FFC.00.250.CTAC22Z
FFC.00.250.CTAC22Z
    LEMO(雷莫)
    FFC.00.250.CTAC22Z
FFC.00.250.CTAC22Z 数据手册
FFC.00.250.CTAC22Z www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 1.80 - 2.20 mm Status active Matching parts ERA.00.250.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFC*: Straight plug with flats on latch sleeve and cable collet and nut for fitting a bend relief Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 3.48 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz Cable type: RG 196 A/U - RG 178 B/U - LEMO Germany reference 178 190 Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >1000 hr DRAWINGS RECOMMENDED BY LEMO Tools Spanner wrench: DCD.00.ZZZ.PA050 Cables 178190 PTFE Brown 196270 PTFE White CCX.50.030.083.180B White CCX.50.RG1.78BU18M FEP Brown CCX.50.RG1.78BU18M PTFE Brown LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 CCX.50.RG1.96AU19B PTFE White CCX.50.RG1.96AU20B PFA White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFC.00.250.CTAC22Z 价格&库存
很抱歉,暂时无法提供与“FFC.00.250.CTAC22Z”相匹配的价格&库存,您可以联系我们找货
