PSA.00.250.CTLC31
PSA.00.250.CTLC31
    LEMO(雷莫)
    PSA.00.250.CTLC31
PSA.00.250.CTLC31 数据手册
PSA.00.250.CTLC31 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Female solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 2.80 - 3.10 mm Status active Matching parts FFA.00.250.CTAC31 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PSA*: Fixed receptacle, nut fixing, with cable collet Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 4.07 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 VSWR: 1.09 + 0.11 * f/GHz Cable type: RG 174 A/U Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A Emax L S S1 S2 e mm. 8 5.5 25 4.5 6.3 4.5 M7x0.5 in. 0,31 0,22 0,98 0,18 0,25 0,18 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.00.ZZZ.PA045 Cables LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 17420 PVC Black 31600 PTFE Brown CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG3.16U28M PTFE Brown LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PSA.00.250.CTLC31 价格&库存
很抱歉,暂时无法提供与“PSA.00.250.CTLC31”相匹配的价格&库存,您可以联系我们找货
