SMB Straight Crimp Type Straight Plugs for Flexible Cable
1. Identify connector parts. (2 piece parts)
2. Strip cable to dimensions shown. Do not nick braid or center
conductor. A wire stripper of correct size is recommended for
this step. Twist stranded center conductor into tight bundle
and tin. Slide crimp sleeve onto cable as shown.
3. Flare braid and slide cable into body making certain that
the cable dielectric bottoms against center contact. Solder
Attachment: Solder center conductor to contact through the
side access ports and hole in center contact. Use a minimum
amount of solder for a full fillet joint. .020 (0.51) diameter
solder is recommended. Crimp Attachment: Crimp contacts
with 141-0000-911 dieset in 144-0000-900 tool frame.
Cable Group
Part No.
Crimp Hex
RG-316/U, 188, 174, 179, 187
131-9403-001
.128 (3.25)
RG-316 DS, 188 DS, 179 DS, 187 DS
131-9404-001
.151 (3.83)
255
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“131-9404-001”相匹配的价格&库存,您可以联系我们找货
