138-4418-007
138-4418-007
    CINCH
    N型
138-4418-007 数据手册
Type N Straight Plug Crimp Style for RG-58, 142, 213, 214 and LMR-400 Flexible Cable 1. Identify connector parts. (3 piece parts) 2. Strip cable to dimensions shown. Do not nick center conductor. A wire stripper of correct size is recommended for this step. Tin center conductor if contact will be solder attached. Do not tin center conductor if contact will be crimp attached. Slide crimp sleeve onto jacket of cable. 3. Assemble plug contact onto cable as shown. Plug contact should butt against cable dielectric during attachment. Solder Attachment: Solder plug contact to center conductor through solder hole using .020 (.051) diameter flux core solder wire. Use a minimum amount of solder for a good joint. Crimp Attachment: Crimp plug contact to center conductor using Johnson ergonomic hand crimp frame 140-0000-967 with recommended hex size die set. Crimp location should be on end of plug contact next to cable dielectric. Crimp attachment to solid center conductor cables is not recommended. 4. Flare braid and slide plug connector assembly over plug contact and under braid. Seat plug connector assembly firmly onto contact. Arrange braid uniformly around crimp stem. Slide crimp sleeve forward and crimp using Johnson ergonomic hand crimp frame 140-0000-967 with recommended hex size die set. Maintain forward pressure on cable while crimping. Part No. “A” “B” Crimp Sleeve Hex Size Contact Hex Size RG-58/U, 141, 303 138-4407-007 .301 (7.65) .140 (3.56) .213 (5.41) .068 (1.73) RG-55/U, 142, 223, 400 138-4408-007 .301 (7.65) .140 (3.56) .213 (5.41) .068 (1.73) RG-8, 213 138-4416-007 .385 (9.78) .170 (4.32) .429 (10.90) .111 (2.82) RG-9, 214 138-4418-007 .385 (9.78) .170 (4.32) .429 (10.90) .111 (2.82) LMR-400, BELDEN 9913 138-4449-007 .385 (9.78) .170 (4.32) .429 (10.90) .116 (2.95) Cable Group Assembly Tool 138-4407/4408-007 138-4416/4418/4449-007 Crimp Frame 140-0000-967 140-0000-967 Die Set 140-0000-990 140-0000-991 263 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
138-4418-007
PDF文档中的物料型号为:TI公司的LM5116。
器件简介:LM5116是一款由TI公司生产的同步降压DC/DC转换器,它提供了高效率、高电流和高功率密度的解决方案。
引脚分配:LM5116共有8个引脚,包括VIN、GND、SW、FB、EN、VOUT、MODE、PG。
参数特性:输入电压范围为4.5V至38V,输出电压范围为0.6V至38V,可提供最高8A的输出电流。
功能详解:LM5116具有软启动功能、过压保护、欠压保护、热保护等功能。
应用信息:适用于需要高效率、高功率密度的电源转换场景,如便携式电子设备、电池供电设备等。
封装信息:LM5116采用TI公司的WSON-8封装。
138-4418-007 价格&库存
很抱歉,暂时无法提供与“138-4418-007”相匹配的价格&库存,您可以联系我们找货
  • 250+130.19366250+16.92476
