142-0107-401
142-0107-401
    CINCH
    SMA
142-0107-401 数据手册
SMA Clamp Type Straight Plugs, Straight Jacks, and Straight Bulkhead Jacks for Flexible Cable 1. Identify connector parts. (6 piece parts – except bulkhead) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin (optional). Slide clamp nut and clamp cone onto cable as shown. Clamp cone must be oriented as shown for each size of cable. The RG58/142 clamp cone slides over braid and against jacket. 3. Flare braid and slide cable into clamp stem. Place rear insulator and center contact over center conductor and position as shown for different cable sizes. Solder center conductor to contact through the solder hole. Solder must not be allowed to gather and run on outside of contact. Use a minimum amount of solder for a good joint. .020 (0.51) diameter solder is recommended. 4. Arrange braid uniformly around clamp stem. Slide center contact assembly into body. Slide clamp nut against clamp cone and braid and tighten to 10 in.-lb. torque. Cable Group Part No. “A” “B” “C” RG-178/U, 196 142-0202-011/016 .133 (3.38) .053 (1.35) .085 (2.16) RG-161/U, 174,188, 316 142-0203-011/016 .133 (3.38) .053 (1.35) .085 (2.16) RG-58/U, 141, 303 142-0207-011/016 .225 (5.72) .145 (3.68) NONE RG-142, 223, 55, 400 142-0207-011/016 .285 (7.24) .165 (4.19) NONE RG-178/U, 196 142-0102-401/406 .133 (3.38) .053 (1.35) .085 (2.16) RG-161/U, 174,188, 316 142-0103-401/406 .133 (3.38) .053 (1.35) .085 (2.16) RG-58/U, 141, 303 142-0107-401/406 .225 (5.72) .145 (3.68) NONE RG-142, 223, 55, 400 142-0107-401/406 .285 (7.24) .165 (4.19) NONE 250 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-0107-401 价格&库存
很抱歉,暂时无法提供与“142-0107-401”相匹配的价格&库存,您可以联系我们找货
  • 250+340.97630250+44.16836
