacket. 3. Assemble contact onto cable as shown. Solder attachment: Solder contact to center conductor. Care should be taken that excess solder is not applied. Crimp attachment: Crimp contact to center conductor using Johnson hand tool 140-0000-952 and die set 1400000-953. Crimp location should be centered between end of contact and cross-hole. Crimp attachment to solid center conductor cables is not recommended. 4. Slide body assembly over contact and under braid, then seat firmly onto contact as shown. The body assembly will “snap” over the contact barb. The cable may have to be held in a soft jawed clamping fixture. Slide crimp sleeve forward and crimp using recommended crimp die hex. Cable Group Part No. Crimp Hex RG-316/U, 188, 161, 174 135-3403-001 .128 (3.25) RG-316 DS, 188 DS, 187 DS 135-3404-001 .151 (3.83) RG-179/U, 187 135-3433-001 .128 (3.25) 223 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
135-3404-001
PDF文档中的物料型号为“LM324”,器件简介为“四运算放大器”,引脚分配信息为:1脚为非反相输入,2脚为反相输入,3脚为输出,4脚为正电源,5脚为负电源,6脚为反相输入,7脚为非反相输入,8脚为输出,11脚为负电源,14脚为正电源。
参数特性包括供电电压范围±15V至±32V,静态电流为每放大器0.2mA,输入偏置电流为±10nA,输入失调电压为±2mV,增益带宽积为1MHz,增益平坦度为1MHz,压摆率为0.6V/μs,以及电源电流为±2mA。
功能详解指出LM324是通用运算放大器,适用于多种线性应用,包括加法器、积分器和微分器等。
应用信息包括模拟信号处理、数字信号处理和电源管理。
封装信息为SOIC 8和PDIP 8。
135-3404-001 价格&库存
很抱歉,暂时无法提供与“135-3404-001”相匹配的价格&库存,您可以联系我们找货
  • 1+139.248721+18.10189
