PCA.00.250.CTLC31Z
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
00
Termination type
Female solder
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
2.80 - 3.10 mm
Status
active
Matching parts
FFA.00.250.CTAC31Z
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
PCA*: Free receptacle with cable collet
Keying
Circular, female
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Variant
Z : Nut for fitting a bend relief
Weight
4.27 g
Performance
Configuration
00.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
4 Amps
Specifications
Contact Type: Coaxial 50 Ohm (Solder)
Contact Dia.: 0.7 mm (0.028in)
Bucket Dia.: 0.6 mm (0.024in)
Test voltage: 2.1 kV (rms)
R (max): 6.1 mOhm
Vtest: 2100 V (AC), 3000 V (DC)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Impedance: 50 Ohm
VSWR: 1.09 + 0.11 * f/GHz
Cable type: RG 174 A/U
Others
Endurance (Shell): 5000 mating cycles
F ret (min): 100 N
Salt Spray Corrosion: >1000 hr
DRAWINGS
Dimensions
A
L
S2
mm.
6.5
32.5
6
in.
0,26
1,28
0,24
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.00.ZZZ.PA060
2/3
Cables
17420
PVC
Black
31600
PTFE
Brown
CCX.50.RG1.74AU28N
PVC
Black
CCX.50.RG1.74AU28N
PVC
Black
CCX.50.RG3.16U28M
PTFE
Brown
3/3
很抱歉,暂时无法提供与“PCA.00.250.CTLC31Z”相匹配的价格&库存,您可以联系我们找货
