Ultra-Miniature Push-on Lock Coaxial Connectors for
Digital Broadcasting Applications
PL75 Series
75ø up to 3GHz
PL75 and PL71 Size Comparison
●Right-angle receptacles
[PL71]
14.9
9.2
7.2
Ø2.65
5
Ø3.95
[PL75]
9
4.5
Ø0.7
Ø0.7
[PL71]
14.4
6.7
[PL75]
13
14
5
9.3
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
●Right-angle plugs
Ø4.8
Features
Ø6.5
Mating Chart
1.Further reduction in size
The size is reduced by approximately 30% when
compared with PL71 Series, 75 Ohm connectors.
Low mounted profile: 5mm.
Fig.1
Plugs
Straight
PL75-P-1.5CV
2.Superior locking mechanism
Our exclusive locking method keeps the mating
par t in constant contact with the electr ic
reference plane (Top Touch), ensuring high
contact stability and reliability. The construction is
protected by the outer shell.
3.Reliable at high frequencies
The high-frequency performance of the PL75
S e r i e s i s v e r y r e l i a b l e , w i t h V. S . W. R .
characteristics of a maximum of 1.3 at DC, and
up to 3 GHz, which is suitable for 3G-SDI
broadcasting equipment.
Right-angle
PL75-LP-1.5CV
PL75-LP-1.5CW
4.Applicable cable: 1.5C type
By using together with Hirose's BNC(75) Series
connectors, 75ø total system lines from the
interface connections to the internal wiring
system is available.
Fig.2
5.RoHS compliant
All materials and substances used to produce
this product comply with RoHS standards.
Receptacle
Straight
PL75-R-PC
Right-angle
PL75-LR-PC
Fig.3
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2014.11w
1
PL75 Series●Ultra-Miniature Push-on Lock Coaxial Connectors for Digital Broadcasting Applications
Specifications
Nominal characteristic impedance
Frequency range
Ratings
Item
1. Insulation resistance
2. Withstanding voltage
3. Contact resistance
4. Center contact retention force
5. V.S.W.R. *
6. Vibration
7.Moisture resistance
: 75ø
: DC to 3 GHz
Operating temperature range
Operating humidity
:-30°C to +85°C
: RH 95% max.
Specification
1,000 Mø min.
No flashover or insulation breakdown
Center contact : 15 mø max.
Conditions
250 V DC
250 V AC / 1 minute
100 mA max.
Outer shell: 6 mø max.
0.2 N min.
1.3max.
No electrical discontinuity of 1 μs or longer
Measured with 0.3 mm diameter pin gauge
DC to 3 GHz
Frequency: 10 to 500 Hz, single amplitude of 0.75 mm,
No damage, cracks, or parts dislocation
Insulation resistance: 10 Mø min. (high humidity)
acceleration of 98m/s2, 2 hours in each of the 3 axis
Insulation resistance: 1,000 Mø min. (dry)
96 hours at +40ç and humidity of 90% to 95%
Contact resistance Center contact : 19 mø max.
8. Temperature cycle
Outer shell
: 10 mø max.
Temperature:-30ç ➝ +5ç to +35ç ➝ +85ç ➝ +5ç
to +35ç
Time: 30 min. ➝ 5 min.max. ➝ 30 min.➝ 5 min.max.
5 cycles
Contact resistance: Center contact : 19 mø max.
9. Durability
Outer shell
: 10 mø max.
No corrosion
10. Salt spray
500 cycles
5% salt water solution, 48 hours
* V.S.W.R. Measurement System
The above V.S.W.R. standard values were measured using the measurement system shown below.
Network Analyzer
Note 1: Cable connectors were measured with PL75 and
BNC(75) connectors connected with 10cm long coaxial cable.
Test Port Cable
D.U.T
Materials / Finishes
Plugs
Part
Shell
Male center contact
Female center contact
Insulator
Crimp sleeve
Material
Brass
Phosphor bronze
Beryllium copper
PTFE
Brass
Finish
Gold plated
Gold plated
Gold plated
--------------Nickel plated
Material
Brass
Phosphor bronze
Beryllium copper
PTFE
Finish
Gold plated
Gold plated
Gold plated
Receptacles
Part
Shell
Male center contact
Insulator
Ordering information
PL75 −
2
Series name :PL75
Connector type
P
:Straight plug
LP
:Right-angle plug
R
:Straight receptacle
LR
:Right-angle receptacle
Applicable cable (plug) or board mounting (receptacle) style
1.5CV
:1.5CCA-EXBV(LF)
1.5CW :1.5C-QEW.CW
PC :DIP mounting
Plugs
Straight
Ø4.8
16
HRS No.
Applicable cable
RoHS
PL75-P-1.5CV
334-0078-0
1.5CCA-EXBV(LF)
Yes
Right angle
13
9.3
5
Ø4.8
All dimensions: mm
Part No.
HRS No.
Applicable cable
PL75-LP-1.5CV
334-0076-4
1.5CCA-EXBV(LF)
PL75-LP-1.5CW
334-0080-1
1.5C-QEW.CW
RoHS
Yes
Receptacles
Straight
●PCB mounting pattern
5.8
3±0.05
1.5±0.05
Ø2.65
3±0.05
1.5±0.05
+0.1
Ø0.8
4∞
1
0.
+ 0
2.3
Ø1
Ø0.7
3
All dimensions: mm
Part No.
HRS No.
RoHS
PL75-R-PC
334-0081-4
Yes
Right angle
5
3±0.05
1.5±0.05
+0.1
Ø0.8
1
0.
+ 0
Ø1
4∞
3±0.05
1.5±0.05
4.5
Ø2.65
4.5
2.3
All dimensions: mm
Part No.
Ø0.7
3
All dimensions: mm
Part No.
HRS No.
RoHS
PL75-LR-PC
334-0075-1
Yes
3
High Frequency Characteristics of 75ø Hirose Products
2
BNC(75) Series
1.9
100
1.8
V.S.W.R.
1.7
1.6
1.5
1.4
1.3
BNC(75)-BPJ-1.5CV-※
BNC(75)-BPJ-1.5CV-※
1.2
1.1
1
1
1.5
2
2.5
3
2
2.5
3
2
2.5
3
2
2.5
3
Frequency[GHz]
PL71 Series
2
1.9
100
1.8
V.S.W.R.
1.7
1.6
1.5
1.4
1.3
BNC(75)-BPJ-1.5CV-※
PL71-LP-1.5C(40)
1.2
1.1
1
1
1.5
Frequency[GHz]
PL75 Series
2
1.9
100
1.8
V.S.W.R.
1.7
1.6
1.5
1.4
1.3
BNC(75)-BPJ-1.5CV-※
PL75-LP-1.5CV
1.2
1.1
1
1
1.5
Frequency[GHz]
H.FL75 Series
2
1.9
1.8
H.FL75-2LPG-084N※-L
V.S.W.R.
1.7
100
1.6
1.5
1.4
1.3
1.2
1.1
BNC(75)J-H.FLJ-BPA(40)
1
1
1.5
Frequency[GHz]
4
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 11/2014. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“PL75-LR-PC”相匹配的价格&库存,您可以联系我们找货
