SF3211-6000
SF3211-6000
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPMPLUGSTR50OHMSOLDER
SF3211-6000 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION DATE APPROVED - DCN 36030 08/08 STW A DCN 47738 07/18 STW REV PRODUCT DATA DRAWING .380 9.65 .165 4.19 .100 2.54 .480 12.19 .112 2.84 .328 8.33 2X .073 THRU .140 3.56 X 82° ACCEPTS T-FLEX 405 CABLE RP MATERIAL: BODY & INSERT: .083 2.11 .207 5.26 STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: INSERT: BODY& CONTACT: PASSIVATED PER AMS-2700 GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: DWV: OPERATING TEMP.: MATERIAL: 50 OHMS DC TO 40.0 GHz 1.30:1 DC TO 40.0 GHz 325 VRMS -55 C TO +125 C FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: DAL 08/26/08 CHECKED: APPROVED: STW 08/26/08 STW 08/26/08 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM MALE SB 2-HOLE FLANGE MOUNT FOR T-FLEX 405 CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 7:1 SF3211-6000 SHEET 1 OF 1
SF3211-6000 价格&库存
很抱歉,暂时无法提供与“SF3211-6000”相匹配的价格&库存,您可以联系我们找货
SF3211-6000
  • 50+624.7207350+80.92319
