FLA.1S.650.ZTA
FLA.1S.650.ZTA
    LEMO(雷莫)
    FLA.1S.650.ZTA
FLA.1S.650.ZTA 数据手册
COAXIAL, TRIAXIAL, MULTI & MIXED CONNECTORS SHORT FORM CATALOGUE ® ® Precision modular connectors to suit your application Since its creation in Switzerland in 1946 the LEMO Group has been recognized as a global leader of circular Push-Pull connectors and connector solutions. Today LEMO and its affiliated companies, REDEL and COELVER, are active in more than 80 countries with the help of over 40 subsidiaries and distributors. Over 75000 connectors The modular design of the LEMO range provides over 75000 connectors from miniature ø 3 mm to ø 50 mm, capable of handling cable diameters up to 30 mm and for up to 114 contacts. This vast portfolio enables you to select the ideal connector configuration to suit almost any specific requirement in most markets, including medical devices, test and measurement instruments, machinery, audio video broadcast, telecommunications and military. LEMO’s Push-Pull Self-Latching Connection System This self-latching system is renowned worldwide for its easy and quick mating and unmating features. It provides absolute security against vibration, shock or pull on the cable, and facilitates operation in a very limited space. The LEMO self-latching system allows the connector to be mated by simply pushing the plug axially into the socket. Once firmly latched, connection cannot be broken by pulling on the cable or any other component part other than the outer release sleeve. When required, the connector is disengaged by a single axial pull on the outer release sleeve. This first disengages the latches and then withdraws the plug from the socket. UL Recognition LEMO connectors are recognized by the Underwriters Laboratories (UL). The approval of the complete system (LEMO connector, cable and your equipment) will be easier because LEMO connectors are recognized. CE marking CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. RoHS LEMO connector specifications conforms the requirements of the RoHS directive (2011/65/EU) of the European Parliament and the latest amendments. This directive specifies the restrictions of the use of hazardous substances in electrical and electronic equipment marketed in Europe. Product safety notice & disclaimers Please read and follow all instructions specified on the last page or on our website carefully and consult all relevent national and international safety regulations for your application. Improper handling, cable assembly, or wrong use of connectors can result in hazardous situations. LEMO products and services are provided “as is.” LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. In no event shall LEMO be liable for any direct, indirect, punitive, incidental, special consequential damages, to property or life, whatsoever arising out of or connected with the use or misuse of LEMO’s products. www.lemo.com www.lemo.com ® ® Introduction This catalogue gives the complete description of LEMO connectors with coaxial, triaxial and mixed contacts. Mixed contacts include coaxial and low voltage contact configurations, as well as multi-coaxial contact configurations. The LEMO manufacturing programme has been extended to almost 40 series divided into 7 product families with specific mating and environmental characteristics. Each series includes a wide variety of plug, socket and coupler models, available in contact configurations adapted to all round cables. The catalogue includes the B, K, S and E Series of the LEMO product range. In addition the 00 Series (triaxial) connector is also represented. Watertight and vacuumtight models are also available. Since LEMO connectors are perfectly screened and designed to guarantee very low resistance to shell electrical continuity, they are particularly adapted to applications where electromagnetic compatibility (EMC) is important. Material and treatment Surface treatment (µm) chrome nickel gold black chr. Notes Cu Ni Cr Cu Ni Cu Ni Au Ni Cr Material (Standard) Component Brass (UNS C 38500) 0.5 Stainless steel (AISI 303, 304 or 316L) without treatment Aluminium alloy (AA 6262A or AA 6023) POM (Delrin or Ertacetal ), Polyoxymethylene, black – 1) PEEK, Polyether ethercetone, beige – 2) PSU (Udel ), Polysulfone, grey or white – 3) PPSU (Radel®), Polyphenylsulfone, cream – 3) PPS (Ryton ), Polyphenilene sulfide, brown – 4) Bronze (UNS C 54400) or special brass – – – 0.5 3 0.5 3 1.0 – – 5) Beryllium Copper (UNS C 17300) – – – 0.5 3 0.5 3 1.0 – – 6) Stainless steel (AISI 416 or 316L) without treatment Special brass 0.5 Stainless steel (AISI 416 or 316L) without treatment Bronze (UNS C 52100) – – – 0.5 3 0.5 3 0.5 – – Brass (UNS C 38500) – – – 0.5 3 0.5 3 0.5 – – Stainless steel (AISI 303, 304 or 316L) without treatment 8) Aluminium alloy (AA 6262A or AA 6023) anodized natural 8) Brass (UNS C 38500) – Stainless steel (AISI 303, 304 or 316L) without treatment O-ring and gaskets Silicone MQ/MVQ or FPM/FKM (Viton®) – Sealing resin Epoxy (Araldite or Stycast ) – Outer shell, collet nut, conical nut or notched nut and oversized collet ® ® ® ® Earthing crown Latch sleeve Locking washer Hexagonal or round nut Other metallic components ® ® Notes: standards for surface treatment are as follows: – chrome-plated: SAE AMS 2460 – nickel-plated: SAE AMS QQ N 290, or MIL DTL 32119 – gold-plated: ISO 27874 – black chrome: MIL-C-14538C with a minimum of 10 µm of lacquer protection 1) for FFP, PCP and ERN models of the 0S to 3S series 2) for FFP, PCP and ERN models of the 0S to 3S series, FGG and ENG models of the 0B, 1B, 3B and 4B series, FFA and FFC models of the 00 triaxial series www.lemo.com 3 3 – 0.3 0.5 0.3 0.5 – 0.5 3 0.5 3 0.5 1 ­ 2 anodized 3 0.5 3 0.5 3 3 0.5 0.5 7) – ­ – – 7) – 9) for the FGG, FGY and ENY models of the 2B to 4B series for 00 triaxial series (elbow sockets for printed circuits) gold-plating for unipole types 6) used in 00 series free and fixed sockets 7) AISI 416 steel is used with shells made of AISI 303 or 304 8) delivered with free and fixed sockets with aluminium alloy or stainless steel shell 9) FPM/FKM (Viton®) o-ring and gaskets are installed upon special request. However standard for vacuumtight models. 