FFF.00.250.CTAC27
FFF.00.250.CTAC27
    LEMO(雷莫)
    FFF.00.250.CTAC27
FFF.00.250.CTAC27 数据手册
FFF.00.250.CTAC27 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 2.30 - 2.70 mm Status active Matching parts ERA.00.250.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFF*: Straight plug, non-latching, with cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 3.27 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 VSWR: 1.09 + 0.11 * f/GHz Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A L M mm. 6.4 26 18 in. 0,25 1,02 0,71 RECOMMENDED BY LEMO Tools Cables 17450 COPOLYMER Black 18700 PTFE White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 18800 PTFE White CCX.50.RG0.58AU14B FEP White CCX.50.RG1.74-U25N PVC Black CCX.50.RG1.74U25N PVC Black CCX.50.RG1.88AU24B TFE White CCX.50.RG1.88AU26B PFA White CCX.50.RG1.88AU26B PTFE White CCX.50.RG3.16BU26M FEP Brown CCX.75.RG1.79BU26M FEP Brown CCX.75.RG1.87AU26B PFA White CCX.75.RG1.87AU27B PTFE White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFF.00.250.CTAC27
PDF文档中的物料型号为“FFF.00.250.CTAC27”,属于LEMO公司生产的同轴连接器。
该器件为直插头,不带锁扣,配有电缆固定螺帽,并且具有圆形的阳极键槽。
引脚分配为1个同轴连接。
参数特性包括: - 接触类型:同轴50欧姆(焊接) - 接触直径:0.7毫米 - 桶直径:0.6毫米 - 测试电压:2.1千伏(rms) - 最大电阻:6.1毫欧姆 - 测试电压:2100伏(交流),3000伏(直流) - 阻抗:50欧姆 - 电压驻波比:1.09 + 0.11 f/GHz - 端壳耐耐力:5000次插拔循环 - 端壳保持力:最小100牛顿 - 盐雾腐蚀:大于1000小时
功能详解包括: - 壳体风格/型号:FFF:直线插头,非自锁,带电缆固定螺帽 - 键槽:圆形,阳极 - 外壳材料:黄铜(镀硬铬[SAE AMS 2460])壳体和固定螺帽,镍(镀层[SAE AMS QQ N 290])黄铜锁套和中间件 - 重量:3.27克
应用信息: - 推荐配套使用的LEMO工具和电缆型号列表。
封装信息: - 推荐使用的各种电缆型号,包括材料、颜色和型号代码。
以上信息仅供说明,具体产品及服务由LEMO提供,用户需自行负责使用LEMO组件的产品和应用。
FFF.00.250.CTAC27 价格&库存
很抱歉,暂时无法提供与“FFF.00.250.CTAC27”相匹配的价格&库存,您可以联系我们找货
FFF.00.250.CTAC27
  • 50+171.1419550+22.24428
