1485-6000
1485-6000
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMMAPLUGSTR50OHMPCB
1485-6000 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING A DCN 42242 DATE APPROVED 06/16 STW .240 6.10 .498 12.65 .343 8.71 REVISION HISTORY DESCRIPTION REV .155 3.94 .200 5.08 .034 0.86 4X .040 1.02 MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1; OR ASTM A582 TYPE 303, COND A CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: FLUOROSILICONE NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com FINISH: BODY & CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: 50 OHMS N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: BRT 08/05/02 CHECKED: APPROVED: STW 08/05/02 STW 08/05/02 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMMA PLUG PCB MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 10:1 1485-6000 SHEET 1 OF 1
1485-6000 价格&库存
很抱歉,暂时无法提供与“1485-6000”相匹配的价格&库存,您可以联系我们找货
