SF1211-66303
SF1211-66303
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPPLUGSTR50OHMPCB
SF1211-66303 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING - DCN 41992 DATE APPROVED 12/15 STW 4X .216 5.49 4X .106±.002 2.69±0.05 RP 2X .100 2.54 4X .125 3.18 .218 5.54 4X .025 0.64 .169 4.29 .060 1.52 .015 0.37 RECOMMENDED MOUNTING HOLE MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT & LEGS: BERYLLIUM COPPER PER ASTM B196, ALLOY UNS C17300 INSULATOR: TORLON 4203 (ELECTRICAL GRADE) .030±.002 0.76±0.05 .100±.002 2.54±0.05 FINISH: BODY: CONTACT & LEGS: PASSIVATED PER AMS-2700 GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com MATERIAL: FINISH: PERFORMANCE: SEE NOTES SEE NOTES SURFACE AREA: IMPEDANCE: FREQ. RANGE: VSWR: 50 OHMS DC TO 20.0 GHz 1.30:1 DC TO 20.0 GHz N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: STW 12/29/15 CHECKED: APPROVED: JMC 12/29/15 STW 12/29/15 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP MALE PCB MOUNT W/ R/A CONTACT SMOOTH BORE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 13:1 SF1211-66303 SHEET 1 OF 1
SF1211-66303 价格&库存
很抱歉,暂时无法提供与“SF1211-66303”相匹配的价格&库存,您可以联系我们找货
