BNC(75)-BPJ-1.5CV-(P)(40)
    HRS(广濑)
    BNC Connector Jack, Female Socket 75 Ohm Panel Mount, Bulkhead - Front Side Nut Solder
BNC(75)-BPJ-1.5CV-(P)(40) 数据手册
BNC 75Ω connector BNC75 Series ■Features 1. 50Ω-based BNC connector, 75Ω type BNC type products are widely used as 50ø connectors. Hirose’s BNC75 is rated for 75ø and can be mated with the other BNC connectors. 4. Applicable specifications Electronic Industries Association of Japan's temporary specifications (EIAJ RCX-5233) 2. Easy on, easy-off bayonet lock system Bayonet lock system that is easy to use and operate. 3. Applicable cable Cable for this connector is coaxial with the diameter of approximately Ø1.5 - Ø6 (1.5C-QEV.CW etc.) ■Functional diagram Plug side ■Straight plug Representative product: BNC(75)-P-59/U(40) ■Cap CW-123A/U(40) Jack side Plug-plug relay adapter ■Adapter ●Mating interface shape Jack -jack type BNC(75)-A-JJ (40) Jack-Jack relay adapter ■ Short plug JCW-159/U(40) ■Nonreflective terminator ●Mating interface shape: plug type BNC-TMP-05(75)(50) ■U-link ●Mating interface shape Plug-plug type BNC-UPA(75)-35(40) ■Panel jack Representative product: BNC(75)-BPJ1.5CV-(P)(40) ■Right angle receptacle ●PCB-mounted type Representative product: BNC(75)-LRPC-6(40) ■Various conversion adapters ■Non-reflective terminator ●Mating interface shape: Jack type BNC-TMJ-05(75)(50) 2014.11w 1 BNC75 Series●BNC 75Ω connector ■Product Specifications Nominal characteristic impedance Rated voltage Rated frequency Rated value Items 75ø AC150Vrms DC~3GHz Operation temperature range Operating relative humidity Specifications -30ç~+60ç Maximum of 85% Conditions 1. Contact resistance Maximum of 6mø Measured at a maximum of DC 100 mA 2. Insulation resistance Minimum of 1,000 Mø Measured at DC 500 V 3. Withstanding voltage No flashover or dielectric breakdown. AC 500 V for one minute 4. Voltage Standing Wave Ratio (π) Maximum of 1.3 Up to DC 3GHz 5. Retaining force of a female contact Minimum of 0.6N Measured by a pin gauge of Ø 1.32 mm 6. Mating cycles Contact resistance: a maximum of 20 mø 500 times No electrical discontinuity for 1 μs or longer. 7. Vibration Resistance No damage, crack or looseness of parts. Frequency: 10 - 500Hz, half amplitude: 0.75mm 2 Acceleration: 98m/s , 3 axis directions, 10 cycles each 2 Acceleration : 490m/s , duration: 11ms Half-sine, 3 directions, 3 times each 8. Shock resistance No electrical discontinuity for 1 μs or longer. No damage, crack or looseness of parts. 9. Moisture resistance Insulation resistance: a minimum of 100 Mø (at high temperatures) Temperature: +25ç - +65ç Humidity: 80 - 96% Insulation resistance: a minimum of 1000 Mø (when dry) Left for 240 hours No damage, crack or looseness of parts. 10. Thermal shock resistance No damage, crack or looseness of parts. (-55°C for 30 minutes➝5 - 35°C for a maximum of 5 minutes➝85°C for 30 minutes ➝5 - 35°C for a maximum of 5 minutes), 5 cycles 11. Corrosion resistance No heavy corrosion. In a 5 % salt water solution for 48 hours on end πSome products may have different specifications from those shown above. The specification values of the Voltage Standing Wave Ratio (V.S.W.R.) are the values measured in the measuring system shown in the Figure below: Network Analyzer Test Set Test Port D.U.T Test Post Cable Termination ■Material Parts Materials Finish Remarks Shell Brass Silver plating/nickel plating ––––– Male contact Brass Silver plating/gold plating ––––– Female contact Beryllium copper Silver plating/gold plating ––––– Insulator PTFE resin ––––– Flame retardant Gasket Silicone rubber ––––– ––––– ■Ordering information BNC ( 75 ) - L q 2 w P - 59/U e r 1 Series name: BNC(75) :Complies with