UG-58A/U(40)
UG-58A/U(40)
    HRS(广濑)
    CONN N JACK STR 50OHM SOLDER
UG-58A/U(40) 数据手册
N type Coaxial Connectors N Series ■Features 1. 50 ohms wide varieties standard connectors 2. Screw on locking 3. Applicable cable : RG cable, JIS cable 4. Applicable standard : MIL-C-39012/MIL STD 348-304 ■Functional diagram Plugs Straight plug for flexible cable UG-21D/U(40) Straight plug for semi-rigid cable N-P-141(40) Jacks In-line adapters Right angled jack-plug type UG-27C/U(40) T-type adapter Jack-plug-jack type Straight jack for flexible cable UG-23D/U(40) Panel mount jack for flexible cable N-PJ-58/U(40) UG-107B/U(40) Right angled plug for flexible cable N-LP-5DW(40),N-LP-58U(40) Fixed attenuator Plug-jack type Panel mount straight receptacle UG-58A/U(40) AT-4** Conversion adapters BNC series conversion type M series conversion type S series conversion type SMA(HRM series) conversion type Conversion adapters In-line adapters Straight plug-plug type UG-57B/U(40) BNC series conversion type M series conversion type TNC series conversion type SMA(HRM series) conversion type Cap with a chain MX-913/U(40) In-line adapters Straight jack-jack type UG-29B/U(40) Non-reflective Terminators N-TMP-* Panel mount adapter Jack-jack type N-PA(40) T-type adapter Jack-jack type UG-28A/U(40) 2014.11w 1 N Series●N type Coaxial Connectors ■Product Specifications Nominal characteristic impedance Frequency range Ratings Item 50 ohms DC to 2 GHz Operating temperature range Operating humidity Specification -30˚C to +60˚C 95%RH max. Conditions 1. Contact resistance 3 m ø max. 100 mA max. 2. Insulation resistance 1000 M ø min. 500 V DC 3. Withstanding voltage No flashover or insulation breakdown. 1500 V AC / 1 minute 4. V.S.W.R.* 1.2 max. Up to 2GHz 10 m ø max. 500 cycles No electrical discontinuity of 1µs min. Frequency: 10 to 500 Hz, single amplitude of 0.75mm, acceleration of 98m/s2, for 10 cycles in the direction of each of the 3 axis. 5. Durability (mating / un-mating, with corresponding plug) 6. Vibration No damage, cracks or parts dislocation. Acceleration of 490 m/s 2, 11ms duration, sine half-wave waveform, 3 cycles in each of 3 axes. No damage, cracks or parts dislocation. 96 hours at temperature of 40ç and humidity of 80% to 96%. 9. Temperature cycle No damage, cracks or parts dislocation. Time: 10. Salt spray No excessive corrosion 7. Shock 8. Humidity (Steady state) Temperature: -55˚C/+25 to +65˚C/+85˚C/+5 to +35˚C 30min. / 5min. /30min./ 5min. 5 cycles 5% salt water solution, 48 hours *V.S.W.R. Measurement System The above V.S.W.R. standard values were measured using the measurement connection as shown below. Network Analyzer Test Set Test Port D.U.T Termination Test Port Cable Note 1: Connectors with cable are measured with 10 cm of suitable cable attached at both ends. ■Material Part Material Finish Remark Shell Brass Silver plated/Nickel plated –––––– Male contact Brass Silver plated/Gold plated –––––– Female contact Beryllium copper Silver plated/Gold plated –––––– Insulator Tetrafluoride resin –––––– Flame retardant Packing Silicone rubber –––––– Flame retardant ■Ordering information ●Product with MIL standard ●Standard N - L P - 5DW 1 1 2 2 3 Series name : N Connector style Blank : Straight type : L angle