3) 4) 5) 1 ® ® B Series B series connectors provide the following main features: – security of the Push-Pull self-latching system – coaxial, triaxial and mixed contact configurations – plastic models made of PSU or PPSU – multiple key options to avoid cross mating of similar connectors («G» key standard). Metal housing models – up to 10 coaxial contacts – solder or crimp contacts – high packing density for space savings – 360° screening for full EMC shielding Fixed plugs Straight plugs FWG FGG EGG EJG PHG FAG FGG ENG EEG PHG FFG EKG ECG PNG Elbow plugs Fixed sockets Free sockets Fixed sockets FHG FNG EHG PKG FKG FEG PFG FDG PEG FIG Plastic housing models Model Description ECG Fixed socket with two nuts, key (G) or keys (A…L and R) (back panel mounting) EEG Fixed socket, nut fixing, key (G) or keys (A…L and R) (back panel mounting) EGG Fixed socket, nut fixing, key (G) or keys (A…L and R) EHG Fixed socket, nut fixing, key (G) or keys (A…L and R), and protruding shell EJG Fixed socket, press or adhesive fit, key (G) or keys (A…L) EKG Fixed socket, nut fixing, key (G) or keys (A…L and R), special alignment mark on the front ENG Fixed socket with earthing tag, nut fixing, key (G) or keys (A…L) ENG Fixed socket with earthing tag, nut fixing, key (G or J), PEEK outer shell ENY Fixed socket with earthing tag, nut fixing, keys (Y), PSU or PPSU outer shell FAG Fixed plug, non-latching, nut fixing, key (G) or keys (A…L and R) FDG Straight plug, long version, key (G) or keys (A…L), cable collet 2 Straight plugs Fixed sockets FGG FGG ENG FGY FGY ENY FEG Straight plug, key (G) or keys (A…L), cable collet, front seal and nut for fitting a bend relief (IP 54 protection index when mated) FFG Straight plug, non-latching, key (G) or keys (A…L), cable collet FGG Straight plug, key (G) or keys (A…L and R), cable collet FGG Straight plug, key (G) or keys (A…L), cable collet and nut for fitting a bend relief FGG Straight plug, key (G or J), cable collet, PEEK outer shell FGG Straight plug, key (G or J), cable collet, PEEK outer shell, nut for fitting a bend relief FGY Straight plug, keys (Y), cable collet and PSU or PPSU outer shell FGY Straight plug, keys (Y), cable collet and PSU or PPSU outer shell and nut for fitting a bend relief FHG Elbow (90°) plug, key (G) or keys (A…L and R), cable collet FIG Straight plug for remote handling, key (G) or keys (A…L and R), special alignment mark, knurled handling surface, cable collet FKG Elbow (90°) plug for remote handling, key (G) or keys (A…L), special alignment mark, knurled handling surface, cable collet FNG Straight plug, key (G) or keys (A…L and R), cable collet and lanyard release FWG Fixed plug, nut fixing, key (G) or keys (A…L) PEG Fixed socket, nut fixing, key (G) or keys (A…L), cable collet (back panel mounting) PFG Fixed socket, with two nuts, key (G) or keys (A…L and R), cable collet (back panel mounting) PHG Free socket, key (G) or keys (A…L and R), cable collet PHG Free socket, key (G) or keys (A…L), cable collet and nut for fitting a bend relief PKG Fixed socket, nut fixing, key (G) or keys (A…L and R), cable collet PNG Free socket, nut fixing, key (G) or keys (A…L and R), cable collet with lanyard release www.lemo.com ® ® Part Numbering System Plug F G G 3 B 8 4 4 C L A D 1 1 1 Free socket P H G 3 B 8 4 4 C L L D 1 1 1 Cable group Variant: Z = collet nut for bend relief (page 9) Cable ø max. 1) Collet type: D or M Fixed socket E G G 8 4 4 3 B C L L 1 Cable group Contact type: A = male solder C = male crimp L = female solder M = female crimp Model Alignment key: G Insulator: L = PEEK Series Housing: C = brass chrome-plated P = PSU Insert configuration: multi coax, coax + LV FGG.3B.844.CLAD111 = straight plug with key (G) and cable collet, 3B series, mixed coax & low voltage type (1 coax and 4 low voltage contacts), outer shell in chrome-plated brass, PEEK insulator, male solder contacts, D type collet for up to 11 mm diameter cable. Cable group 1. PHG.3B.844.CLLD111 = free socket with key (G) and cable collet, 3B series, mixed coax & low voltage type (1 coax and 4 low voltage contacts), outer shell in chrome-plated brass, PEEK insulator, female solder contacts, D type collet for up to 11 mm diameter cable. Cable group 1. EGG.3B.844.CLL1= fixed socket, nut fixing, with key (G), 3B series, mixed coax & low voltage type (1 coax and 4 low voltage contacts), outer shell in chrome plated brass, PEEK insulator, female solder contacts. Cable group 1. Note: 1) see unipole-multipole catalogue. Part Section Showing Internal Components (mixed coax + LV) Straight plug Fixed socket 1 2 3 4 5 6 7 8 8 outer shell earthing crown retaining ring hexagonal nut locking washer insulator female contact female coaxial contact 7 6 2 3 4 5 1 1 8 6 5 4 2 7 3 1 outer shell 2 latch sleeve 3 collet nut 4 split insert carrier 5 insulator 6 male contact 7 collet 8 male coaxial contact www.lemo.com 3 ® ® K Series K series connectors have been specifically designed for outdoor applications. They include an inner sleeve and two seals to prevent penetration of solids or liquids into the housing formed by the plug, free socket or fixed socket. All models (except FXl model) of this series are watertight when mated to give a protection index of IP68 as per IEC 60529 standard (in mated condition) when correctly assembled to an appropriate cable (IP66 otherwise). K series connectors have the same insulators as the B series and have the following main features: – security of the Push-Pull latching system – watertight connection (IP 68/IP 66) – coaxial, triaxial and mixed contact configurations – up to 10 coaxial contacts – solder or crimp contacts – 360° screening for full EMC shielding – multiple key options to avoid cross mating – high packing density for space savings of similar connectors («G» key standard) – rugged housing for extreme working conditions. Models Fixed plugs Straight plugs FXG FAG FGG FGG Elbow plug FHG FGG Fixed sockets EGG EEG EBG Free sockets PHG PHG Fixed sockets PKG PEG PHG EDG EHG Model Description EBG Fixed socket with square flange, key (G) or keys (A to F, L and R) and screw fixing EDG Fixed socket with square flange, key (G) or keys (A to F, L and R), protruding shell and earthing tag, screw fixing EEG Fixed socket, nut fixing, key (G) or keys (A to F, L and R) (back panel mounting) EGG Fixed socket, nut fixing, key (G) or keys (A to F, L and R) EHG Fixed socket, nut fixing, key (G) or keys (A to F and L), protruding shell FAG Fixed plug, nut fixing, non-latching, key (G) or keys (A to F, L and R) FGG Straight plug, key (G) or keys (A to F, L and R), cable collet FGG Straight plug, key (G) or keys (A to F, L and R), cable collet and oversize cable collet FGG Straight plug, key (G) or keys (A to F, L and R), cable collet and nut for fitting a bend relief FHG Elbow (90°) plug, key (G) or keys (A to F, L and R), cable collet FXG Fixed plug with round flange, key (G) or keys (A to F, L and R) and screw fixing PEG Fixed socket, nut fixing, key (G) or keys (A to F, L and R), cable collet (back panel mounting) PHG Free socket, key (G) or keys (A to F, L and R), cable collet PHG Free socket, key (G) or keys (A to F, L and R), cable collet and oversize cable collet PHG Free socket, key (G) or keys (A to F, L and R), cable collet and nut for fitting a bend relief PKG Fixed socket, nut fixing, key (G) or keys (A to F, L and R), cable collet 4 www.lemo.com ® ® Part Numbering System Plug F G G 3 K 8 4 4 C L A C 1 1 3 Free socket P H G 3 K 8 4 4 C L L C 1 1 3 Cable group Variant: Z = collet nut for bend relief (page 9) Cable ø max. 1) Collet type: C or K Fixed socket E G G 3 K 8 4 4 C L L 