ROHS COMPLIANT
REVISION HISTORY
DESCRIPTION
REV
PRODUCT DATA DRAWING
DCN 35547
DATE
APPROVED
11/07
STW
.264 6.71
.156 3.96
.198 5.03
.131 3.33
.266 6.76
.198 5.03
MATERIAL:
BODIES, CONTACT
EMI RING, CAP &
ANTI-ROCK RING:
INSULATOR:
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B
ACCEPTS RG-178 CABLE
FINISH:
BODIES, CONTACT
EMI RING CAP &
ALIGNMENT RING:
GOLD PER ASTM B 488, TYPE II,
CODE C, CLASS 1.27; OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
VSWR:
INSERTION LOSS:
DWV:
OPERATING TEMP.:
INSUL. RES.:
50 OHMS
DC TO 3.0 GHz
1.30:1 DC TO 3.0 GHz
.12 X SQRT(F(F IN GHz))
500 VRMS
-55 C TO +125 C
5000 MEGOHMS.
MATERIAL:
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
HLP 11/29/07
CHECKED:
APPROVED:
STW 11/29/07
STW 11/29/07
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
R/A SMP JACK
FOR RG-178 CABLE
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 15:1
1222-4006
SHEET 1 OF 1
很抱歉,暂时无法提供与“1222-4006”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+473.797901+61.37340
- 10+402.6947610+52.16306
- 25+377.4952925+48.89885
- 50+359.4916250+46.56674
- 100+342.35135100+44.34648