type L : T angle type T 3 4 2 UG - 21 D /U 4 1 Connector type P : Plug J : Jack PJ : Panel jack R : Receptacle A : Adapter PA : Panel adapter Applicable cable 2 3 1 1 High freguency coaxial connectors 2 Product identification number 3 Improved sign N Series●N type Coaxial Connectors ■Straight Plug Ø20.8 5/8-24UNEF-2B ØD Ød ●Flexible cable type L Unit : mm Part No. Packaging ØD Ød L UG-21D/U(40) 301-0003-0 40 HRS No. RG-8/U,RG-9/U 11.1 19.0 38.0 JUG-536/U(40) 301-0001-4 40 RG-58/U 5.4 19.0 38.0 N-P-3DV(40) 301-0078-9 40 3D-2V 6.3 12.7 35.0 N-P-5DV(40) 301-0120-3 40 5D-2V 8.6 18.0 45.5 N-P-5DW(40) 301-0199-3 40 5D-2W 9.3 18.0 46.0 N-P-5DFB(40) 301-0205-4 40 5D-FB 8.6 18.0 46.0 N-P-10DFB(40) 301-0206-7 40 10D-FB 14.5 23.0 55.0 1 Applicable cable Ød ØD 5/8-24UNEF-2B Ø20.8 ●Semi rigid cable type L Unit : mm Packaging HRS No. 301-0162-3 40 N-P-141-2(A)(40) 301-0262-8 40 N-P-250(A)(41) 301-0261-5 41 1 Applicable cable ØD Ød L UT-141A 3.63 13 27.3 UT-141A 3.63 5 25.7 UT-250 6.5 14 34.9 34 5/8-24UNEF-2B ■Right angle plug L ●Flexible cable type Ø20.8 Part No. N-P-141(40) ØD Ød Unit : mm Part No. HRS No. N-LP-5DW(40) 301-0007-0 40 N-LP-58U(40) 301-0076-3 40 Packaging Applicable cable 1 ØD Ød L Remarks 5D-2W 9.3 17.5 52.4 Nickel-plated ecxept for center conductor RG-58/U 5.3 15.5 44.0 -------------- 3 N Series●N type Coaxial Connectors ■Straight jack ●Flexible cable type 34.8 Ø5.8 Ø15.8 Ø3.2 ØD 20.8 5/8-24UNEF-2A Unit : mm Packaging Applicable cable ØD 301-0180-5 40 1 3D-2V 5.1 Ø11.1 5/8-24UNEF-2A N-J-3DV(40) HRS No. Ø19.7 Part No. 39.7 Part No. HRS No. Packaging Applicable cable UG-23D/U(40) 301-0008-3 40 1 RG-8/U,RG-9/U ■Panel mount jack ØD 16.7 4∞Ø3.2 L Part No. HRS No. Packaging Applicable cable UG-22D/U(40) 301-0010-5 40 N-PJ-58/U(40) 301-0011-8 40 1 ØD Ød L Unit : mm S RG-8/U,RG-9/U 11.1 19.0 39.7 18.24 5.4 14.6 41.5 RG-58/U Ø14.7 5/8-24UNEF-2A 18.24 25.4 ■Receptacle 16.7 4∞Ø3.2 4 Ød 5/8-24UNEF-2A S 25.4 ●Fexible cable type 28 Part No. HRS No. Packaging UG-58A/U(40) 301-0012-0 40 1 18.2 N Series●N type Coaxial Connectors ■Straight plug(waterproof type) Ød ØD Ø23.3 5/8-24UNEF-2B L スパナ幅16 Spanner width 16 21HEX Unit : mm Part No. HRS No. N-P-5DFXL(41) 301-0235-5 41 N-P-8DGXC(40) 301-0228-0 40 Packaging 1 Applicable cable ØD Ød L 5D-FXL 8.6 18 47.2 8D-GXC 11.6 19.5 49.9 * IP67 compliant ■Straight jack(waterproof type) ØD Ød L 5 /8 - 2 4 U N F - 2 A Spanner width 18 Spanner width 16 Unit : mm Part No. HRS No. N-J-5DFXL(40) 301-0237-0 40 N-J-8DGXC(40) 301-0229-2 40 Packaging 1 Applicable cable ØD Ød L 5D-FXL 8.6 18 49.1 8D-GXC 11.6 19.5 51.9 * IP67 compliant 5 N Series●N type Coaxial Connectors Ø16.7 5/8-24UNEF-2A ●Straight adapter (jack-jack type) 5/8-24UNEF-2A ■Adapter 44.5 HRS No. Packaging 301-0035-6 40 1 Part No. UG-29B/U(40) 5/8-24UNEF-2B 5/8-24UNEF-2B Ø20.8 (Plug-plug type) 40.6 HRS No. Packaging 301-0018-7 40 1 Part No. UG-57B/U(40) 16.7 2 45 4∞Ø3.2 HRS No. Packaging 301-0036-9 40 1 Part No. N-PA(40) ●Right angle adapter (Plug-jack type) 33 5/8-24UNEF-2A 35.5 5/8-24UNEF-2B Ø20.8 Part No. UG-27C/U(40) 6 HRS No. Packaging 301-0015-9 40 1 25.4 18.2 Ø16.5 5/8-24UNEF-2A 5/8-24UNEF-2A ●Panel mount adaper (jack-jack type) N Series●N type Coaxial Connectors ●T-shaped adapter (Jack-jack-jack type) 5/8-24UNEF-2A 