PSS.00.250.NTME24
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
00
Termination type
Female crimp
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 2.30 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
PSS.00*: Fixed socket, nut fixing, for cable crimping
Keying
Circular, female
Housing Material
Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces
Weight
2.56 g
Performance
Configuration
00.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
4 Amps
Specifications
Contact Type: Coaxial 50 Ohm (Crimp)
Contact Dia.: 0.7 mm (0.028in)
Bucket Dia.: 0.6 mm (0.024in)
Test voltage: 2.1 kV (rms)
R (max): 6.1 mOhm
Vtest: 2100 V (AC), 3000 V (DC)
Impedance: 50 Ohm
VSWR: 1.09 + 0.11 * f/GHz
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Cable type: RG 196 A/U
Others
Endurance (Shell): 5000 mating cycles
F ret (min): 100 N
Salt Spray Corrosion: >144 hr
DRAWINGS
Dimensions
A
E
L
M
S1
S2
S3
e
e
mm.
10.2
5.5
30
1
6.3
5.5
9
M7x0.5
8
in.
0,40
0,22
1,18
0,04
0,25
0,22
0,35
0,31
RECOMMENDED BY LEMO
Tools
Crimp Tool:
DPE.99.123.1K
Die Tool:
DPN.99.123.1K
Spanner wrench:
DCP.99.055.TC
2/3
Cables
178190
PTFE
Brown
196270
PTFE
White
CCX.50.030.083.180B
White
CCX.50.RG1.78BU18M
FEP
Brown
CCX.50.RG1.78BU18M
PTFE
Brown
CCX.50.RG1.96AU19B
PTFE
White
CCX.50.RG1.96AU20B
PFA
White
3/3
很抱歉,暂时无法提供与“PSS.00.250.NTME24”相匹配的价格&库存,您可以联系我们找货
