ERN.0A.275.NTL
ERN.0A.275.NTL
    LEMO(雷莫)
    ERN.0A.275.NTL
ERN.0A.275.NTL 数据手册
ERN.0A.275.NTL www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 0A Termination type Female solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ERN*: Fixed receptacle with tag, nut fixing Keying Housing Material Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces Weight 4.28 g Performance Configuration 0A.275 : 1 Coax (75 Ohm) Insulator Rated Current Specifications Contact Type: Coaxial 75 Ohm (Solder) Others Endurance (Shell): 5000 mating cycles Salt Spray Corrosion: >144 hr LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 DRAWINGS Dimensions A B Emax L M S1 S2 e1 mm. 10 12.5 5.5 19 1.2 8.2 11 M9x0.6 in. 0,39 0,49 0,22 0,75 0,05 0,32 0,43 RECOMMENDED BY LEMO Tools Cables 159580 PVC Black 17420 PVC Black 17450 COPOLYMER Black 178190 PTFE Brown 18000 PTFE Brown 18700 PTFE White 18800 PTFE White 196270 PTFE White 31600 PTFE Brown 62000 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 CCX.50.030.083.180B White CCX.50.RG0.58AU14B FEP White CCX.50.RG1.74-U25N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74U25N PVC Black CCX.50.RG1.78BU18M FEP Brown CCX.50.RG1.78BU18M PTFE Brown CCX.50.RG1.88AU24B TFE White CCX.50.RG1.88AU26B PFA White CCX.50.RG1.88AU26B PTFE White CCX.50.RG1.96AU19B PTFE White CCX.50.RG1.96AU20B PFA White CCX.50.RG3.16BU26M FEP Brown CCX.50.RG3.16U28M PTFE Brown CCX.75.040.195327G PVC Grey CCX.75.RG0.59BU62N PVC Black CCX.75.RG1.79BU26M FEP Brown CCX.75.RG1.87AU26B PFA White CCX.75.RG1.87AU27B PTFE White CCX.93.RG0.62AU62N PVC Black CCX.95.RG1.80BU36M PTFE Brown CCX.95.RG1.95AU37B PFA White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ERN.0A.275.NTL 价格&库存
很抱歉,暂时无法提供与“ERN.0A.275.NTL”相匹配的价格&库存,您可以联系我们找货
ERN.0A.275.NTL
  • 50+165.8232550+21.55649
