SF1233-6000
SF1233-6000
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPPLUGSTR50OHMSOLDER
SF1233-6000 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV DATE APPROVED - REL. NRN 31512 06/04 STW A REV. DCN 37346 02/03/10 PJS .386 9.80 .188 4.78 .075 1.91 .045 1.14 .480 12.19 .328 8.33 .164 4.17 .180 4.57 .052 1.33 SMP FULL DETENT MALE INTERFACE PER MIL-STD-348 2X .098 2.49 RP .110 2.79 MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT & FERRULE: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODY: CONTACT & FERRULE: PASSIVATED PER AMS-2700. GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: DWV: OPERATING TEMP.: 50 OHMS DC TO 18.0 GHz 1.15:1 DC TO 18.0 GHz .03 X SQRT(F(F IN GHz)) 500 VRMS -55 C TO +125 C MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 06/02/04 CHECKED: APPROVED: STW 06/02/04 STW 06/02/04 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP MALE 2 HOLE FL. MT. FOR .047 S/R CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 6:1 SF1233-6000 SHEET 1 OF 1
SF1233-6000 价格&库存
很抱歉,暂时无法提供与“SF1233-6000”相匹配的价格&库存,您可以联系我们找货
