1211-40004
1211-40004
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPPLUGSTR50OHMSMD
1211-40004 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV - DCN 38041 DATE APPROVED 02/11 STW SMP MALE LIMITED DETENT RP .201 5.11 .091±.002 2.31±0.05 .113 2.87 .010 0.25 .165 4.19 MATERIAL: BODY & CONTACT: INSULATOR: .039 0.99 BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 .015 0.38 TORLON .165 4.19 FINISH: BODY & CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: DWV: OPERATING TEMP: 50 OHMS DC TO 26.5 GHz 1.25:1 DC TO 18.0 GHz 1.35:1 18.0 TO 26.5 GHz .03 X SQRT(F(F IN GHz)) 500 VRMS -55 C TO +125 C .076 1.93 NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FED 02/28/11 CHECKED: APPROVED: STW 02/28/11 STW 02/28/11 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP MALE LD SURFACE MT R/A TERMINAL SIZE CAGE CODE DWG. NO. B 95077 SCALE: 12:1 1211-40004 SHEET 1 OF 1
1211-40004 价格&库存
很抱歉,暂时无法提供与“1211-40004”相匹配的价格&库存,您可以联系我们找货
  • 1+452.197701+58.65150
