141-0594-421
141-0594-421
    CINCH
    SMA
141-0594-421 数据手册
SMA Straight Solder Type for Semi-Rigid Cables 1. Identify the connector (plug or jack) and tools. 2. Strip the cable jacket and dielectric to dimension shown. Do not nick the center conductor. 3. Bevel the entire diameter on the end of the cable center conductor until the point resembles the appropriate dimensional profile. This operation can be accomplished effectively by using the recommended center conductor pointing tool as described in step 4. 4. Insert the stripped cable into the bushing of the appropriate pointing tool until the center conductor just touches the blade. While maintaining light pressure on the center conductor against the blade, turn the tool in a counter-clockwise fashion as viewed from the bushing end of the tool. Continue cutting the center conductor point until the cable jacket bottoms out inside the bushing. 5. Attach the appropriate soldering mating fixture to the connector and tighten to a maximum of 8 inch pounds of torque. 6. Clean all debris from the prepared cable and insert the cable into the connector, making sure that the cable jacket bottoms out against the internal shoulder of the connector body. 7. Insert the stop screw into the mating fixture. Clamp the cable and fixtured connector assembly securely in the soldering vise. Solder the connector body to the cable as shown, while insuring the cable dielectric expansion does not move the assembly. Allow the assembly to cool before removing the connector from the fixture. 241 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17 SMA Straight Solder Type for Semi-Rigid Cables (cont’d from last page) Cable Group Part No. RG-405/U (.086 Semi-Rigid) 141-0593-421 141-0693-062 RG-402/U (.141 Semi-Rigid) 141-0594-421 141-0694-062 242 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
141-0594-421 价格&库存
很抱歉,暂时无法提供与“141-0594-421”相匹配的价格&库存,您可以联系我们找货
