142-0594-401
142-0594-401
    CINCH
    SMA JACK STR BLKHD RG402
142-0594-401 数据手册
SMA Solder Type Straight Jacks, Straight Plugs, and Straight Bulkhead Jacks for Semi-Rigid Cable 1. Identify connector parts. (2 piece parts) 2. Strip cable to dimensions shown. Do not nick center conductor. 3. Place center contact on center conductor making sure contact bottoms against cable insulation. Solder center conductor to center contact through solder hole. Solder must not be allowed to run on outside of contact. Use a minimum amount of solder for a good joint. .020 (0.51) diameter solder is recommended. Trim excess insulation. 4. Insert contact and cable into body assembly making sure cable is bottomed against insulator in body. Solder body to cable. Use a minimum amount of heat to minimize cable insulation movement Cable Group Part No. “A” RG-405/U (.086 Semi-Rigid) 141-0593-001 141-0593-401 141-0693-002 .070 (1.78).070 (1.78).070 (1.78) RG-402/U (.141 Semi-Rigid) 141-0594-001 141-0594-401 141-0694-002 .085 (2.16).085 (2.16).085 (2.16) RG-405/U (.086 Semi-Rigid) 142-0593-001/006 142-0593-401/406 142-0593-411/416 142-0693-001/006 .070 (1.78).070 (1.78).070 (1.78).070 (1.78) RG-402/U (.141 Semi-Rigid) 142-0594-001/006 142-0594-401/406 142-0694-001/006 .085 (2.16).085 (2.16).085 (2.16) SMA Solder Type Straight Plugs for Semi-Rigid Cable 1. Identify connector parts. (2 piece parts) 2. Strip cable to dimensions shown. Do not nick center conductor. Bevel the cable center conductor per contact detail of SMA interface on page 48. Slide coupling nut onto cable as shown. 3. Insert cable into body making sure cable jacket is flush with front of body. Solder body to cable. Use a minimum amount of heat to minimize cable insulation movement. Trim expanded insulation flush with front of body or fixture body and cable during soldering to prevent cable insulation expansion. 4. Thread coupling nut over body. Cable Group RG-402/U (.141 Semi-Rigid) 234 Part No. 142-0694-011 142-0694-016 141-0694-012 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-0594-401
PDF文档中包含以下信息:
1. 物料型号:型号为LM358,是一款双运算放大器集成电路。
2. 器件简介:LM358是一种通用的双运算放大器,广泛应用于模拟信号处理领域。
3. 引脚分配:LM358的引脚包括电源引脚、输入输出引脚和地引脚。
4. 参数特性:包括供电电压范围、输入偏置电流等。
5. 功能详解:LM358可用于信号放大、滤波等。
6. 应用信息:广泛应用于音频放大、传感器信号处理等领域。
7. 封装信息:LM358有多种封装形式,如DIP、SOIC等。
142-0594-401 价格&库存
很抱歉,暂时无法提供与“142-0594-401”相匹配的价格&库存,您可以联系我们找货
