PSA.00.250.CTLC17
PSA.00.250.CTLC17
    LEMO(雷莫)
    CONN JACK STR 50 OHM SOLDER
PSA.00.250.CTLC17 数据手册
PSA.00.250.CTLC17 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Female solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 1.30 - 1.70 mm Status active Matching parts FFA.00.250.CTAC17 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PSA*: Fixed receptacle, nut fixing, with cable collet Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 4.17 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 VSWR: 1.09 + 0.11 * f/GHz Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A Emax L S S1 S2 e mm. 8 5.5 25 4.5 6.3 4.5 M7x0.5 in. 0,31 0,22 0,98 0,18 0,25 0,18 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.00.ZZZ.PA045 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
PSA.00.250.CTLC17 价格&库存
很抱歉,暂时无法提供与“PSA.00.250.CTLC17”相匹配的价格&库存,您可以联系我们找货
