142-5701-501
142-5701-501
    CINCH
    SMA
142-5701-501 数据手册
SMA 50 Ohm - Reverse Thread Right Angle Bulkhead Jack Receptacle GOLD PLATED NICKEL PLATED 142-5701-501 142-5701-506 INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST Mounting hole layouts Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com SMA Reverse Thread - 50 Ohm Specifications INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST ELECTRICAL RATINGS Impedance: 50 ohms Frequency Range: Flexible cable connectors ..................................................... 0-12.4 GHz Uncabled receptacles ........................................................... 0-18.0 GHz VSWR: (f = GHz) Straight Right Angle Cabled Connectors Cabled Connectors RG-316, LMR-100 cable ........... 1.15 + .02f 1.15 + .03f RG-58, LMR-195 cable ............. 1.15 + .01f 1.15 + .02f RG-142 cable ............................ 1.15 + .01f 1.15 + .02f LMR-200, LMR-240 cable ............. 1.10 + .03f 1.10 + .06f Uncabled receptacles .......................................................................... N/A Working Voltage: (Vrms maximum)† Connectors for Cable Type Sea Level 70K Feet RG-316; LMR-100, 195, 200 ........................................... 250 65 RG-58, RG-142, LMR-240, uncabled receptacles .... 335 8 Dielectric Withstanding Voltage: (VRMS minimum at sea level)† Connectors for RG-316; LMR-100, 195, 200 ...................................... 750 Connectors for RG-58, RG-142, LMR-240, uncabled receptacles .. 1000 Corona Level: (Volts minimum at 70,000 feet)† Connectors for RG-316, LMR-100, 195, 200 ................................... 190 Connectors for RG-58, RG-142, LMR-240, uncabled receptacles ... 250 Insertion Loss: (dB maximum) Straight flexible cable connectors ................................ .06 f (GHz), tested at 6 GHz Right angle flexible cable connectors ................................ 0.15 f (GHz), tested at 6 GHz Low loss flexible straight cable connectors ............................. 0.06 f (GHz), tested at 1 GHz Low loss flexible right angle cable connectors ............................. 0.15 f (GHz), tested at 1 GHz Uncabled receptacles, field replaceable ...................................... N/A Insulation Resistance: 5000 megohms minimum Contact Resistance: (milliohms maximum) After Initial Environmental Center contact (straight cabled connectors and uncabled receptacles) ............................ 3.0* 4.0* Center contact (right angle cabled connectors ...................................................... 4.0 6.0 Outer contact (all connectors) ............................ 2.0 N/A Braid to body (gold plated connectors) .............. 0.5 N/A Braid to body (nickel plated connectors) ............ 5.0 N/A RF Leakage: (dB minimum, tested at 2.5 GHz) Flexible cable connectors ............................................................. -60 dB Uncabled receptacles and adapters ................................................. N/A RF High Potential Withstanding Voltage: (Vrms minimum, tested at 4 and 7 MHz)† Connectors for RG-316; LMR-100, 195, 200 ................................... 500 Connectors for RG-58, RG-142, LMR-240, uncabled receptacles ... 670 MECHANICAL RATINGS Engagement Design: MIL-C-39012, Series SMA Engagement/Disengagement Force: 2 inch-pounds maximum Mating Torque: 7 to 10 inch-pounds Bulkhead Mounting Nut Torque: 15 inch-pounds Coupling Proof Torque: 15 inch-pounds minimum Coupling Nut Retention: 60 pounds minimum Contact Retention: 6 lbs. minimum axial force (captivated contacts) 4 inch-ounce minimum torque (uncabled receptacles) Cable Retention: Axial Force* Torque (pounds) (in-oz) Connectors for RG-316, LMR-100 ............ 20 N/A Connectors for LMR-195, 200 ................... 30 N/A Connectors for RG-58; LMR-240 .............. 40 N/A Connectors for RG-142 ............................. 45 N/A *Or cable breaking strength whichever is less. Durability: 500 cycles minimum ENVIRONMENTAL RATINGS (Meets or exceed the applicable paragraph of MIL-C-39012) Temperature Range: - 65° C to + 165° C Thermal Shock: MIL-STD-202, Method 107, Condition B Corrosion: MIL-STD-202, Method 101, Condition B Shock: MIL-STD-202, Method 213, Condition I Vibration: MIL-STD-202, Method 204, Condition D Moisture Resistance: MIL-STD-202, Method 106 MATERIAL SPECIFICATIONS Bodies: Brass per QQ-B-626, gold plated* per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Contacts: Male - brass per QQ-B-626, gold plated per MIL-G-45204 .00003" min. Female - beryllium copper per QQ-C-530, gold plated per MILG-45204 .00003" min. Nut Retention Spring: Beryllium copper per QQ-C-533. Unplated Insulators: PTFE fluorocarbon per ASTM D 1710 and ASTM D 1457 or Tefzel per ASTM D 3159 Expansion Caps: Brass per QQ-B-613, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Crimp Sleeves: Copper per WW-T-799 or brass per QQ-B-613, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Mounting Hardware: Brass per QQ-B-626 or QQ-B-613, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Mating Engagement for SMA Reverse Thread Series per FCC Rule 15 Non-Standard Interface PLUG JACK †Avoid user injury due to misapplication. See safety advisory definitions inside front cover. NOTES 1. ID OF CONTACT TO MEET VSWR, CONTACT RESISTANCE AND INSERTION WITHDRAWAL FORCES WHEN MATED WITH DIA .0355-.0370 MALE PIN. JACK PLUG Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
142-5701-501 价格&库存
很抱歉,暂时无法提供与“142-5701-501”相匹配的价格&库存,您可以联系我们找货