BNC75ø 2 Shape of connectors None: Straight type L: Right angle type B: Bulk head type 3 Connector type P: Plug PJ: Panel jack R: Receptacle PA: Panel adapter 4 1) For plug / jack ··Applicable cable 2) For receptacle PC: PCB-mounted type 3) For adapter : Mating interface shape 4) All other cases ··additional number BNC75 Series●BNC 75Ω connector ■Plugs Ø14.5 Ø6.55 Ø11.1 ●Straight plug Part No. (26) BNC(75)-P-59/U(40) HRS No. 302-0292-5 40 Applicable cables RoHS Yes RG-59/U Ø5.8 (14.5) ●Panel jack (nut securing type) Part No. HRS No. Applicable cables Mounting hole RoHS dimension Remarks Ships with Ø15 BNC(75)-BPJ-1.5CW-2(40) 302-0343-4 40 14 1.5C-2W 26 Ø16 Part No. 11.65 17.2 23.2 HRS No. 12.5 23.2 11.0 (HEX) Yes 2-2 BNC(75)-BPJ-1.5CV-(P)(40) 302-0369-8 40 Mounting hole RoHS dimension Applicable cables Remarks 1.5C-2V Ships with hex nut Ships with round nut BNC(75)-BPJ-1.5CV-1(40) 302-0375-0 40 1.5C-2V (refer to Note) BNC(75)-BPJ-1.5CW(P)(40) 302-0388-2 40 1.5C-2W Ships with hex nut (Note) Requires dedicated jigs. πThe shape diagram is a representative example. Ø13 15 toothed lug terminal strip Part No. HRS No. Applicable cables BNC(75)-BPJ-1.5CV-2(40) 302-0380-0 40 1.5C-2V 2-1 Yes Mounting hole RoHS dimension 3-1 Yes 3 BNC75 Series●BNC 75Ω connector ■ Receptacles 11 Right angle receptacle (PCB-mounted type) 4- 1 Mounting hole RoHS dimension Part No. HRS No. BNC(75)-LR-PC-6(40) 302-0363-1 40 11 29.9 4-1 Yes ■ Adapters Ø15 Straight adapter Part No. 32.54 HRS No. RoHS 302-0384-1 40 Yes Part No. HRS No. RoHS BNC-UPA(75)-35(40) 302-0301-4 40 Yes BNC(75)-A-JJ(40) 27.1 U-link (Mating interface shape: plug-plug) 35(Movable distance ±1.5) Ø13 Ø2.4 Conversion adapter ( BNC (75) jack to H. FL jack panel adapter) 12.5 21.3 11.0 (HEX) Part No. HRS No. BNC(75)J-H.FLJ-BPA(40) 311-0302-8 40 Mounting hole RoHS dimension 3-1 Yes Conversion adapter (BNC (75) jack to PL71 jack panel adapter) 17.2 27.9 Ø16 Ø3.95 15.0 (HEX) Part No. HRS No. BNC(75)J-PL71J-BPA(40) 311-0304-3 40 Mounting hole RoHS dimension 2-1 Yes 4 BNC75 Series●BNC 75Ω connector ■ Nonreflective terminator Mating interface shape: plug type '&#* '% ¢&& ¢&(#+ ¢&)#* HdaYZg^c\ Part No. HRS No. BNC-TMP-05(75)(50) 353-0100-5 50 Mating interface shape: Jack type 21 19.5 4.5 Ø12 Soldering Part No. HRS No. BNC-TMJ-05(75)(50) 353-0101-8 50 Mounting hole dimension diagram (BNC75Ω connector) 1 2 ØA ØB ØA ØA B B 1C 1D B 4-ØA 4 3 4-ØC 2C 2D Diagram 1 Attached diagram No. 1-1 1 1-2 4.13 B + 0.05 0 11.4 C Attached diagram 3-1 4-1 12.7 3 ------ 3 12.7 3.2 ------ 4 3 ------ 12.8 + 0.1 0 11.8 + 0.1 0 -------- -------- 2-2 11.3 + 0.1 0 10.3 + 0.1 0 -------- -------- 9.8 Diagram 3 D 2-1 1-3 2 A Diagram 2 12.7 No. Diagram 4 B A 9.6 + 0.1 0 8.2 + 0.1 0 1.8 + 0.1 0 1.8 + 0.1 0 C D -------- -------- 5.08 ± 0.05 10.16 ± 0.05 5 BNC75 Series●BNC 75Ω connector High-frequency characteristic of 75Ω hirose product series BNC (75) Series 2 1.9 100 1.8 V.S.W.R. 1.7 1.6 1.5 1.4 1.3 BNC(75)-BPJ-1.5CV-※ BNC(75)-BPJ-1.5CV-※ 1.2 1.1 1 0 0.5 1 1.5 2 2.5 3 2 2.5 3 2 2.5 3 2 2.5 3 Frequency [GHz] PL71 Series 2 1.9 100 1.8 V.S.W.R. 1.7 1.6 1.5 1.4 1.3 BNC(75)-BPJ-1.5CV-※ PL71-LP-1.5C(40) 1.2 1.1 1 0 0.5 1 1.5 Frequency [GHz] PL75 Series 2 1.9 100 1.8 V.S.W.R. 1.7 1.6 1.5 1.4 1.3 BNC(75)-BPJ-1.5CV-※ PL75-LP-1.5CV 1.2 1.1 1 0 0.5 1 1.5 Frequency [GHz] H.FL75 Series 2 1.9 1.8 H.FL75-2LPG-084N※-L V.S.W.R. 1.7 100 1.6 1.5 1.4 1.3 1.2 1.1 BNC(75)J-H.FLJ-BPA(40) 1 0 0.5 1 1.5 Frequency [GHz] ® 6 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 11/2014. Contents are subject to change without notice for the purpose of improvements.
BNC(75)-BPJ-1.5CV-(P)(40) 价格&库存
很抱歉,暂时无法提供与“BNC(75)-BPJ-1.5CV-(P)(40)”相匹配的价格&库存,您可以联系我们找货
