GRF1-J-P-08-E-ST-TH1 数据手册
REVISION B
GRF1-J-P-XX-X-XX-XXX-X
DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
DO NOT
SCALE FROM
THIS PRINT
C1
GENDER
-J: JACK
PCB
-P: PCB MOUNT
(No OF POS x 5.00[.197] REF
(No OF POS -1) x 5.00[.197]
5.00 .197
REF (TYP)
INSERT OPTIONS
-E: #1-64 THRU HOLE
THREADED INSERT
(SEE FIG. 2, SHT 2)
TERMINATION
-TH1: THRU HOLE
No OF POSITIONS
-02, -04, -06, -08
C2
"A"
ORIENTATION
-ST: STRAIGHT
PLATING
-E: 50u" GOLD ON CENTER CONDUCTOR
CONTACT AREA AND SOLDER TAIL.
3u" GOLD ON SHELL AND SHELL SOLDER TAILS
5.00 .197
REF
3.50 .138
REF (TYP)
"A"
SUB-GRF1-J-P-X-XX-XXX
C3
2.80±0.10 .110±.004
GRF1-XX-XX-XXX-X
2.00 .079
REF
1.80 .071 REF
4.60 .181
REF
2.80 .11
REF
0.50 .020 SQ
REF (TYP)
0.70 .028
REF (TYP)
((No OF POS -1) x 5.00[.197]) + 2.54[.100]
2.54 .100
REF (TYP)
5.00 .197
REF (TYP)
1. C REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM PUSHOUT FORCE: 2.22N [.5 LB].
GRF1-J-P-04-E-ST-TH1 SHOWN
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
X.X: 0.3
X.XX: 0.13
X.XXX: 0.050
MATERIAL:
ANGLES
2
B
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: L.C.P. COLOR: BLACK
SHELL: BRASS
PIN: BeCu
INSULATOR: TEFLON
F:\DWG\MISC\Mktg\GRF1-J-P-XX-X-XX-XXX-X-MKT.SLDDRW
PACKAGING VIEW
USE: PT 1-24-04-36-TP-09
FIG. 1
2.54 .100
REF (TYP)
DECIMALS
NOTES:
SECTION "A"-"A"
SCALE 6 : 1
SHEET SCALE: 3:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
GANGED RF JACK CONNECTOR
DWG. NO.
BY: CHAD F
9/3/2004
SHEET 1 OF 2
REVISION B
No OF POS x 5.00[.197] + 12.20[.480] REF
No OF POS x 5.00[.197] + 7.20[.283]
C4
"A"
#1-64 UNC-2B
"A"
3.50 .14
REF (2 PLCS)
WT-21-01
2.45±0.10 .096±.004
2.80±0.25 .110±.010
C5
C6
(No OF POS x 5.00[.197]) + 9.74[.383]
2.54 .100
REF (TYP)
FIG. 2
GRF1-J-P-04-E-ST-TH1-E SHOWN
(SAME AS FIG.1, UNLESS OTHERWISE STATED)
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
BY: CHAD F
9/3/2004
SHEET 2 OF 2
GRF1-J-P-08-E-ST-TH1 价格&库存
很抱歉,暂时无法提供与“GRF1-J-P-08-E-ST-TH1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+191.61360
- 196+76.46400
- 504+73.90440
- 994+72.64080
