SF1211-66114
SF1211-66114
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPPLUGSTR50OHMSOLDER
SF1211-66114 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING .080 2.03 REVISION HISTORY DESCRIPTION DATE APPROVED - DCN 37958 01/11 STW A DCN 41036 01/15 STW B REV. DCN 41783 10/19/15 STW REV .192 4.88 .110±.002 2.79±0.05 RP .045 1.14 SCREWDRVER SLOT .065 1.65 .018 0.46 .057 1.45 10-48 UNS-2A .025 MAX 0.64 MAX TO FULL THD. .162 MIN 4.11 MIN MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B BUSHING: BRASS PER ASTM B16, ALLOY UNS No. C36000 .059±.001 1.50±0.03 10-48 UNS-2B FINISH: BODY: PASSIVATED PER AMS-2700 CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. BUSHING: NICKEL PER AMS-QQ-N-290, CLASS 2 PERFORMANCE: IMPEDANCE: FREQ. RANGE: .080 2.03 RECOMMENDED MOUNTING HOLE MATERIAL: FINISH: 50 OHMS DC TO 40.0 GHz .192±.002 4.88±0.05 SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FED 01/17/11 CHECKED: APPROVED: STW 01/17/11 STW 01/17/11 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP SB MALE THREAD-IN SIZE CAGE CODE DWG. NO. B 95077 SCALE: 10:1 SF1211-66114 SHEET 1 OF 1
SF1211-66114 价格&库存
很抱歉,暂时无法提供与“SF1211-66114”相匹配的价格&库存,您可以联系我们找货
