FFS.00.250.CTCE32
FFS.00.250.CTCE32
    LEMO(雷莫)
FFS.00.250.CTCE32 数据手册
FFS.00.250.CTCE32 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Male crimp IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFS*: Straight plug with cable crimping Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 3.26 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Crimp) Contact Retention: 18 N Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz Cable type: Storm 421-099 Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A L M mm. 6.4 31 23 in. 0,25 1,22 0,91 RECOMMENDED BY LEMO Tools Crimp Tool: DPE.99.083.8K Die Tool: DPN.99.103.8K Spanner wrench: DCP.99.055.TC LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFS.00.250.CTCE32 价格&库存
很抱歉,暂时无法提供与“FFS.00.250.CTCE32”相匹配的价格&库存,您可以联系我们找货
FFS.00.250.CTCE32
  • 1+214.668041+27.53349
