ERA.00.250.CLL
ERA.00.250.CLL
    LEMO(雷莫)
    ERA.00.250.CLL
ERA.00.250.CLL 数据手册
ERA.00.250.CLL www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Female solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.00.250.CLAC15Z Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ERA*: Fixed receptacle, nut fixing Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 2.50 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 VSWR: 1.09 + 0.11 * f/GHz Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A B E L M S1 S3 e mm. 8 10.3 5.5 15 1 6.3 9 M7x0.5 in. 0,31 0,41 0,22 0,59 0,04 0,25 0,35 RECOMMENDED BY LEMO Tools Cables 159580 PVC Black 17420 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 17450 COPOLYMER Black 178190 PTFE Brown 18000 PTFE Brown 18700 PTFE White 18800 PTFE White 196270 PTFE White 31600 PTFE Brown 62000 PVC Black CCX.50.030.083.180B White CCX.50.RG0.58AU14B FEP White CCX.50.RG1.74-U25N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74U25N PVC Black CCX.50.RG1.78BU18M FEP Brown CCX.50.RG1.78BU18M PTFE Brown CCX.50.RG1.88AU24B TFE White CCX.50.RG1.88AU26B PFA White CCX.50.RG1.88AU26B PTFE White CCX.50.RG1.96AU19B PTFE White CCX.50.RG1.96AU20B PFA White CCX.50.RG3.16BU26M FEP Brown CCX.50.RG3.16U28M PTFE Brown CCX.75.040.195327G PVC Grey CCX.75.RG0.59BU62N PVC Black CCX.75.RG1.79BU26M FEP Brown CCX.75.RG1.87AU26B PFA White CCX.75.RG1.87AU27B PTFE White CCX.93.RG0.62AU62N PVC Black CCX.95.RG1.80BU36M PTFE Brown CCX.95.RG1.95AU37B PFA White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ERA.00.250.CLL 价格&库存
很抱歉,暂时无法提供与“ERA.00.250.CLL”相匹配的价格&库存,您可以联系我们找货