1 Cable group Alignment key: G Contact type: A = male solder C = male crimp L = female solder M = female crimp Series Insulator: L = PEEK Insert configuration: multi coax, coax + LV Housing: C = brass chrome-plated Model FGG.3K.844.CLAC113 = straight plug with key (G) and cable collet, 3K series, mixed coax & low voltage type (1 coax and 4 low voltage contacts), outer shell in chrome-plated brass, PEEK insulator, male solder contacts, C type collet for 10.5 mm diameter cable. Cable group 3. PHG.3K.844.CLLC113 = free socket with key (G) and cable collet, 3K series, mixed coax & low voltage type (1 coax and 4 low voltage contacts), outer shell in chrome-plated brass, PEEK insulator, female solder contacts, C type collet for 10.5 mm diameter cable. Cable group 3. EGG.3K.844.CLL1 = fixed socket, nut fixing, with key (G), 3K series, mixed coax & low voltage type (1 coax and 4 low voltage contacts), outer shell in chrome-plated brass, PEEK insulator, female solder contacts. Cable group 1. Note: 1) see unipole-multipole catalogue. Part Section Showing Internal Components (mixed coax + LV) Straight plug 1 Fixed socket 2 outer shell 8 2 earthing crown 3 retaining ring 4 hexagonal nut 5 insulator 6 female contact 7 o-ring 8 female coaxial contact 1 5 2 3 4 7 1 6 13 8 2 3 7 6 4 1 9 11 12 10 5 3 4 5 6 7 8 9 10 11 12 13 outer shell latch sleeve inner shell retaining ring collet nut split insert carrier insulator male contact earthing cone collet gasket washer male coaxial contact www.lemo.com 5 ® ® Insert configuration (B and K series) Mixed: multi coax, coax + LV 1B 1K 2B 2K 3B 3K B Rated current (A) Test voltage (kV dc) Test voltage (kV rms) Crimp Solder Contacts type ø A (mm) Number of contacts Cable group Low voltage (LV) Type (see page 10) Impedance (Ω) Reference øA Coax Number of contacts Coax 801 1 50 F 2 1 0.9 l l 0.85 1.20 10 803 1 50 F 2 3 0.9 l l 0.75 1.05 10 802 1 50 A1 1-2-3 2 0.9 l l 0.85 1.20 10 804 1 50 A1 1-2-3 4 0.7 l l 0.75 1.05 7 806 1 50 A1 1-2-3 6 0.7 l l 0.75 1.05 7 810 1 50 C 1-2-3 10 0.7 l l 0.95 1.35 7 841 2 50 E 2 1 1.6 l l 1.90 2.70 17 232 2 50 G – – – – – – – – 243 3 50 2 – – – – – – – 803 1 50 A0 6 3 0.9 l – 1.10 1.55 8 806 1 50 A1 1-2-3 6 0.7 l l 1.00 1.50 7 809 1 50 A1 1-2-3 9 0.7 l l 1.00 1.50 7 812 1 50 A1 1-2-3 12 0.9 l l 0.80 1.10 5 813 1 50 A1 1-2-3 13 0.7 l l 0.90 1.30 7 822 1 50 C 1-2-3 22 0.7 l l 0.70 1.00 5 844 2 50 C 1-2-3 4 0.9 l l 0.90 1.30 10 846 2 50 C 1-2-3 6 0.9 l l 0.90 1.30 10 850 2 50 C 1-2-3 10 0.7 l l 0.75 1.05 8 856 2 50 C 1-2-3 16 0.7 l l 0.70 1.00 7 242 2 50 C 1-2-3 – – – – – – – 243 3 50 C1) 1-2-3 – – – – – 862 3 50 C1) 1-2-3 2 0.9 l E R G Note: 1) for the 3B.243/3K.243 and 3B.862/3K.862 the part number of the extractor is DCC.91.393.4LT. – – l 1.10 1.60 9 l First choice alternative l Special order alternative 6 www.lemo.com ® ® Mixed: multi coax, coax + LV Crimp l 1.00 1.40 12 804 824 A 5-6 50 1 A 4 to 6 75 4 0.9 l l 1.00 1.40 10 806 826 A 5-6 50 1 A 4 to 6 75 6 0.9 l l 1.00 1.40 10 842 2 50 A1 1-2-3 2 0.9 l l 1.70 2.40 12 844 2 50 A1 1-2-3 4 0.9 l l 1.70 2.40 10 852 2 50 C 1-2-3 12 0.9 l l 0.90 1.30 8 856 2 50 C 1-2-3 16 0.9 l l 0.90 1.30 8 858 2 50 C 1-2-3 18 0.7 l l 0.80 1.10 7 866 3 50 C 1-2-3 6 0.7 l l 0.80 1.10 7 885 3 50 C 1-2-3 12 0.7 l l 0.80 1.10 8 244 4 50 C 1-2-3 – – – – 879 4 50 C 1-2-3 9 0.7 l l 0.90 1.30 8 890 6 50 E 2 18 0.7 l l 0.90 1.30 5 894 6 50 E 2 22 0.7 l l 0.90 1.30 4 9971) 1 75 A4 N/A 32 1.3 l l 1.20 1.70 8 1 50 A 5-6 40 0.9 l l 1.30 1.80 7 Reference 840 l First choice alternative    Special order alternative – – Rated current (A) Solder l Test voltage (kV dc) ø A (mm) 0.9 Test voltage (kV rms) Number of contacts 2 Cable group A 5-6 50 1 A 4 to 6 75 Impedance (Ω) 4B 4K 5B 5K Contacts type 802 822 øA Number of contacts Coax Low voltage (LV) Type (see page 10) Coax – Note: 1) only available in 5B series. Solution for triaxial cable fixing. www.lemo.com 7 ® ® Mixed: multi coax, coax + LV 5B 5K Rated current (A) Test voltage (kV dc) Test voltage (kV rms) Crimp Solder Contacts type ø A (mm) Number of contacts Cable group Low voltage (LV) Type (see page 10) Reference øA Number of contacts Coax Impedance (Ω) Coax 868 878 50 B 6 4 3.0 1 75 B 3-5 44 0.9 850 870 50 B 6 2 75 B 3-5 10 0.9 l l 1.40 2.00 8 856 876 6 B 50 2 3-5 B 75 16 0.9 l l 1.40 2.00 7 857 877 2 50 75 2 15 l l 864 2 75 B0 1-6 24 1.3 l l 0.90 1.30 8 273 3 75 B1 5 274 75 5 ­– 892 6 75 D 5-8-9 10 0.9 l l 0.70 1.00 7 260 7 75 D 5-8-9 – – – – – – – 240 10 50 – – – – – – B B 6 3-5 2.0 0.9 l l l l 0.80 1.15 1.40 1.40 2.00 2.00 35 6 30 7 C1 C2 l First choice alternative    4 B1 – C 1-2-3 – – – – – – – – – – – – – Special order alternative 8 www.lemo.com ® ® 2B 2K 3B 3K Inner tube ø (mm) Fluidic (FL) Number of contacts Type Number of contacts Number of contacts High volt. Fibre optic (HV) (FO) ø A (mm) Low volt. (LV) ø A (mm) Cable group Type (see page 10) Rated current (A) Impedance (Ω) Reference øA Coax Number of contacts Coax Number of contacts Mixed: coax + LV + HV, coax + LV + Fluidic, coax + LV + Fibre optic 932 1 50 2.0 C 1 2 1) 0.7 1 2) 0.7 – – – 934 1 50 2.0 C 1 4 0.9 1 0.9 – – – – 970 1 50 2.0 C 1 10 0.7 – – – 986 1 50 2.0 C 1 16 0.7 – – 1 F2 – – – 1 1.3 – Note: 1) Test voltage LV contact-shell 1.9 (kV rms). 2) Test voltage HV contact-shell 7.5 (kV rms). Total rated current for 2B.932 configuration 6 (A). Collet nut for fitting a bend relief (B and K series) D type collets for B series C type collets for K series Coax cable groupe Clamping B Coax cable groupe Clamping 1 2 3 D52Z D51Z D52Z D53Z D62Z D61Z D62Z D63Z D92Z 1 2 3 C50Z C51Z C52Z C53Z C55Z C56Z C57Z C58Z D91Z D92Z D93Z C80Z C81Z C82Z C83Z D10Z D01Z D02Z D03Z C85Z C86Z C87Z C88Z D11Z D11Z D12Z D13Z C90Z C91Z C92Z C93Z D12Z D21Z D22Z D23Z C95Z C96Z C97Z C98Z C10Z C01Z C02Z C03Z C11Z C11Z C12Z C13Z C12Z C21Z C22Z C23Z C13Z C31Z C32Z C33Z C14Z C41Z C42Z C43Z K Note: see unipole-multipole catalogue for others available collets. www.lemo.com 9 ® ® Test voltage (kV rms) Rated current (A) Coaxial contacts for B and K series 0.8 2 1.01 +0.127f 0.9 5 3.00 – 2.35 3.00 1.04 +0.1f 1.6 2 – 1.02 +0.93f 0.8 2 5 1.35 3.95 4.3 5.10 solder collet 6 1.35 3.95 5.3 6.10 1.01 +0.146f 1.8 12 1.3 4 1.05 3.95 3.8 4.60 5 1.05 3.95 4.3 5.10 solder collet 6 1.05 3.95 5.3 6.10 1.01 +0.19f 2.4 7 75 1.3 solder collet none 1.05 3.95 6.7 1.01 7.60 +0.19f 2.4 7 50 0.9 solder crimp 6 1.05 3.75 – 1.06 6.25 +0.156f 0.8 11 75 0.6 3 0.80 2.45 solder crimp 5 0.80 3.75 – 6.25 1.00 +0.22f 2.1 6 B0 75 0.6 0.75 2.95 1 solder solder 0.75 3.75 6 – 1.00 4.25 +0.22f 2.1 6 B11) 75 0.6 crimp crimp – 1.00 6.25 +0.22f 2.1 6 D1) 75 0.5 5 0.75 3.75 8 0.75 2.45 solder crimp 9 0.75 3.00 5.40 3.90 – 4.90 1.00 +0.38f 1.0 5 G3) 50 0.5 solder crimp 1 0.35 1.65 – 1.01 3.00 +0.73f 0.4 2 A0 50 1.3 solder collet 6 0.95 – 3.3 1.02 4.10 +0.3f 2) 3.0 12 1 0.60 1.90 2.5 3.00 2 0.60 1.90 1.7 2.10 solder collet 3 0.60 1.90 2.2 2.60 C1) 50 0.6 1 0.50 0.58 1.65 crimp crimp 2 0.28 0.35 1.05 3 0.28 0.35 1.65 E 1) 3) 50 0.5 solder crimp 50 1.6 75 A A44) 2 0.35 0.95 – VSWR (f=GHz) 0.7 1.05 Maxi 50 0.35 Mini A1 2 Mini Cond. ø maxi Maxi solder crimp Cable group 0.5 Screen fixing 50 Cond. fixing Impedance (Ω) F 1) 3) ø A (mm) Type Dielectric ø maxi Sheath ø 1.05 2.10 +1.83f 2.00 B1) 5 0.55 0.80 3.75 Note: 1) These contacts require specific tools for assembly on the cable, see page 11. 