3269-4001
3269-4001
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPMJACKR/A50OHMSOLDER
3269-4001 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING .109 2.77 - DCN 36005 DATE APPROVED 08/08 STW .207 5.26 .160 4.06 .091 2.31 .147 3.73 MATERIAL: BODY, EXPANSION PLUG & CONTACT: INSULATOR: ACCEPTS .047 S.R. CABLE BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODY, EXPANSION PLUG & CONTACT: EXPANSION PLUG: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PASSIVATED PER AMS-2700, TYPE 2 PERFORMANCE: MATERIAL: IMPEDANCE: FREQ. RANGE: VSWR: DWV: OPERATING TEMP.: 50 OHMS DC TO 20.0 GHz 1.20:1 DC TO 10.0 GHz 1.30:1 DC TO 20.0 GHz 325 VRMS -55 C TO +125 C FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: DAL 08/11/08 CHECKED: APPROVED: STW 08/11/08 STW 08/11/08 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM FEMALE R/A FOR .047 SEMI-RIGID CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 16:1 3269-4001 SHEET 1 OF 1
3269-4001 价格&库存
很抱歉,暂时无法提供与“3269-4001”相匹配的价格&库存,您可以联系我们找货
  • 1+417.551031+53.96100
  • 10+354.9360210+45.86913
  • 25+332.7189725+42.99797
  • 50+316.8496150+40.94714
  • 100+301.74064100+38.99458
  • 300+279.26549300+36.09007
库存:431
