134-0307-406
134-0307-406
    CINCH
134-0307-406 数据手册
Type N Crimp Type Bulkhead Jack for Flexible Cable 1. Identify connector parts. (6 piece parts) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into a tight bundle and tin (optional). Slide crimp sleeve onto cable as shown. 3. Flare body and slide cable into crimp stem of rear body subassembly, until cable dielectric bottoms out on center contact. Solder center conductor to contact through the solder hole. Solder must not be allowed to gather and run on outside of contact. Use a minimum amount of solder for a good joint. .020 (0.51) diameter solder is recommended. 4. Arrange braid uniformly around crimp stem. Slide crimp sleeve over braid and crimp securely using recommended crimp tool. Slide insulator over center conductor and slide center contact assembly into connector body. Thread rear body subassembly into body and tighten securely (ref. 30 in-lbs torque.) Cable Group Part No. Crimp Hex RG-316/U, 161, 174, 188 134-0303-406 .160 (4.06) RG-316 DS, 188 DS 134-0304-406 .160 (4.06) RG-58/U, 141, 303 134-0307-406 .213 (5.41) RG-55/U, 142, 223, 400 134-0308-406 .213 (5.41) 259 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
134-0307-406 价格&库存
很抱歉,暂时无法提供与“134-0307-406”相匹配的价格&库存,您可以联系我们找货
    • 250+208.06360250+27.05400