2) Frequency range with SWR ≤ 1.2 = 0 - 1.5 GHz. 3) Coax contact design differs, the central pin is reverse gender. 4) Only available in 5B series. Solution for triaxial cable fixing. 10 www.lemo.com ® ® Recommended coaxial cables for mixed coax, multi coax for B and K Series LEMO cable Part Number Type LEMO Impedance Conductor Dielectric cable group (Ω) ø (mm) ø (mm) Screen ø (mm) Sheath ø (mm) RG 6 A/U 7 75 ± 3 0.73 4.70 6.20 8.45 311 100 LEDE RG 11 A/U 9 75 ± 2 1.17 7.25 8.15 10.10 CCX.50.RG5.8CU50N RG 58 C/U 6 50 ± 2 0.90 2.95 3.60 5.00 CCX.50.RG5.9BU62N RG 59 B/U 5 75 ± 3 0.60 3.70 4.50 6.20 CCX.50.RG1.74AU27N RG 174 A/U 1 50 ± 2 0.48 1.50 2.00 2.80 CCX.50.RG1.78BU18M RG 178 B/U 2 50 ± 2 0.30 0.84 1.30 1.80 CCX.75.RG1.79BU26M RG 179 B/U 3 75 ± 3 0.30 1.50 2.00 2.50 RG 180 B/U 4 CCX.75.RG1.87AU26B RG 187 A/U 2 75 ± 3 0.30 1.50 2.00 2.60 CCX.50.RG1.88AU26B RG 188 A/U 1 50 ± 2 0.54 1.50 2.00 2.60 CCX.50.RG1.96AU20B RG 196 A/U 1 50 ± 2 0.30 0.84 1.30 1.95 CCX.50.RG3.16U26M RG 316 /U 1 50 ± 2 0.60 1.60 2.10 2.80 95 ± 5 0.30 2.60 3.10 3.60 1) Note: 1) when no defined impedance is required. The cable group number corresponding to the chosen cable must be written in the variant position, see pages 3 and 5. Tooling for coaxial contacts of B and K series Reference Coaxial Imp. Cable contact type­ Ω group F C1) E B B1 D Crimping tool with die Spanner for tightening the contact Extractor 50 2 DPE.99.025.45K DCC.91.019.1AK DCC.16.25B.LAG 50 1-3 DPE.99.103.8K – DCC.91.CP1.LAG 50 2 DPE.99.103.1K – DCC.91.CP1.LAG 50 2 DPE.99.002.5K DCC.91.050.2LA – 50 6 75 3 75 5 75 DPE.99.176.2K – DCC.91.804.5LA DPE.99.125.2K – DCC.91.804.5LA DPE.99.127.0K – DCC.91.804.5LA 5 DPE.99.127.0K – DCC.91.808.0LC 75 5 DPE.99.006.2K DCB.91.685.8TN – 75 8 DPE.99.005.2K DCB.91.685.8TN – 75 9 DPE.99.005.5K DCB.91.685.8TN – Note: 1) for the 3B.243/3K.243 and 3B.862/3K.862 the part number of the extractor is DCC.91.393.4LT. www.lemo.com 11 ® ® 00.650 Series The 00 Series are available in triax configuration, allowing a very compact solution for triaxial cables. These connectors are designed for small diameter ranging from 1.1 to 3.5 mm. Either twinax (2 shielded connectors) or triax (1 conductor and 2 concentric separate screens) can be used with the 00 Series. The 00 Series with a 650 configuration insert are mostly used in audio-video applications where a large density of connection is required. LEMO 00 Series connectors offer customers many benefits including: – self-latching push-pull system – ease of use – aesthetically pleasing appearance – low weight – small size – reliable performances – high packing density – wide choice to suit application – rugged construction. Metal housing models Elbow plug Straight plugs FLA FFC FFC Fixed and free sockets Free socket ERN EPA PCA Elbow socket Fixed socket EPL PSA ECP FFY ERX Plastic housing model Threaded latching models FAA Straight plug FAR FFC ERC Straight plug ELF FVN Fixed socket ELF Model Description ECP Fixed socket with 2 round nuts (back panel mounting) ELF Fixed socket, nut fixing, threaded shell with tag (back panel mounting) ELF Fixed socket, nut fixing, threaded shell with tag, black chrome-plated outer shell (back panel mounting) EPA Straight socket for printed circuit board EPL Elbow plug (90°) for printed circuit board ERC Fixed socket, with thread, with slots in flange ERN Fixed socket with nut fixing and tags ERX Fixed socket with nut fixing, slots on flange and tags FAA Straight plug non latching with nut FAR Straight plug non latching with 2 nuts (back panel mounting) FFC Straight plug with flats on latch sleeve and cable collet FFC Straight plug with flats on latch sleeve and cable collet and nut for fitting a bend relief FFC Straight plug with flats on latch sleeve and cable collet, black POM (Delrin® outershell) FFY Straight plug, large shell with cable collet FLA Elbow socket (90°) with cable collet FVN Straight plug with cable collet, black chrome-plated outer shell PCA Free socket with cable collet PSA Fixed socket, nut fixing, cable collet Part Section Showing Internal Components Straight plug Fixed socket 1 2 3 4 5 6 7 outer shell earthing crown retaining ring hexagonal nut locking washer insulator female triaxial contact 7 6 3 4 5 2 1 1 7 6 2 5 4 8 3 1 2 3 4 5 6 7 8 outer shell latch sleeve collet nut earthing sleeve rear insulator insulator male triaxial contact collet 12 www.lemo.com ® ® Part Numbering System Plug F F C 0 0 6 5 0 C L A C 2 7 Free socket P C A 0 0 6 5 0 C L L C 2 7 Z Variant Cable ø max.: from 1.1 to 3.5 mm Collet type: C = with cable collet clamping Contact type: A = male solder L = female solder Fixed socket E R N 0 0 6 5 0 C L L Model Series: 00 Variant Insert configuration: 650 = triaxial ( 50 Ω) Contact type: A = male solder D = male print L = female solder N = female print Housing : N = brass nickel-plated 3) C = brass chrome-plated 3) 1) K = brass black chrome 1) B = black POM 2) G = PEEK (natural) Insulator: L = PEEK FFC.00.650.CLAC27 = straight plug with flats on latch sleeve and cable collet, 00 Series, triaxial (50 Ω), outer shell in chrome-plated brass, PEEK insulator, C type collet for an up to 2.6 mm diameter cable. PCA.00.650.CLLC27Z = free socket with cable collet, 00 Series, triaxial (50 Ω), outer shell in chrome-plated brass, PEEK insulator, C type collet for an up to 2.6 mm diameter cable and nut for fitting a bend relief. ERN.00.650.CLL = fixed socket with nut fixing and tags, 00 Series, triaxial (50 Ω), outer shell in chrome-plated brass, PEEK insulator. Note: 1) treatment not available for the printed circuit models. 