31 5/8-24UNEF-2A 5/8-24UNEF-2A 44.4 (Jack-plug-jack) Part No. HRS No. Packaging UG-28A/U(40) 301-0017-4 40 1 Part No. HRS No. Packaging UG-107B/U(40) 301-0016-1 40 1 37.7 5/8-24UNEF-2A 5/8-24UNEF-2A 44.4 5/8-24UNEF-2B Ø20.8 ■Conversion adapters Plug N Mating portion 2 Series name Mating portion Plug BNC Jack Jack M Jack S Plug SMA (HRM) Jack Plug BNC Jack Plug Jack Plug M Jack TNC SMA (HRM) Plug Jack Part No. HRS No. Packaging NP-BNCP(40) JUG-201A/U(40) NP-MJ(40) N.P-S.J(40) HRM-555S(40) HRM-554S(40) UG-349/U(40) NJ-BNCJ(40) NJ-BNCJ-PA(40) NJ-MP(40) NJ-MJ(40) N.J-TNC.P(40) HRM-553S HRM-557SV HRM-552S HRM-556SV 311-0050-7 40 311-0007-8 40 311-0019-7 40 311-0245-6 40 311-0125-4 40 311-0123-9 40 311-0004-0 40 311-0005-2 40 311-0014-3 40 311-0018-4 40 311-0011-5 40 311-0225-9 40 311-0121-3 311-0272-9 311-0119-1 311-0298-2 1 ■Cap 57 With a chain Ø3.2 14 Mating portion 1 Series name Mating portion Ø3.66 Part No. HRS No. Packaging 5/8-24UNEF-2B MX-913/U(40) 301-0020-9 40 1 Ø19.1 7 N Series●N type Coaxial Connectors BCable assembly procedure L1 - 00.5 Insulater The cable ends are processed as shown in the drawing. For the dimensions L1, refer to Table 1, which shows dimansions arranged L by part number. Tightener Gasket Jacket (L3) Outer conductor Center conductor L2±0.1 Surface A Soldered Male or female contact Gasket Clamp (1) Insert clamp from tip of cable and fold outer conductor of cable back onto clamp. Using a knife, cut off excess outar conductor left at this time. (2) Cut off center conductor of cable at L2, from surface A of cable insulation. For dimensions of L2 and L3, refer to Table 1. L3 is a reference dimension. (3) Solder cable center conductor and male contact (or female contact). It is a good idea st this time to solder the contact preliminarily in advance. (Note: There must be no gap between the contact and the cable insulation.) Insert cable and parts into shell and fit sharp end of clamp completely into V-shaped surface of gasket. Tighten tightening nut sufficiently. ■Remarks Nut Gasket 1. The cable dimensions L are based on the MIL and DSP standards. They may differ somewhat depending on the type of cable. In such cases, match the dimensions with the connectors. 2. S o m e c l a m p s a n d g a s k e t s d o e s n o t h a v e n o t V-shaped, but the assembling procedures are the same. Clamp Table 1 Dimensions L arranged by part number Unit : mm 8 Part No. HRS No. 0 L1   −0.5 JUG-536/U(40) 301-0001-4 40 8.6 6 UG-21D/U(40) 301-0003-0 40 10.0 6 1 N-LP-5DW(40) 301-0007-0 40 11.5 4 3.5 UG-23D/U(40) 301-0008-3 40 8.5 5 1 UG-22D/U(40) 301-0010-5 40 8.5 5 1 N-PJ-58/U(40) 301-0011-8 40 7.4 3 3.2 N-LP-58U(40) 301-0076-3 40 9.2 4 3.6 N-P-3DV(40) 301-0078-9 40 12.3 6 4.8 N-P-5DV(40) 301-0120-3 40 11.1 6 1.5 N-P-5DW(40) 301-0199-3 40 12.0 6 1.5 N-P-5DFB(40) 301-0205-4 40 11.0 6 5 N-P-10DFB(40) 301-0206-7 40 11.0 6 5 L2±0.1 L3 1 N Series●N type Coaxial Connectors ■Non-reflective Terminators(Coupling portion plug) Part No. N-TMP-1-1(50) V.S.W.R.(Max) Frequency range (GHz) DC~4GHz 4~6GHz 6~8GHz DC~8 353-0137-5 50 1.10 1.15 1.20 HRS No. Ø20.8 Ø11 5/8-24NEF-2B 34 Power (W) 1 Weight (g) 59 Packaging 1 2-M3∞0.5 Depth (Vote:Mounting screw hole) Part No. N-TMP-5(40) HRS No. 353-0033-0 40 Frequency range (GHz) DC~6 V.S.W.R.