131-9403-001
131-9403-001
    CINCH
    SMB Connector Plug, Female Socket 50 Ohm Free Hanging (In-Line) Crimp or Solder
131-9403-001 数据手册
SMB Straight Crimp Type Straight Plugs for Flexible Cable 1. Identify connector parts. (2 piece parts) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin. Slide crimp sleeve onto cable as shown. 3. Flare braid and slide cable into body making certain that the cable dielectric bottoms against center contact. Solder Attachment: Solder center conductor to contact through the side access ports and hole in center contact. Use a minimum amount of solder for a full fillet joint. .020 (0.51) diameter solder is recommended. Crimp Attachment: Crimp contacts with 141-0000-911 dieset in 144-0000-900 tool frame. Cable Group Part No. Crimp Hex RG-316/U, 188, 174, 179, 187 131-9403-001 .128 (3.25) RG-316 DS, 188 DS, 179 DS, 187 DS 131-9404-001 .151 (3.83) 255 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
131-9403-001 价格&库存
很抱歉,暂时无法提供与“131-9403-001”相匹配的价格&库存,您可以联系我们找货