2) available for the FFC model only. 3) standard. Insert configuration – 50 0.5 1.02 0.55 2.9 3.5 +0.9f 1) Rated current (A) Test voltage (kV rms) VSWR (f=GHz) Sheath ø maxi Dielectric ø maxi Cond. ø max Cable group ø A (mm) 00 Impedance (Ω) Standard 650 Watertight Reference øA Series 0.6 4 Note: 1) 00.650 is designed for use with 2 conductors screened cable (twinax). www.lemo.com 13 ® ® S Series S series connectors have main features as follows: – security of the Push-Pull self-latching system – solder contacts, print contacts only for coaxial and triaxial configurations – 360° screening for full EMC shielding. – coaxial, triaxial and mixed contact configurations – polarisation by stepped insert (half-moon) – up to 8 coaxial contacts Metal housing models Straight plug Straight plugs Fixed sockets FZP FFA, FFP ERA FFA ERN FFA, FFP ERC Free sockets EBS Fixed sockets PSA, PSP PCA, PCP Fixed plug EBC PCA PSS FAA Straight plug with resistor ERD PCA FRT FFB EHP Elbow plugs ECP RMA FFE JLM FTR Fixed coupler EBD FFF FLS Elbow plug with socket Free coupler RAD FLC FFS Plastic housing models FFP Straight plugs Watertight or vacuumtight models Fixed socket FFA, FFP Fixed coupler Fixed sockets HGP EWB ERN FFL Model Description EBC Fixed socket with square flange, protruding shell and screw fixing EBD Fixed socket with square flange, screw fixing EBS Fixed socket with round flange, screw fixing ECP Fixed socket with two nuts, long threaded shell (back panel mounting) EHP Fixed socket, nut fixing, protruding shell ERA Fixed socket, nut fixing ERC Fixed socket, nut fixing, slot in the flange ERD Fixed socket with two nuts (back panel mounting) ERN Fixed socket, nut fixing, with earthing tag ERN Fixed socket, nut fixing, with earthing tag, PEEK or POM outer shell EWB Fixed socket, nut fixing, with two flats on the flange, watertight or vacuumtight FAA Fixed plug non-latching, nut fixing FFA Straight plug, cable collet FFA Straight plug with oversize cable collet FFA Straight plug, cable collet and nut for fitting a bend relief FFA Straight plug, cable collet, 14 PEEK or POM outer shell FFB Straight plug, cable collet and safety locking ring FFE Straight plug, cable collet, front seal and nut for fitting a bend relief (protected to IP54 when mated) FFF Straight plug, non-latching, cable collet FFP Straight plug, cable collet and inner anti-rotating device FFP Straight plug, cable collet, PEEK or POM outer shell and inner anti-rotating device FFP Straight plug, cable collet, PEEK or POM outer shell, inner anti-rotating device and nut for fitting a bend relief FFS Straight plug for cable crimping FLC Elbow (90°) plug, cable collet FLC Elbow (90°) plug, cable collet and nut for fitting a bend relief FLS Elbow (90°) plug for cable crimping FRT Straight plug with resistor FTR Elbow (90°) plug with socket FZP Straight plug for remote handling, SWH HCP HGW cable collet and inner anti-rotating device HCP Fixed socket, nut fixing, watertight or vacuumtight (back panel mounting) HGP Fixed socket, nut fixing, watertight or vacuumtight HGW Fixed socket, nut fixing, with back washer, watertight or vacuumtight JLM Elbow (90°) plug, cable collet PCA Free socket, cable collet PCA Free socket with oversize cable collet PCA Free socket, cable collet and nut for fitting a bend relief PCP Free socket, cable collet and inner anti-rotating device PSA Fixed socket, nut fixing, cable collet PSP Fixed socket, nut fixing, cable collet and inner anti-rotating device PSS Free socket, nut fixing for cable crimping RAD Fixed coupler, nut fixing RMA Free coupler SWH Fixed coupler, nut fixing, watertight or vacuumtight www.lemo.com ® ® Part Numbering System Plug F F A 1 S 2 5 0 C T A C 4 2 Free socket P C A 1 S 2 5 0 C T L C 4 2 Z Variant: 1) (page 27) Cable ø max. 2) Collet type: C, K or L Fixed socket E R A 2 5 0 1 S C T L Variant 1) Contact type: A = male solder C = male crimp L = female solder M = female crimp Insulator: L = PEEK T = PTFE Model Series Housing: C = brass chrome-plated N = brass nickel-plated B = POM (black) Insert configuration: coaxial, triaxial, multi coax, coax + LV FFA.1S.250.CTAC42 = straight plug with cable collet, 1S series, coaxial (50 Ω), outer shell in chrome-plated brass, PTFE insulator, male solder contact, C type collet for a 4.2 mm diameter cable. PCA.1S.250.CTLC42Z = free socket with cable collet, 1S series, coaxial (50 Ω), outer shell in chrome-plated brass, PTFE insulator, female solder contact, C type collet for a 4.2 mm diameter cable and nut for fitting a bend relief. ERA.1S.250.CTL = fixed socket, nut fixing, 1S series, coaxial (50 Ω), outer shell in chrome-plated brass, PTFE insulator, female solder contact. Note: 1) for mixed contacts, add cable group to the part number. 2) see unipole-multipole catalogue. Part Section Showing Internal Components (mixed coax + LV) Fixed socket 1 outer shell 2 3 4 5 6 7 8 Straight plug 8 earthing crown retaining ring hexagonal nut locking washer insulator male coaxial contact female contact 7 6 2 3 4 5 1 1 6 5 4 2 7 3 1 outer shell 2 latch sleeve 3 collet nut 4 centre-piece 5 insulator 6 female coaxial contact 7 collet www.lemo.com 15 ® ® E Series E series connectors have been specifically designed for outdoor applications. They include an inner sleeve and two seals to prevent penetration of solids or liquids into the housing formed by the plug, free socket or fixed socket. All models of these series are watertight when mated and give a protection index of IP 68 as per IEC 60529 standard (in mated condition) when correctly assembled to an appropriate cable (IP 66 otherwise). – security of the Push-Pull latching system – coaxial, triaxial and mixed contact configurations – watertight connection (IP 68/IP 66) – polarization by stepped insert (half-moon) – solder contacts, print contacts only – 360° screening for full EMC shielding for coaxial and triaxial configurations – rugged housing for extreme working condition. Models Straight plug Straight plugs FZP FFA Fixed plug FFA Fixed sockets ERA ERB Free sockets PCA PCA FAA Elbow plug FFA EEP Fixed socket FLA FFF EHP PSA Watertight or vacuumtight models Fixed sockets HGP Fixed coupler EBR Model Description EBR Fixed socket with round flange, watertight, protruding shell and screw fixing EEP Fixed socket, nut fixing (back panel mounting) EHP Fixed socket, nut fixing, protruding shell ERA Fixed socket, nut fixing ERB Fixed socket, nut fixing with two flats in the flange FAA Fixed plug non-latching, nut fixing FFA Straight plug, cable collet 16 PCA SWH FFA Straight plug with oversize cable collet FFA Straight plug, cable collet and nut for fitting a bend relief FFF Straight plug non-latching, cable collet FLA Elbow (90°) plug, cable collet FZP Straight plug for remote handling, cable collet and inner anti-rotating device HGP Fixed socket, nut fixing, watertight or vacuumtight PCA Free socket, cable collet Free coupler RMA PCA Free socket with oversize cable collet PCA Free socket, cable collet and nut for fitting a bend relief PSA Fixed socket, nut fixing, cable collet RMA Free coupler SWH Fixed coupler, nut fixing, watertight or vacuumtight www.lemo.com ® ® Part Numbering System Plug F F A 1 E 2 5 0 C T A C 5 0 Free socket P C A 1 E 2 5 0 C T L C 5 0 Z Variant: 1) (page 27) Cable ø max. 2) Collet type: C or K Fixed socket E R A 1 E 2 5 0 C T L Variant 1) Contact type: A = male solder L = female solder Insulator: L = PEEK T = PTFE Model Series Housing: C = brass chrome-plated K = brass black chrome T = stainless steel Insert configuration: coaxial, triaxial, multi coax, coax + LV FFA.1E.250.CTAC50 = straight plug with cable collet, 1E series, coaxial (50 Ω), outer shell in chrome-plated brass, PTFE insulator, C type collet for an up to 5.0 mm diameter cable. PCA.1E.250.CTLC50Z = free socket with cable collet, 1E series, coaxial (50 Ω), outer shell in chrome-plated brass, PTFE insulator, C type collet for an up to 5.0 mm diameter cable and collet nut for fitting a bend relief. ERA.1E.250.CTL = fixed socket, nut fixing, 1E series, coaxial (50 Ω), outer shell in chrome-plated brass, PTFE insulator. Note: 1) for mixed contacts, add cable group to the part number. 