Type N Crimp Type Bulkhead Jack for Flexible Cable
1. Identify connector parts. (6 piece parts)
2. Strip cable to dimensions shown. Do not nick braid or center conductor. A
wire stripper of correct size is recommended for this step. Twist stranded
center conductor into a tight bundle and tin (optional). Slide crimp sleeve
onto cable as shown.
3. Flare body and slide cable into crimp stem of rear body subassembly, until
cable dielectric bottoms out on center contact. Solder center conductor to
contact through the solder hole. Solder must not be allowed to gather and
run on outside of contact. Use a minimum amount of solder for a good joint.
.020 (0.51) diameter solder is recommended.
4. Arrange braid uniformly around crimp stem. Slide crimp sleeve over braid and
crimp securely using recommended crimp tool. Slide insulator over center
conductor and slide center contact assembly into connector body. Thread
rear body subassembly into body and tighten securely (ref. 30 in-lbs torque.)
Cable Group
Part No.
Crimp Hex
RG-316/U, 161, 174, 188
134-0303-406
.160 (4.06)
RG-316 DS, 188 DS
134-0304-406
.160 (4.06)
RG-58/U, 141, 303
134-0307-406
.213 (5.41)
RG-55/U, 142, 223, 400
134-0308-406
.213 (5.41)
259
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“134-0304-406”相匹配的价格&库存,您可以联系我们找货
