FFA.00.250.CTAC22
FFA.00.250.CTAC22
    LEMO(雷莫)
    CONN PLUG STR 50 OHM SOLDER
FFA.00.250.CTAC22 数据手册
FFA.00.250.CTAC22 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 1.80 - 2.20 mm Status active Matching parts ERA.00.250.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug with cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 2.88 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 VSWR: 1.09 + 0.11 * f/GHz Cable type: RG 196 A/U - RG 178 B/U - LEMO Germany reference 178 190 Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A L M mm. 6.4 26 18 in. 0,25 1,02 0,71 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.00.ZZZ.PA045 Cables LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 178190 PTFE Brown 196270 PTFE White CCX.50.030.083.180B White CCX.50.RG1.78BU18M FEP Brown CCX.50.RG1.78BU18M PTFE Brown CCX.50.RG1.96AU19B PTFE White CCX.50.RG1.96AU20B PFA White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.00.250.CTAC22 价格&库存
很抱歉,暂时无法提供与“FFA.00.250.CTAC22”相匹配的价格&库存,您可以联系我们找货