2) see unipole-multipole catalogue. Part Section Showing Internal Components (mixed coax + LV) Straight plug Fixed socket 1 2 3 4 5 6 7 8 7 outer shell earthing crown retaining ring hexagonal nut insulator male coaxial contact female contact o-ring 6 5 2 3 4 8 1 8 2 3 7 6 1 4 9 11 12 10 5 1 2 3 4 5 6 7 8 9 10 11 12 outer shell latch sleeve inner shell retaining ring collet nut centre-piece insulator female coaxial contact earthing cone collet gasket washer www.lemo.com 17 ® ® Insert configuration (S and E series) Coaxial Test voltage (kV rms) Rated current (A) 2.1 4 0S 0E 50 1-2 0.9 3-4 1.02 0.95 2.95 6.7 5.0 +0.25f 3.0 6 250 1S 1E 50 1-2 1.6 3-4 1.01 1.35 3.95 8.5 8.5 +0.23f 3.0 12 275 1S 1E 75 1.02 1.3 5-6-7 1.05 3.95 8.5 8.5 +0.08f 2.4 10 250 2S 2E 50 2.0 1.01 6-7 1.75 5.95 10.5 10.5 +0.95f 3.0 15 275 2S 2E 75 1.6 1.02 6-7 1.35 5.95 10.5 10.5 +0.03f 1.5 12 250 3S 3E 50 3.0 8 1.06 2.65 8.15 13.0 15.0 +0.5f 3.0 26 275 3S 3E 75 2.0 8 1.04 1.75 8.15 13.0 15.0 +0.05f 2.7 15 250 4S 4E 50 4.0 1.01 8-9 3.65 10.05 22.0 23.5 +1.9f 2.1 36 275 4S 4E 75 1.01 3.0 8-9-0 2.65 10.05 22.0 23.5 +0.12f 1.8 26 250 5S – 50 5.0 1.02 5.15 17.45 30.0 30.0 +2.3f 3.0 45 250 1S 1E 2S 2E 3S 3E 4S 4E Cond. ø max Cable group ø A (mm) Reference 0S 0E VSWR (f=GHz) 1.09 0.7 1 to 9 1.05 3.05 5.5 +0.11f Maxi E series 50 Maxi S series – 00 Dielectric ø maxi Impedance (Ω) 2501) 00 øA Watertight Sheath ø Standard Series 5S 9 Note: 1) see NIM-CAMAC catalogue. 18 www.lemo.com ® ® Triaxial Rated current (A) Test voltage (kV rms) (contact/screen) VSWR (f=GHz) Maxi E series Maxi S series Dielectric ø maxi Cond. ø max Cable group ø A (mm) Sheath ø Impedance (Ω) Watertight Standard Reference øA Series 0S 0E 650 1.03 0S 0E 50 0.9 1-2 0.75 2.95 6.7 5.0 +0.34f 1.0 6 1S 1E 650 1.01 1S 1E 50 0.9 1-2-3 0.75 3.95 8.5 8.5 +0.17f 1.0 6 2S 2E 650 1.01 2S 2E 50 1.6 2-3-4 1.35 5.95 10.5 10.5 +0.3f 1.5 12 675 1.01 2S 2E 75 0.9 4-6 0.75 5.95 10.5 10.5 +0.07f 1.5 650 1.01 3S 3E 50 2.0 3-4-5 1.75 8.45 13.0 15.0 +0.27f 2.4 15 675 1.01 1.02 3S 3E 75 0.9 4-5 0.75 8.45 13.0 15.0 +0.05f 1.8 6 650 4S 4E 50 1.01 3.0 4-5 2.65 10.05 22.0 23.5 +0.38f 2.7 26 675 4S 4E 75 1.01 2.0 4-5-7 2.25 10.05 22.0 23.5 +0.14f 2.2 15 3S 3E 4S 4E 6 www.lemo.com 19 ® ® Mixed: coax + LV, multi coax 3S 3E 4S 4E Rated current (A) Test voltage (kV dc) Test voltage (kV rms) ø A (mm) Number of contacts Cable group Low voltage Type (see page 28) Rated current (A) Impedance (Ω) Coaxial Number of contacts Watertight Standard Coax Reference øA Series 801 3S 3E 1 50 5 A1 1-2-3 1 1.3 2.7 3.9 14 802 3S 3E 1 50 5 A1 1-2-3 2 1.3 1.2 1.8 14 803 3S 3E 1 50 5 A1 1-2-3 3 1.3 2.7 3.9 14 804 3S 3E 1 50 5 A1 1-2-3 4 1.3 1.2 1.8 10 805 3S 3E 1 50 5 A1 1-2-3 5 0.9 1.8 2.4 8 806 3S 3E 1 50 5 A1 1-2-3 6 0.9 0.8 1.2 8 807 3S 3E 1 50 5 A1 1-2-3 7 0.9 0.8 1.2 7 802 4S 4E 1 50 5 A1 1-2-3 2 3.0 2.1 3.0 21 803 4S 4E 1 50 5 A1 1-2-3 3 2.0 2.1 3.0 16 804 4S 4E 1 50 5 A1 1-2-3 4 1.3 2.7 3.9 13 805 4S 4E 1 50 5 A1 1-2-3 5 1.3 2.1 3.0 11 806 4S 4E 1 50 5 A1 1-2-3 6 1.3 2.1 3.0 9 807 4S 4E 1 50 5 A1 1-2-3 7 1.3 2.1 3.0 8 809 4S 4E 1 50 5 A1 1-2-3 9 0.9 2.1 3.0 7 810 4S 4E 1 50 5 A1 1-2-3 10 0.9 2.1 3.0 7 812 4S 4E 1 50 5 A1 1-2-3 12 0.9 2.1 3.0 7 202 4S 4E 2 50 5 A1 1-2-3 – – – – – 832 4S 4E 2 50 5 A1 1-2-3 2 1.3 2.1 3.0 13 20 www.lemo.com ® ® Mixed: coax + LV, multi coax Test voltage (kV dc) Test voltage (kV rms) 1.3 2.1 3.0 13 836 4S 4E 2 50 5 A1 1-2-3 6 0.9 1.8 2.4 7 838 4S 4E 2 50 5 A1 1-2-3 8 0.9 1.8 2.4 7 842 4S 4E 2 50 5 A1 1-2-3 12 0.9 1.8 2.4 7 803 – 5E 1 50 12 A 4-6 3 3.0 3.0 4.2 25 804 5S 804 – 5E 1 75 7 A 3-4-5 4 3.0 2.1 3.0 22 810 5S 5E 1 50 5 A1 1-2-3 10 1.6 1.8 2.4 11 232 5S 2 50 6 A0 1-3-4 – – – – – 282 292 5S 5E 50 12 2 75 7 4-6 A 3-4-5 – – – – 832 5S 5E 2 A0 1-3-4 2 – – 1 50 50 6 6 A0 1-3-4 4 – Rated current (A) A1 1-2-3 4 ø A (mm) 5 Number of contacts 50 Cable group 2 Number of contacts 4S 4E Watertight 834 Standard Type (see page 28) 5S 5E Low voltage Rated current (A) 4S 4E Reference Coax Coaxial Impedance (Ω) øA Series 3.0 2.1 3.0 22 2.0 2.1 3.0 18 www.lemo.com 21 ® ® Mixed: coax + LV, multi coax 5S 5E Rated current (A) Test voltage (kV dc) Test voltage (kV rms) ø A (mm) Number of contacts Cable group Low voltage Type (see page 28) Rated current (A) Impedance (Ω) Coaxial Number of contacts Watertight Standard Coax Reference øA Series 834 5S 5E 2 50 6 A0 1-3-4 4 2.0 2.1 3.0 18 838 5S 2 50 6 A0 1-3-4 8 1.6 1.8 2.4 12 842 5S 5E 2 50 6 A0 1-3-4 12 1.3 1.8 2.4 846 – 5E 2 75 7 A 3-4-5 16 1.3 0.8 1.2 8 850 5S – 2 50 6 A0 1-3-4 20 1.3 0.8 1.2 7 854 5S – 2 50 6 A0 1-3-4 24 1.3 0.8 1.2 6 234 5S 5E 4 50 5 A1 1-2-3 – – 876 5S 5E 4 50 5 A1 1-2-3 6 – – – – 1.3 0.8 1.2 9 6 22 www.lemo.com ® ® Mixed: coax + LV, multi coax Rated current (A) Test voltage (kV dc) Test voltage (kV rms) ø A (mm) Number of contacts Cable group Low voltage Type (see page 28) Rated current (A) Impedance (Ω) Number of contacts Coax Reference øA Coaxial 6S 826 1 75 7 A 3-4-5 26 2.0 1.5 2.1 7 830 4 1 75 7 A 3-4-5 30 3.0 1.6 1.5 1.5 2.1 2.1 14 5 858 2 75 7 A 3-4-5 6 6 5 17 1.3 1.6 2.0 1.9 1.2 1.2 1.2 1.2 1.8 1.8 1.8 1.8 4 5 10 2 859 2 50 5 A1 1-2-3 36 4 1.3 3.0 1.2 1.2 1.8 1.8 4 14 866 3 50 6 A0 1-3-4 26 2.0 1.5 2.1 7 867 49 3 75 7 A 3-4-5 2 883 4 50 4 A1 1-2-3 30 1.6 1.5 2.1 5 0.9 1.6 1.2 1.2 1.8 1.8 2 5 www.lemo.com 23 ® ® Mixed: coax + LV, multi coax Rated current (A) Test voltage (kV dc) Test voltage (kV rms) ø A (mm) Number of contacts Cable group Low voltage Type (see page 28) Rated current (A) Impedance (Ω) Number of contacts Coax Reference øA Coaxial 6S 284 294 50 12 4-6 4 A 75 7 3-4-5 – – – – – 882 4 887 1 50 26 A3 7 9 4 50 5 A1 3 890 6 50 5 A1 1-2-3 4 4.0 1.5 2.1 16 893 6 50 5 A1 1-2-3 20 1.6 1.5 2.1 5 238 8 50 6 A0 1-3-4 – – – – – 899 8 75 7 A 3-4-5 26 0.9 0.8 1.2 2 } 50 7 2.0 1.5 2.1 10 5 A1 1-2-3 20 1.6 1.5 2.1 5 24 www.lemo.com ® ® Mixed: coax + LV, multi coax Rated current (A) Test voltage (kV dc) Test voltage (kV rms) ø A (mm) Number of contacts Cable group Low voltage Type (see page 28) Rated current (A) Impedance (Ω) Number of contacts Coax Reference øA Coaxial 6E 8051) 1 75 7 A 3-4-5 5 2.0 1.5 2.1 10 831 1 75 7 A 3-4-5 24 12 0.9 2.0 0.8 1.5 1.2 2.1 2 10 843 2 75 7 A 3-4-5 12 1 2.0 3.0 1.5 1.5 2.1 2.1 10 14 847 2 50 5 A1 1-2-3 17 2.0 1.5 2.1 10 856 2 75 7 A 3-4-5 26 2.0 1.5 2.1 7 857 2 75 7 A 3-4-5 33 1.3 1.2 1.8 4 865 3 75 7 21 A 3-4-5 4 1.3 2.0 1.2 1.2 1.8 1.8 4 10 Note: 1) The type 6E.805 is delivered with female contacts in the plug. www.lemo.com 25 ® ® Mixed: coax + LV, multi coax Rated current (A) Test voltage (kV dc) Test voltage (kV rms) ø A (mm) Number of contacts Cable group Low voltage Type (see page 28) Rated current (A) Impedance (Ω) Number of contacts Coax Reference øA Coaxial 6E 866 3 75 7 880 4 882 4 75 7 A 3-4-5 20 0.9 0.8 1.2 2 884 4 75 7 A 3-4-5 38 0.9 0.8 1.2 2 235 5 50 6 A0 1-3-4 – 899 8 50 5 A1 1-2-3 20 1.6 1.5 2.1 5 50 A 3-4-5 26 1.3 1.2 1.8 4 5 A1 1-2-3 20 1.3 1.2 1.8 4 – – – – 26 www.lemo.com ® ® Mixed: coax + LV + HV ø A (mm) A1 1-2-3 4 0.9 ø A (mm) 5 Number of contacts 50 Cable group Type (see page 28) 1 Rated current (A) 934 Impedance (Ω) Number of contacts 4S 4E Reference øA Coax Number of contacts Low voltage High voltage (LV) (HV) Coax 1 2.0 Collet nut for fitting a bend relief (S and E series) C type collets for S series C type collets for E series Coax cable groupe Clamping S Coax cable groupe Clamping 1 2 3 C42Z C41Z C42Z C43Z C57Z C51Z C52Z C53Z C72Z C71Z C72Z C73Z C87Z 1 2 3 C50Z C51Z C52Z C53Z C55Z C56Z C57Z C58Z C80Z C81Z C82Z C83Z C81Z C82Z C83Z C85Z C86Z C87Z C88Z C97Z C91Z C92Z C93Z C90Z C91Z C92Z C93Z C11Z C11Z C12Z C13Z C95Z C96Z C97Z C98Z C12Z C21Z C22Z C23Z C10Z C01Z C02Z C03Z C11Z C11Z C12Z C13Z C12Z C21Z C22Z C23Z C13Z C31Z C32Z C33Z C14Z C41Z C42Z C43Z E Note: see unipole-multipole catalogue for others available collets. www.lemo.com 27 ® ® VSWR (f=GHz) Maxi Mini Dielectric ø maxi Cond. ø maxi Cable group Screen fixing Cond. fixing ø A (mm) Impedance (Ω) Type Sheath ø Rated current (A) Test voltage (kV rms) Coaxial contacts for S and E series A1 1 0.55 1.90 2.5 3.0 1.01 2 0.55 1.90 1.7 2.1 50 0.7 solder collet 0.9 5 +0.127f 3 0.55 1.90 2.2 2.6 A0 1 0.95 2.95 1.7 2.1 1.06 50 0.9 solder collet 3.0 6 3 0.95 2.95 2.7 3.1 +0.1f 4 0.95 2.95 3.3 4.1 1.01 4 1.35 3.95 3.3 4.1 50 1.6 solder collet 1.8 12 +0.146f 6 1.35 3.95 4.3 5.1 A 3 1.05 3.95 2.2 2.6 1.01 4 1.05 3.95 3.3 4.1 75 1.3 solder collet 2.4 7 +0.19f 5 1.05 3.95 5.3 6.1 A3 1.06 50 3.0 solder collet 7 2.60 8.10 10.0 10.6 +0.5f 3.0 15 Recommended coaxial cables for 00 Series (page 18) Non standard Standard LEMO cable Part Number LEMO Type cable group Impedance Conductor Dielectric (Ω) ø (mm) ø (mm) Screen ø (mm) Sheath ø (mm) CCX.50.RG5.8CU50N RG 58 C/U 6 50 ± 2 0.90 2.95 3.60 5.00 CCX.50.RG1.42BU50M RG 142 B/U 7 50 ± 2 0.95 2.95 3.53 / 4.30 5.00 CCX.50.RG1.74U25N RG 174 /U 3 50 ± 2 0.48 1.50 2.00 2.55 CCX.50.RG1.74AU27N RG 174 A/U 3 50 ± 2 0.48 1.50 2.00 2.80 CCX.50.RG1.78BU18M RG 178 B/U 1 50 ± 2 0.30 0.84 1.30 1.80 CCX.75.RG1.79BU26M RG 179 B/U 2 75 ± 3 0.30 1.50 2.00 2.50 CCX.75.RG1.87AU26B RG 187 A/U 2 75 ± 3 0.30 1.50 2.00 2.60 CCX.50.RG1.88AU24B RG 188 A/U 4 50 ± 2 0.54 1.50 2.00 2.60 CCX.95.RG1.95AU37B RG 195 A/U 5 95 ± 5 0.30 2.52 3.10 3.70 CCX.50.RG1.96AU20B RG 196 A/U 1 50 ± 2 0.30 0.84 1.30 1.95 CCX.50.RG3.16U26M RG 316 /U 4 50 ± 2 0.54 1.50 2.10 2.60 Huber+Suhner, G02232D-60 8 50 ± 2 0.50 1.50 1.95 / 2.40 3.10 Huber+Suhner, K01152-07 9 50 ± 5 0.19 0.52 0.90 1.25 Storm, 421-099 8 50 ± 2 0.50 1.52 2.00 / 2.50 3.05 Note: for more details on cable properties, see NIM-CAMAC catalogue. 28 www.lemo.com ® ® Recommended triaxial cables for 00 Series (page 13) Standard LEMO cable Part Number Impedance Conductor Type (Ω) ø (mm) Dielectric ø (mm) Screen 1 ø (mm) Screen 2 ø (mm) Sheath ø (mm) RGT 316 50 ± 2 0.51 1.50 2.05 3.15 3.60 RGT 403 50 ± 2 0.30 0.84 1.30 2.35 2.95 017 410 LEDE RGT 174 50 ± 2 0.48 1.55 1.90 2.90 3.90 017 820 LEDE RGT 178 50 ± 2 0.30 0.90 1.37 2.30 2.80 Huber + Suhner G 02332 50 ± 2 0.49 1.50 2.00 3.05 4.25 SMT 50 50 ± 2 0.16 0.52 0.85 1.35 1.60 Recommended coaxial cables for S and E Series (page 18) LEMO cable Part Number Type LEMO Impedance Conductor Dielectric cable group (Ω) ø (mm) ø (mm) Screen ø (mm) Sheath ø (mm) RG 11 A/U 8 75 ± 2 1.17 7.25 8.15 10.10 RG 12 A/U 0 75 ± 3 1.20 7.25 8.20 11.80 CCX.50.RG5.8CU50N RG 58 C/U 6 50 ± 2 0.90 2.95 3.60 5.00 CCX.50.RG5.9BU62N RG 59 B/U 7 75 ± 3 0.60 3.70 4.50 6.20 RG 115 A/U 8 50 ± 2 2.25 6.50 8.00 10.50 RG 122 /U 4 50 ± 2 0.80 2.50 3.20 4.10 RG 142 B/U 6 50 ± 2 0.95 2.95 4.30 5.00 RG 144 /U 8 75 ± 3 1.35 7.25 8.00 10.40 RG 165 /U 8 50 ± 2 2.46 7.25 8.00 10.40 CCX.50.RG1.74AU27N RG 174 A/U 3 50 ± 2 0.48 1.50 2.00 2.80 CCX.50.RG1.78BU18M RG 178 B/U 1 50 ± 2 0.30 0.84 1.30 1.80 CCX.75.RG1.79BU26M RG 179 B/U 5 75 ± 3 0.30 1.50 2.00 2.50 CCX.75.RG1.87AU26M RG 187 A/U 5 75 ± 3 0.30 1.50 2.00 2.60 CCX.50.RG1.88AU26B RG 188 A/U 2 50 ± 2 0.54 1.50 2.00 2.60 CCX.50.RG1.96AU20B RG 196 A/U 1 50 ± 2 0.30 0.84 1.30 1.95 213 000 LEDE RG 213 /U 8 50 ± 2 2.25 7.25 8.20 10.30 RG 214 /U 9 50 ± 2 2.25 7.25 8.80 10.80 RG 216 /U 9 75 ± 3 1.20 7.25 8.80 10.80 RG 223 /U 7 50 ± 2 0.89 2.95 4.30 5.40 RG 225 /U 9 50 ± 2 2.40 7.25 8.80 10.90 RG 302 /U 6 75 ± 3 0.64 3.70 4.40 5.10 RG 316 B/U 2 50 ± 2 0.60 1.60 2.10 2.80 RG 400 /U 6 50 ± 2 1.00 2.98 4.20 5.00 HF-2114 Dätwyler 3 50 ± 2 0.48 1.30 1.90 2.70 HF-5408/1 Dätwyler 7 75 ± 3 0.60 3.80 5.60 2YCCY 0.4/2.5 Siemens 6 75 ± 2 0.40 2.50 4.50 311 100 LEDE CCX.50.RG1.42BU50M CCX.50.RG3.16U26M 3.70 www.lemo.com 29 ® ® Recommended coaxial cables for mixed coax, multi coax for S and E Series (pages 20 to 27) LEMO cable Part Number CCX.50.RG5.8CU50N CCX.50.RG5.9BU62N Type RG 58 C/U LEMO Impedance Conductor Dielectric cable group (Ω) ø (mm) ø (mm) 6 50 ± 2 0.90 2.95 Screen ø (mm) 3.60 Sheath ø (mm) 5.00 RG 59 B/U 5 75 ± 3 0.60 3.70 4.50 6.20 RG 122 /U 4 50 ± 2 0.80 2.50 3.20 4.10 CCX.50.RG1.42BU50M RG 142 B/U 6 50 ± 2 0.95 2.95 4.30 5.00 CCX.50.RG1.74.AU27N RG 174 A/U 1 50 ± 2 0.48 1.50 2.00 2.80 CCX.50.RG1.78BU18M RG 178 B/U 2 50 ± 2 0.30 0.84 1.30 1.80 CCX.75.RG1.79BU26M RG 179 B/U 3 75 ± 3 0.30 1.50 2.00 2.50 CCX.75.RG1.87AU26M RG 187 A/U 3 75 ± 3 0.30 1.50 2.00 2.60 CCX.50.RG1.88AU26B RG 188 A/U 1 50 ± 2 0.54 1.50 2.00 2.60 CCX.50.RG1.96AU20B RG 196 A/U 2 50 ± 2 0.30 0.84 1.30 1.95 213 000 LEDE RG 213 /U 7 50 ± 2 2.25 7.25 8.20 10.30 CCX.50.RG3.16U26M RG 223 /U 6 50 ± 2 0.89 2.95 4.30 5.40 RG 302 /U 5 75 ± 3 0.64 3.70 4.40 5.10 RG 316 /U 1 50 ± 2 0.54 1.50 2.10 2.60 RG 400 /U 5 50 ± 2 1.00 2.98 4.20 5.00 Note: the cable group number corresponding to the chosen cable must be written in the variant position, see pages 15 and 17. Recommended triaxial cables for S and E Series (page 19) LEMO cable Part Number Type CTR.50.RG1.78BU29M RGT 178 CTR.50.RG1.74AU39N RGT 174 466 140 LEDE Sheath ø (mm) 1 50 ± 2 0.30 0.90 1.37 2.30 2.80 2 50 ± 2 0.48 1.55 1.90 2.90 3.90 9222 Belden 3 50 ± 2 0.94 2.90 3.50 5.20 6.10 HF-2318 Dätwyler 5 50 ± 2 1.60 4.80 – – 10.20 8215 Belden 4 75 ± 3 0.72 4.55 – – 8.43 8232A Belden 4 75 ± 3 0.80 3.70 – – 8.00 1) 375 029 LEDE LEMO Impedance Conductor Dielectric Screen 1 Screen 2 cable group (Ω) ø (mm) ø (mm) ø (mm) ø (mm) HF-2426 Dätwyler 4 75 ± 3 0.60 3.70 – – 8.00 RGT 179 6 75 ± 3 0.30 1.60 2.10 3.10 3.60 Triax 8 Nokia 4 75 ± 3 1.00 4.50 5.20 7.20 8.50 9267 Belden 5 75 ± 3 0.84 3.70 – – 9.20 Triax 11 Nokia 7 75 ± 3 1.40 6.50 7.20 9.40 10.90 8233A Belden 7 75 ± 3 1.60 7.30 – – 12.10 Note: 1) when used with 1S.650 / 1E.650, please request large contact bucket («W» type). 