131-9403-101
131-9403-101
    CINCH
    SMB
131-9403-101 数据手册
SMB Right Angle Crimp Type Straight Plugs for Flexible Cable 1. Identify connector parts. (3 piece parts: crimp sleeve, body assembly and expansion cap.) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin (optional). Slide crimp sleeve onto cable as shown. 3. Flare braid and slide cable into body assembly making certain that the cable insulation bottoms on center contact. Arrange braid uniformly around crimp stem of body assembly. Slide crimp sleeve over braid and crimp securely using recommended crimp tool. 4. Solder center conductor to contact through the rear and side access ports. Use a minimum amount of solder for a good joint. .020 (0.51) diameter solder is recommended. Place expansion cap in access port and seat with a .125 (3.17) diameter flat punch. Snap cover ring over side access port. Cable Group Part No. Crimp Hex RG-316/U, 188, 174, 179,187 131-9403-101 / -116 .128 (3.25) RG-316 DS, 188 DS, 179 DS, 187 DS 131-9404-101 / -116 .151 (3.83) 256 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
131-9403-101 价格&库存
很抱歉,暂时无法提供与“131-9403-101”相匹配的价格&库存,您可以联系我们找货