(Max) DC~2GHz 2~6GHz 1.15 1.20 Ø20.8 5/8-24NEF-2B 15 Ø32 68.5 Power (W) 5 Weight (g) 113 Packaging 1 9 N Series●N type Coaxial Connectors ■Fixed Attenuators(plug-jack) 5/8-24NEF-2A Ø20.8 Part No. HRS No. AT-401(40) AT-402(40) AT-403(40) AT-406(40) AT-410(40) AT-420(40) 354-0081-9 40 354-0082-1 40 354-0033-6 40 354-0034-9 40 354-0035-1 40 354-0036-4 40 5/8-24NEF-2B 52 Attenuation(dB) V.S.W.R.(Max) Frequency range Power Weight Packaging (g) (GHz) DC~2GHz 2~4GHz 4~13GHz DC~2GHz 2~4GHz 4~13GHz (W) +0.5 +0.6 01 −0.3 01 −0.3 1±0.3 02 +0.5 02 +0.6 −0.3 −0.3 2±0.3 +0.5 03 −0.3 03 +0.7 −0.3 3±0.3 DC~13 1.15 1.20 1.25 2 77 1 06 +0.5 06 +0.7 −0.3 −0.3 6±0.3 10 +1.0 −0.5 −0.5 10±0.5 10 +0.8 +0.8 20 20 +1.2 −0.5 −0.7 20±0.5 BTypical data ●Non-reflective Terminations [dB] N-TMP-1-1 (50) I.20 I.I5 V. S. W. R. I.I0 I.00 0.0I I 2 3 4 5 6 8 [GHz] 7 ●Fixed Attenuator V.S.W.R. 1.2 1.1 1.0 ATTENUATION(dB) 0 10 2 4 6 8 FREQUENCY[GHz] 10 12 AT-406(40) -5.5 -6.0 -6.5 -7.0 -7.5 -8.0 ATTENUATION(dB) ATTENUATION(dB) AT-403(40) 1.3 AT-403(40) -2.5 -3.0 -3.5 -4.0 0 2 4 6 8 FREQUENCY[GHz] 4 6 8 FREQUENCY[GHz] 10 12 13 12 13 AT-410(40) -9.0 -9.5 -10.0 -10.5 -11.0 -11.5 0 2 4 6 8 FREQUENCY[GHz] 10 12 13 0 2 10 N Series●N type Coaxial Connectors MEMO : 11 N Series●N type Coaxial Connectors USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : +1-805-522-7958 Fax : +1-805-522-3217 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 3255 Scott Boulevard, Building 7, Suite 101 Santa Clara, CA 95054 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. CHICAGO OFFICE 580 Waters Edge Lane, Suite 205 Lombard IL 60148 Phone : +1-630-282-6706 Mail : inquiries@hirose.com http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 37677 Professional Center Drive, Suite #100C Livonia, MI 48154 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : +49-711-4560-02-1 Fax : +49-711-4560-02-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUERNBERG OFFICE Muggenhofer Str. 136 90429 Nuernberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1601, Henderson Metropolitan, NO.300, East Nanjing Road, Huangpu District, Shanghai, China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose.com/cn/ KOREA: SINGAPORE: HIROSE KOREA CO., LTD. HIROSE ELECTRIC SINGAPORE PTE. LTD. 1261-10, Jeoungwhang-Dong, Shihung-City, 10 Anson Road #26-1, International Plaza Kyunggi-Do 429-450 079903, Singapore Phone : +82-31-496-7000,7124 Phone : +65-6324-6113 Fax : +82-31-496-7100 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.co.kr/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE Office NO.519, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Phone : +91-12-660-8018 Fax : +91-120-4804949 http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No.03, Ground Floor, Explorer Building International Tech Park Whitefield Road, Bangalore 560066 Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ ® 12 MALAYSIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. (REPRESENTATIVE OFFICE) 1-10-07, Suntech @ Penang Cybercity (1164),Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 11/2014. Contents are subject to change without notice for the purpose of improvements.
UG-58A/U(40) 价格&库存
很抱歉,暂时无法提供与“UG-58A/U(40)”相匹配的价格&库存,您可以联系我们找货
