1408-6002
1408-6002
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMMAPLUGSTR50OHMSOLDER
1408-6002 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING DATE APPROVED A DCN 42242 06/16 STW B DCN 46958 11/17 FSG .600 15.24 .446 11.33 .065 1.65 .120 3.05 MATERIAL: BODY & HEX NUT: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1; OR ASTM A582 TYPE 303, COND A CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: FLUOROSILICONE LOCK WASHER: 300 SERIES STAINLESS STEEL 10-36 UNS-2A TRUNCATED TO Ø.180±.001 2X .250 [6.35] HEX .125 MAX 3.18 MAX PANEL .1825±.0005 4.64±0.01 FINISH: BODY & CONTACT: HEX NUT & LOCK WASHER: GOLD PER ASTM B 488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. GOLD PER ASTM B488, TYPE I, CODE C, CLASS .50, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. RECOMMENDED MOUNTING HOLE MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: PERFORMANCE: N/A PROPRIETARY IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 28.0 GHz. THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: MEB 10/15/02 CHECKED: APPROVED: STW 10/15/02 STW 10/15/02 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMMA PLUG BLKHD FEED THRU FOR Ø.085 S.R. CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 8:1 1408-6002 SHEET 1 OF 1
1408-6002 价格&库存
很抱歉,暂时无法提供与“1408-6002”相匹配的价格&库存,您可以联系我们找货
  • 100+303.62731100+39.24359
