SF1211-6059
SF1211-6059
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPPLUGSTR50OHMSOLDER
SF1211-6059 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING - DCN 37958 DATE APPROVED 01/11 STW .367 9.32 .240 6.10 .268 6.81 SMP LIMITED DETENT INTERFACE .200±.002 5.08±0.05 .150±.003 3.81±0.08 PANEL MATERIAL: BODY & BLKHD NUT: .2005±.0005 5.09±0.01 STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 FERRULE: BRASS PER ASTM B16, ALLOY UNS No. C36000 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B .240±.001 6.10±0.03 FINISH: BODY & BLKHD NUT: FERRULE & CONTACT: PASSIVATED PER AMS-2700 GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: .050±.001 1.27±0.03 RECOMMENDED MOUNTING HOLE MATERIAL: FINISH: 50 OHMS DC TO 26.5 GHz 1.20:1 DC TO 26.5 GHz SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FED 01/17/11 CHECKED: APPROVED: STW 01/17/11 STW 01/17/11 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP MALE LD BLKHD MOUNT FOR Ø.047 CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 14:1 SF1211-6059 SHEET 1 OF 1
SF1211-6059 价格&库存
很抱歉,暂时无法提供与“SF1211-6059”相匹配的价格&库存,您可以联系我们找货
