REVISION A
SMP-J-C-XX-RA-CA7
DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
Pb THIS PRODUCT MANUFACTURED
WITH LEAD-FREE PROCESSING
TERMINATION
-CA7: CCA-405 CABLE
(RG405 SEMI FLEXIBLE CABLE)
ORIENTATION
-RA: RIGHT ANGLE
GENDER
-J: JACK
DO NOT
SCALE FROM
THIS PRINT
TYPE
-C: CABLE
PLATING SPECIFICATION
-HG: HEAVY GOLD / GOLD
30µ" Au / 50µ" Ni MIN ON PIN
10µ" Au / 50µ" Ni MIN ON OUTER CONTACT
3µ" Au / 50µ" Ni MIN ON CAP
-GF: GOLD / FLASH GOLD
10µ" Au / 50µ" Ni MIN ON PIN
3µ" Au / 50µ" Ni MIN ON OUTER CONTACT
100µ" Ni MIN ON CAP
(SEE TABLE 1)
2
(SEE NOTE 4)
5.31 .209
REF
7.00 .276
REF
4.36 .172 REF
1
0.50 .020 REF
2.89 .114
REF
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. PRODUCT TO BE PACKAGED PER PACKING STANDARD CO-HD-WI-3040-M.
TRAY: TY-SMA001-1
COVER: TY-SMA001-2
200 PARTS PER TRAY (2 PARTS PER POCKET)
3. CAP TO BE PACKAGED SEPARATELY.
4. THE RING IS LOOSE AND CAN MOVE, 1.5 LBS MIN FORCE TO REMOVE.
A
ANGLES
X.X: 0.3 [.01]
5
X.XX: 0.13 [.005]
X.XXX: 0.051 [.0020]
MATERIAL:
A
F:\DWG\MISC\MKTG\SMP-J-C-XX-RA-CA7-MKT.SLDDRW
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SUB ASSEMBLY:
INSULATOR: PTFE
BODY, RING & SOCKET: BeCu
CAP: BRASS
SHEET SCALE: 8:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
SMP RA JACK FOR CCA-405 - 50 OHM
DWG. NO.
SMP-J-C-XX-RA-CA7
BY: J. BROWNING 02/08/2011 SHEET 1 OF 2
REVISION A
0.9 .04
IN-PROCESS 1
STRIP AND TIN INNER CONDUCTOR
0.30±0.10 .012±.004
CCA-405 CABLE
END OF CABLE DIELECTRIC
SHOULD SEAT FLUSH
AGAINST CONTACT CUP
C
2
IN-PROCESS 2
ADD SUB ASSEMBLY & SOLDER BRAID
CABLE CENTER CONDUCTOR AND
SOLDER SHOULD NOT PROTRUDE
OUTSIDE CONTACT CUP
'A'
C
DETAIL 'A'
SCALE 6 : 1
IN-PROCESS 3
SOLDER SIGNAL CONTACT
C
0.00±0.10 .000±.004
IN-PROCESS 4
INSERT CAP
DETAIL 'B'
SCALE 6 : 1
1
'B'
PROPRIETARY NOTE
SHEET SCALE: 8:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SMP-J-C-XX-RA-CA7
BY: J. BROWNING 02/08/2011 SHEET 2 OF 2
很抱歉,暂时无法提供与“SMP-J-C-GF-RA-CA7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+143.609391+18.67318