30 www.lemo.com ® www.lemo.com ® 31 ® 32 ® www.lemo.com ® ® Product safety notice PLEASE READ AND FOLLOW ALL INSTUCTIONS CAREFULLY AND CONSULT ALL RELEVENT NATIONAL AND INTERNATIONAL SAFETY REGULATIONS FOR YOUR APPLICATION. IMPROPER HANDLING, CABLE ASSEMBLY, OR WRONG USE OF CONNECTORS CAN RESULT IN HAZARDOUS SITUATIONS. 1. SHOCK AND FIRE HAZARD Incorrect wiring, the use of damaged components, presence of foreign objects (such as metal debris), and / or residue (such as cleaning fluids), can result in short circuits, overheating, and / or risk of electric shock. Mated components should never be disconnected while live as this may result in an exposed electric arc and local overheating, resulting in possible damage to components. 2. HANDLING Connectors and their components should be visually inspected for damage prior to installation and assembly. Suspect components should be rejected or returned to the factory for verification. Connector assembly and installation should only be carried out by properly trained personnel. Proper tools must be used during installation and / or assembly in order to obtain safe and reliable performance. 3. USE Connectors with exposed contacts should never be live (or on the current supply side of a circuit). Under general conditions voltages above 30 VAC and 42 VDC are considered hazardous and proper measures should be taken to eliminate all risk of transmission of such voltages to any exposed metal part of the connector. 4. TEST AND OPERATING VOLTAGES The maximum admissible operating voltage depends upon the national or international standards in force for the application in question. Air and creepage distances impact the operating voltage; reference values are indicated in the catalog however these may be influenced by PC board design and / or wiring harnesses. The test voltage indicated in the catalog is 75% of the mean breakdown voltage; the test is applied at 500 V/s and the test duration is 1 minute. 5. CE MARKING CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. 6. PRODUCT IMPROVEMENTS The LEMO Group reserves the right to modify and improve to our products or specifications without providing prior notification. 7. WARNING (Prop 65 State of California) Proposition 65 requires businesses to provide warnings to Californians about significant exposures to chemicals that cause cancer, birth defects or other reproductive harm. LEMO products are exempt from proposition 65 warnings because they are manufactured, marketed, and sold solely for commercial and industrial use. For further information, please visit https://www.lemo.com/quality/LEMO-Prop-65-compliance-declaration.pdf. Disclaimers LEMO works constantly to improve the quality of its products; the information and illustrations figuring in this document may therefore vary and are not binding. In any case, LEMO makes no specific warranty of merchantability, fitness for a particular purpose, third party components as such or included in assembly, non-infringement, title, accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO component. In no event shall LEMO, its affiliates, officers, agents or employees be liable for any incidental, indirect, special or consequential damages in connection with the products or services provided by LEMO, including (without limitation) loss of profits or revenues, interruption of business, loss of use of the products or any associated equipment, materials, components or products, damages to associated equipment or in combination with other components, materials. Reproduction of significant portions of LEMO information in LEMO data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. LEMO is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO SA reserves the right to modify and improve specifications, at all times, without any notification. www.lemo.com 33 LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. +41 21 695 16 00 - e-mail: info@lemo.com SUBSIDIARIES AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: +43 1 914 23 20 0 Fax:+43 1 914 23 20 11 salesAT@lemo.com BRAZIL LEMO Latin America Ltda Av. Dr. Adhemar de Barros, 566 – Sala 1407, Vila Adyana CEP: 12245-011 São José dos Campos - SP - Brazil Tel: +55 11 94242 4293 info-la@lemo.com CANADA LEMO Canada Inc 44 East Beaver Creek Road, unit 20 Richmond Hill, Ontario L4B 1G8 Tel: +1 905 889 56 78 Fax: +1 905 889 49 70 info-canada@lemo.com CHINA / HONG KONG LEMO Electronics (Shanghai) Co., Ltd First Floor, Block E, 18 Jindian Road, Pudong Shanghai, China, 201206 Tel: +86 21 5899 7721 Fax: +86 21 5899 7727 cn.sales@lemo.com DENMARK LEMO Denmark A/S Mandal Allé 16A 5500 Middelfart Tel: +45 45 20 44 00 Fax: +45 45 20 44 01 info-dk@lemo.com FRANCE LEMO France Sàrl 24/28 Avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: +33 1 60 94 60 94 Fax: +33 1 60 94 60 90 info-fr@lemo.com GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: +49 89 42 77 03 Fax: +49 89 420 21 92 info@lemo.de HUNGARY REDEL Elektronika Kft Nagysándor József u. 6-12 1201 Budapest Tel: +36 1 421 47 10 Fax: +36 1 421 47 57 info-hu@lemo.com ITALY LEMO Italia srl Viale Lunigiana 25 20125 Milano Tel: +39 02 66 71 10 46 Fax: +39 02 37 90 80 46 sales.it@lemo.com JAPAN LEMO Japan Ltd 2-7-22, Mita, Minato-ku, Tokyo, 108-0073 Tel: +81 3 54 46 55 10 Fax: +81 3 54 46 55 11 info-jp@lemo.com LEMO NETHERLANDS / BELGIUM LEMO Connectors Nederland B.V. Jacques Meuwissenweg 6 2031 AD Haarlem Tel. +31 23 206 07 01 info-nl@lemo.com NORWAY / ICELAND LEMO Norway A/S Soerumsandvegen 69, 1920 Soerumsand Tel: +47 22 91 70 40 Fax: +47 22 91 70 41 info-no@lemo.com SINGAPORE LEMO Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building Singapore 159088 Tel: +65 6476 0672 Fax: +65 6474 0672 sg.sales@lemo.com SPAIN / PORTUGAL IBERLEMO SAU Brasil, 45, 08402 Granollers Barcelona Tel: +34 93 860 44 20 Fax: +34 93 879 10 77 info-es@lemo.com SWEDEN / FINLAND LEMO Nordic AB Gunnebogatan 30 163 53 Spånga Tel: +46 8 635 60 60 Fax: +46 8 635 60 61 info-se@lemo.com SWITZERLAND LEMO Verkauf AG Grundstrasse 22 B, 6343 Rotkreuz Tel: +41 41 790 49 40 ch.sales@lemo.com TAIWAN TAOYUAN TAIWAN Tel: +886 967 132 824 speng@lemo.com UNITED ARAB EMIRATES LEMO Middle East Connectors LLC Concorde Tower 11th Floor, Office 1102, Dubai Media City, P.O. Box 449849 Dubai, United Arab Emirates Tel: +971 4 568 1904 info-me@lemo.com UNITED KINGDOM LEMO UK Ltd 12-20 North Street, Worthing, West Sussex, BN11 1DU Tel: +44 1903 23 45 43 lemouk@lemo.com USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: +1 707 578 88 11 +1 800 444 53 66 Fax: +1 707 578 08 69 info-US@lemo.com DISTRIBUTORS ARGENTINA, AUSTRALIA, BRAZIL, CHILE, COLOMBIA, CZECH REPUBLIC, GREECE, INDIA, ISRAEL, NEW ZEALAND, PERU, POLAND, SOUTH AFRICA, SOUTH KOREA, TURKEY, UKRAINE www.lemo.com CAT.CT.LEN.P0410, © LEMO / Data subject to change, printed in Switzerland, updated November 2022 LEMO
FLA.1S.650.ZTA 价格&库存
很抱歉,暂时无法提供与“FLA.1S.650.ZTA”相匹配的价格&库存,您可以联系我们找货
