142-5439-106
142-5439-106
    CINCH
    SMA
142-5439-106 数据手册
Right Angle SMA Low Loss Diameter .195, .200 and .240 1. Identify connector parts. (3 piece parts) 2. Strip cable to dimensions shown. Do not nick braid, foil or center conductor. Cut foil flush with dielectric, do not remove foil. Make sure that dielectric is clean and free from all particles. Tin center conductor, keeping solder amount to a minimum. Slide crimp sleeve onto jacket of cable. 3. Flare braid and slide body assembly over foil and dielectric, then under braid. Make sure cable center conductor is contained within connector contact, but do not allow foil and dielectric to enter body access port. Solder center conductor to contact through the rear access port. Use a minimum amount of solder for a full fillet joint. .020 (0.51) Diameter solder is recommended. 4. Arrange braid uniformly around crimp stem. Slide crimp sleeve forward and crimp using Johnson hand crimp tool 141-0000913 and recommended crimp die hex. Place expansion cap in access port and seat with recommended Diameter flat punch. Low Loss Diameter “A” Crimp Die Hex Flat Punch Diameter 0.195 .110 (2.79) .213 (5.41) hex .187 (4.75) 0.200 .110 (2.79) .213 (5.41) hex .187 (4.75) 0.240 .135 (3.43) .255 (6.48) hex .242 (6.15) Cable Group Part No. Crimp Hex LMR-195 142-0407-101 142-0407-106 .213 (5.41) .213 (5.41) LMR-200 142-4439-101 142-4439-106 .213 (5.41) .213 (5.41) LMR-240 142-0435-101 142-0435-106 .255 (6.48) .255 (6.48) LMR-195 142-5407-101 142-5407-106 .213 (5.41) .213 (5.41) LMR-200 142-0439-101 142-0439-106 .213 (5.41) .213 (5.41) LMR-240 142-5435-101 142-5435-106 .255 (6.48) .255 (6.48) LMR-195 142-4407-101 142-4407-106 .213 (5.41) .213 (5.41) LMR-200 142-5439-101 142-5439-106 .213 (5.41) .213 (5.41) LMR-240 142-4435-101 142-4435-106 .255 (6.48) .255 (6.48) 249 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-5439-106 价格&库存
很抱歉,暂时无法提供与“142-5439-106”相匹配的价格&库存,您可以联系我们找货
