Straight SMA Low Loss Diameter .195, .200 and .240 Straight Type Plugs
1. Identify connector parts. (3 piece parts – except bulkhead)
2. Strip cable to dimensions shown. Do not nick braid, foil
or center conductor. Cut foil flush with dielectric, do not
remove foil. Make sure that dielectric is clean and free from
all particles. Tin center conductor, keeping solder amount
to a minimum. Slide crimp sleeve onto jacket of cable.
3. Assemble contact onto cable as shown. Position contact
such that a gap of no more than .020 (0.51) is kept between
dielectric and contact. Solder contact to center conductor
through solder hole using .020 (0.51) Diameter solder. Use
a minimum amount of solder for a good joint. Do not allow
contact to move into dielectric during soldering process.
4. Flare braid and slide body assembly over contact, foil and
dielectric, then under braid. Seat body assembly firmly onto
contact. Arrange braid uniformly around crimp stem. Slide
crimp sleeve forward and crimp using Johnson hand crimp
tool 141-0000-913 and recommended crimp die hex.
Cable Group
Part No.
Crimp Hex
LMR-195
142-0307-411
142-0307-416
.213 (5.41).213 (5.41)
LMR-240
142-0335-401
142-0335-406
.255 (6.48).255 (6.48)
LMR-200
142-0339-401
142-0339-406
LMR-195
142-0407-011
142-0407-016
LMR-240
142-0435-001
142-0435-006
LMR-200
142-0439-001
142-0439-006
LMR-240
142-4435-001
142-4435-006
LMR-200
142-4439-001
142-4439-006
LMR-195
142-4407-001
142-4407-006
LMR-240
142-5435-001
142-5435-006
LMR-200
142-5439-001
142-5439-006
LMR-195
142-5407-001
142-5407-006
240
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“142-5435-006”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+148.71148250+19.24916
