Type N Straight Plug One Piece Style for Semi-Rigid Cable
1. Identify connector and tools. (4 piece parts)
2. Strip cable jacket and dielectric to dimension shown. Do
not nick center conductor.
3. Bevel end of cable center conductor per appropriate
dimensional profile.
4. Clean all debris from prepared cable and insert cable into
connector assembly, making sure cable jacket bottoms out
against internal shoulder of connector assembly and center
conductor engages with internal captivated plug contact.
5. Insert location fixture into connector assembly and clamp
cable in vise. Tighten stop screw until light pressure is
applied between connector assembly and cable jacket. 6.
Solder connector body to cable jacket, using a minimum
amount of solder for a full fillet joint. Allow assembly to cool
before removing connector from vise.
Cable Group
Part No.
“A”
“B”
RG-405, .086 Semi-Rigid
138-4693-011
.085 (2.16)
.014 (0.36)
RG-402, .141 Semi-Rigid
138-4694-011
.085 (2.16)
.022 (0.56)
RG-401, .250 Semi-Rigid
138-4696-011
.150 (3.81)
.045 (1.14)
Assembly
Location Fixture
140-0000-983
140-0000-983
140-0000-983
Cable Vise
140-0000-962
140-0000-962
140-0000-962
Clamp Inserts
140-0000-964
140-0000-965
140-0000-986
Stop Screw
140-0000-981
140-0000-981
140-0000-981
267
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“138-4696-011”相匹配的价格&库存,您可以联系我们找货
