PL75-LP-1.5CW
PL75-LP-1.5CW
    HRS(广濑)
    CONN RF COAXIAL
PL75-LP-1.5CW 数据手册
Ultra-Miniature Push-on Lock Coaxial Connectors for Digital Broadcasting Applications PL75 Series 75ø up to 3GHz PL75 and PL71 Size Comparison ●Right-angle receptacles [PL71] 14.9 9.2 7.2 Ø2.65 5 Ø3.95 [PL75] 9 4.5 Ø0.7 Ø0.7 [PL71] 14.4 6.7 [PL75] 13 14 5 9.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Right-angle plugs Ø4.8 Features Ø6.5 Mating Chart 1.Further reduction in size The size is reduced by approximately 30% when compared with PL71 Series, 75 Ohm connectors. Low mounted profile: 5mm. Fig.1 Plugs Straight PL75-P-1.5CV 2.Superior locking mechanism Our exclusive locking method keeps the mating par t in constant contact with the electr ic reference plane (Top Touch), ensuring high contact stability and reliability. The construction is protected by the outer shell. 3.Reliable at high frequencies The high-frequency performance of the PL75 S e r i e s i s v e r y r e l i a b l e , w i t h V. S . W. R . characteristics of a maximum of 1.3 at DC, and up to 3 GHz, which is suitable for 3G-SDI broadcasting equipment. Right-angle PL75-LP-1.5CV PL75-LP-1.5CW 4.Applicable cable: 1.5C type By using together with Hirose's BNC(75) Series connectors, 75ø total system lines from the interface connections to the internal wiring system is available. Fig.2 5.RoHS compliant All materials and substances used to produce this product comply with RoHS standards. Receptacle Straight PL75-R-PC Right-angle PL75-LR-PC Fig.3 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2014.11w 1 PL75 Series●Ultra-Miniature Push-on Lock Coaxial Connectors for Digital Broadcasting Applications Specifications Nominal characteristic impedance Frequency range Ratings Item 1. Insulation resistance 2. Withstanding voltage 3. Contact resistance 4. Center contact retention force 5. V.S.W.R. * 6. Vibration 7.Moisture resistance : 75ø : DC to 3 GHz Operating temperature range Operating humidity :-30°C to +85°C : RH 95% max. Specification 1,000 Mø min. No flashover or insulation breakdown Center contact : 15 mø max. Conditions 250 V DC 250 V AC / 1 minute 100 mA max. Outer shell: 6 mø max. 0.2 N min. 1.3max. No electrical discontinuity of 1 μs or longer Measured with 0.3 mm diameter pin gauge DC to 3 GHz Frequency: 10 to 500 Hz, single amplitude of 0.75 mm, No damage, cracks, or parts dislocation Insulation resistance: 10 Mø min. (high humidity) acceleration of 98m/s2, 2 hours in each of the 3 axis Insulation resistance: 1,000 Mø min. (dry) 96 hours at +40ç and humidity of 90% to 95% Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No damage, cracks, or parts dislocation Contact resistance Center contact : 19 mø max. 8. Temperature cycle Outer shell : 10 mø max. No damage, cracks, or parts dislocation Temperature:-30ç ➝ +5ç to +35ç ➝ +85ç ➝ +5ç to +35ç Time: 30 min. ➝ 5 min.max. ➝ 30 min.➝ 5 min.max. 5 cycles Contact resistance: Center contact : 19 mø max. 9. Durability Outer shell : 10 mø max. No damage, cracks, or parts dislocation No corrosion 10. Salt spray 500 cycles 5% salt water solution, 48 hours * V.S.W.R. Measurement System The above V.S.W.R. standard values were measured using the measurement system shown below. Network Analyzer Note 1: Cable connectors were measured with PL75 and BNC(75) connectors connected with 10cm long coaxial cable. Test Port Cable D.U.T Materials / Finishes Plugs Part Shell Male center contact Female center contact Insulator Crimp sleeve Material Brass Phosphor bronze Beryllium copper PTFE Brass Finish Gold plated Gold plated Gold plated --------------Nickel plated Material Brass Phosphor bronze Beryllium copper PTFE Finish Gold plated Gold plated Gold plated --------------- Receptacles Part Shell Male center contact Female center contact Insulator Ordering information PL75 − 2 − Series name :PL75 Connector type P :Straight plug LP :Right-angle plug R :Straight receptacle LR :Right-angle receptacle Applicable cable (plug) or board mounting (receptacle) style 1.5CV :1.5CCA-EXBV(LF) 1.5CW :1.5C-QEW.CW PC :DIP mounting PL75 Series●Ultra-Miniature Push-on Lock Coaxial Connectors for Digital Broadcasting Applications Plugs Straight Ø4.8 16 HRS No. Applicable cable RoHS PL75-P-1.5CV 334-0078-0 1.5CCA-EXBV(LF) Yes Right angle 13 9.3 5 Ø4.8 All dimensions: mm Part No. HRS No. Applicable cable PL75-LP-1.5CV 334-0076-4 1.5CCA-EXBV(LF) PL75-LP-1.5CW 334-0080-1 1.5C-QEW.CW RoHS Yes Receptacles Straight ●PCB mounting pattern 5.8 3±0.05 1.5±0.05 Ø2.65 3±0.05 1.5±0.05 +0.1 0 Ø0.8 4∞ 1 0. + 0 2.3 Ø1 Ø0.7 3 All dimensions: mm Part No. HRS No. RoHS PL75-R-PC 334-0081-4 Yes ●PCB mounting pattern Right angle 5 3±0.05 1.5±0.05 +0.1 0 Ø0.8 1 0. + 0 Ø1 4∞ 3±0.05 1.5±0.05 4.5 Ø2.65 4.5 2.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. All dimensions: mm Part No. Ø0.7 3 All dimensions: mm Part No. HRS No. RoHS PL75-LR-PC 334-0075-1 Yes 3 PL75 Series●Ultra-Miniature Push-on Lock Coaxial Connectors for Digital Broadcasting Applications High Frequency Characteristics of 75ø Hirose Products 2 BNC(75) Series 1.9 100 1.8 V.S.W.R. 1.7 1.6 1.5 1.4 1.3 BNC(75)-BPJ-1.5CV-※ BNC(75)-BPJ-1.5CV-※ 1.2 1.1 1 0 0.5 1 1.5 2 2.5 3 2 2.5 3 2 2.5 3 2 2.5 3 Frequency[GHz] Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PL71 Series 2 1.9 100 1.8 V.S.W.R. 1.7 1.6 1.5 1.4 1.3 BNC(75)-BPJ-1.5CV-※ PL71-LP-1.5C(40) 1.2 1.1 1 0 0.5 1 1.5 Frequency[GHz] PL75 Series 2 1.9 100 1.8 V.S.W.R. 1.7 1.6 1.5 1.4 1.3 BNC(75)-BPJ-1.5CV-※ PL75-LP-1.5CV 1.2 1.1 1 0 0.5 1 1.5 Frequency[GHz] H.FL75 Series 2 1.9 1.8 H.FL75-2LPG-084N※-L V.S.W.R. 1.7 100 1.6 1.5 1.4 1.3 1.2 1.1 BNC(75)J-H.FLJ-BPA(40) 1 0 0.5 1 1.5 Frequency[GHz] ® 4 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 11/2014. Contents are subject to change without notice for the purpose of improvements.
PL75-LP-1.5CW 价格&库存
很抱歉,暂时无法提供与“PL75-LP-1.5CW”相匹配的价格&库存,您可以联系我们找货
