FFA.00.250.CTAC31Z
FFA.00.250.CTAC31Z
    LEMO(雷莫)
    FFA.00.250.CTAC31Z
FFA.00.250.CTAC31Z 数据手册
FFA.00.250.CTAC31Z www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 2.80 - 3.10 mm Status active Matching parts ERA.00.250.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug with cable collet and nut for fitting a bend relief Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 3.70 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz Cable type: RG 174 A/U Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A L M mm. 6.4 33.5 25.5 in. 0,25 1,32 1,00 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.00.ZZZ.PA060 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 17420 PVC Black 31600 PTFE Brown CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG3.16U28M PTFE Brown LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.00.250.CTAC31Z 价格&库存
很抱歉,暂时无法提供与“FFA.00.250.CTAC31Z”相匹配的价格&库存,您可以联系我们找货
FFA.00.250.CTAC31Z
  • 1+154.40840
  • 10+129.41031
  • 25+120.24714
  • 50+113.49155
  • 100+106.73596
库存:43
FFA.00.250.CTAC31Z
  • 1+209.670181+27.14362
  • 10+178.1758710+23.06641
  • 30+164.8835130+21.34560
  • 50+159.0473150+20.59005
  • 100+151.46075100+19.60791
  • 250+141.98760250+18.38153
  • 500+135.21988500+17.50539
库存:62
FFA.00.250.CTAC31Z
  • 1+209.42912
  • 10+177.93941
  • 25+165.89643
  • 100+154.89758
  • 250+145.20387
  • 500+138.28658
库存:777
FFA.00.250.CTAC31Z
  • 1+166.106331+21.50390
  • 10+139.2220710+18.02350
  • 25+129.3586925+16.74660
  • 50+122.1139050+15.80870
  • 100+114.86912100+14.87080
库存:43
