SMB Non-Magnetic RF Connectors
PC Mount
INCHES (MILLIMETERS)
CUSTOMER DRAWINGS AVAILABLE UPON REQUEST
Right Angle Jack Receptacle
GOLD PLATED
131-9701-301
SPECIFICAITONS
ELECTRICAL RATINGS
Impedance: 50 ohms
Frequency Range: 0-4 GHz
VSWR: (f = GHz)
Straight
Right Angle
Cabled
Cabled
RG-316 .................................................................. 1.25 + .04f
1.35 + .04f
Uncabled receptacles .................................................. N/A
Working Voltage: (Vrms maximum)
Connectors for Cable Type
Sea Level
70K Feet
RG-316, uncabled connectors ......................... 335
85
Dielectric Withstanding Voltage: (VRMS minimum at sea level)
Connectors for RG-316, uncabled receptacles .......................................... 1000
Corona Level: (Volts minimum at 70,000 feet)
Connectors for RG-316 ................................................................................ 250
Uncabled receptacles ................................................................................... N/A
Insertion Loss: (dB maximum, tested at 1.5 GHz)
Straight cable connectors ....................................................................... 0.30 dB
Right angle cable connectors ................................................................. 0.60 dB
Insulation Resistance: 1000 megohms minimum
Contact Resistance: (milliohms maximum)
Initial After Environmental
Center contact (straight cabled connectors
and uncabled receptacles) ....................................... 6.0
8.0
Center contact (right angle cabled connectors ........... 12.0
16.0
Outer contact (gold plated connectors) ........................ 1.0
1.5
Braid to body (gold plated connectors) ........................ 1.0
N/A
RF Leakage: (dB minimum tested at 2.5 GHz)
Cable connectors ...................................................................................... -55 dB
Uncabled receptacles .................................................................................... N/A
RF High Potential Withstanding Voltage: (Vrms minimum, tested at 4 and 7 MHz)
Connectors for RG-316 ................................................................................ 700
Uncabled receptacles ................................................................................... 600
Power Rating (Dummy Load): 0.5 watt @ +25oC, derated to 0.25 watt @ +125o C
MECHANICAL RATINGS
Engagement Design: MIL-STD-348, Series SMB
Engagement/Disengagment Force: 2 pounds min to 14 pounds maximum axial
force
Contact Retention: 4 lbs. min axial force (captivated contacts)
1 inch-ounce min torque (uncabled receptacles)
Cable Retention:
Axial Force*
Torque
(pounds)
(in-oz)
N/A
*or cable breaking strength whichever is less.
Durability: 500 cycles minimum
ENVIRONMENTAL RATINGS
(Meets or exceed the applicable paragraph of MIL-PRF-39012)
Temperature Range: - 65oC to + 165oC
Thermal Shock: MIL-STD-202, Method 107, Condition B
Corrosion: MIL-STD-202, Method 101, Condition B
Shock: MIL-STD-202, Method 213, Condition B
Vibration: MIL-STD-202, Method 204, Condition B
Cinch Connectivity Solutions
299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
1
很抱歉,暂时无法提供与“131-9701-301”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+261.191631+33.88940
- 10+221.9979610+28.80405
- 25+208.1023625+27.00111
- 50+198.1731550+25.71281
- 100+188.72082100+24.48637
- 250+176.91949250+22.95516
- 500+168.48682500+21.86103
