GRF1-J-P-04-E-RA-TH1
    SAMTEC(申泰)
    插件
GRF1-J-P-04-E-RA-TH1 数据手册
GRF1–P–P–08–E–ST–TH1 F-221 WEB GRF1–P–P–04–E–ST–TH1 GRF1–J–P–04–E–ST–TH1–E GRF1–J–P–04–E–ST–TH1 (5.00 mm) .197" GRF1-J, GRF1-P SERIES 50 W GANGED MICRO-MINI RF SYSTEMS SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?GRF1-J or www.samtec.com?GRF1-P Shell Material: Brass Insulator Material: PTFE Contact Material: BeCu Pin Material: Brass Plating: 30 µ" (0.76 µm) Au over 50 µ" (1.27 µm) Ni Current Rating (GRF1-J/GRF1-P): Signals: 3.6 A per pin (8 adjacent pins powered) Grounds: 6.2 A per pin (8 adjacent pins powered) Operating Temp Range: -40 °C to +90 °C Impedance: 50 W Dielectric Withstanding Voltage: 500 Vrms, 50 Hz Dielectric Working Voltage: 170 Vrms, 50 Hz Frequency Range: 0~6 GHz RoHS Compliant: Yes NO. OF JACKS P J GRF1 Mates with: GRF1-P, GRF1-C, GRF1H-C –02, –04, –06, –08 PLATING LEAD STYLE –E = Vertical –ST = 30 µ" (0.76 µm) Gold on Center Conductor & Tail, Gold Flash on Shell and Tails INSERT OPTION TH1 –E = #1 - 64 Through-hole Threaded Insert, Mates with GRF1-C with captive screw option –RA = Rightangle No. of Jacks x (5.00) .197 + (12.20) .480 No. of Jacks x (5.00) .197 + (7.20) .283 (5.00) .197 (6.68) .263 (6.88) .271 (5.00) .197 (3.50) .138 No. of Jacks x (5.00) .197 (2.80) .110 (4.60) .181 (0.50) .020 SQ (0.70) .028 DIA –RA SHOWN (2.80) .110 –ST–TH1–E SHOWN PROCESSING (2.71) .107 (5.20) .205 Lead–Free Solderable: Yes RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality GRF1 Mates with: GRF1-J FILE NO. E111594 APPLICATION P P NO. OF PLUGS –02, –04, –06, –08 ST PLATING TH1 –E = 30 µ" (0.76 µm) Gold on Center Conductor & Tail, Gold Flash on Shell and Tails No. of Plugs x (5.00) .197 GRF1-J (5.00) .197 (6.40) .252 (5.00) .197 GRF1-P (2.70) .106 OTHER SOLUTIONS (2.70) .106 DIA (1.80) .071 (4.50) .177 • Cable assembly (see GRF1-C Series) (0.50) .020 SQ (2.80) .110 (2.00) .079 (0.70) .028 DIA WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
GRF1-J-P-04-E-RA-TH1 价格&库存
很抱歉,暂时无法提供与“GRF1-J-P-04-E-RA-TH1”相匹配的价格&库存,您可以联系我们找货
  • 1+170.897441+22.22138
  • 10+158.2310210+20.57439
  • 25+145.5781925+18.92918
  • 50+142.0263650+18.46734
